rkdover 0 Posted ... (edited) Hi! I've been using eddie with a port forwarded for a couple days but wanted to change to a headless setup. I install suite 1.3.0 and set up bluetit, and it works, but I was forced to change my port forwarding settings to "All devices" instead of the device-specific settings I would like to have. Is there any way to get that working? Edit: okay, well... I noticed it connected to the default, or first created device so I worked around it by making that one have the right settings. Still interested in if this is configurable in bluetit. Edited ... by rkdover Share this post Link to post
Staff 10494 Posted ... 1 hour ago, rkdover said: Still interested in if this is configurable in bluetit. Hello! Yes, connection's key ("device" in the Client Area) can be selected via Goldcrest's --air-key option: https://airvpn.org/suite/readme/#goldcrest-configuration or via Bluetit's run control file option airkey: https://airvpn.org/suite/readme/#bluetit-configuration Please note that the key string is case sensitive. Kind regards Share this post Link to post
rkdover 0 Posted ... 1 hour ago, Staff said: Hello! Yes, connection's key ("device" in the Client Area) can be selected via Goldcrest's --air-key option: https://airvpn.org/suite/readme/#goldcrest-configuration or via Bluetit's run control file option airkey: https://airvpn.org/suite/readme/#bluetit-configuration Please note that the key string is case sensitive. Kind regards Right, I tried that with both the UID and the wireguard public key for the device in question, and all I get is: ERROR: Key "<long key>" does not exist for user rkdover Share this post Link to post
Staff 10494 Posted ... 6 minutes ago, rkdover said: I tried that with both the UID and the wireguard public key for the device in question Hello! Wait, you must enter the key label. The label is just the name you assigned to the key in your AirVPN account device panel. Kind regards Share this post Link to post
rkdover 0 Posted ... 4 minutes ago, Staff said: Hello! Wait, you must enter the key label. The label is just the name you assigned to the key in your AirVPN account device panel. Kind regards Oh that totally worked. Thank you! Share this post Link to post
