Not connected, Your IP: 216.73.216.54
xteve7221
Switching between Ethernet and WiFi connections
Good day,
I have been using Eddie quite happily for a few years now and most everything works fine.
I have only one nuance I would be happy to fix, if possible.
I can readily boot Windows into an Ethernet connection and Eddie (in my Startup) connects immediately (WiFi disabled).
I can also readily boot Windows into a WiFi connection and Eddie (in my Startup) connects immediately (no Ethernet is connected).
However, if I am in one or the other, then close Eddie, Hibernate, unplug Ethernet, power up, enable WiFi and then start Eddie,
Eddie appears to make a connection, but the System Tray displays the "no Internet connection" icon and I don't have any Internet.
The same applies if I am using Eddie on WiFi, then close Eddie, Hibernate, plug in Ethernet, power up laptop, start Eddie, I get the same thing.
If I am in either Ethernet or WiFi mode, I can open/close Eddie repeatedly with no issue.
It's when I try to switch from one to the other that Eddie  doesn't work.
Is there a setting I can adjust to remedy this?
Otherwise, it works like a charm.
BTW, while I have a IT background, it's not a very techie one, so go easy on me please.
All suggestions and thoughts are welcome and most appreciative of your time.
