gc2017
ANSWERED Problem trying to use Eddie on WiFi
I've been using Eddie for years on wired, today for the first time i disabled my wired, enabled wirelss, launched Eddie and a dialogue box pops up saying :
'Profile is encrypted through a password saved in OS keyring, password could not be found. Do you want to reset Eddie to default settings?'
Is there a way to create a separate profile for WiFi, is that what i should do ?
Thanks, Gary.
1 hour ago, TmDyB563 said:
Long story short: i can not use Eddie anymore. Uninstalled it and reinstalled. Tried older versions. Nothings works. So I need some help. Thanks.
@gc2017
Please try to delete the configuration file while Eddie is not running. Please see here to locate it:
https://eddie.website/support/data-path/
Re-start Eddie and check again. Can you also tell us which Eddie version you both are running?
