Not connected, Your IP: 216.73.216.198
Blatantly0156
ANSWERED Gluetun: Port forwarding works for an hour
I'm running into an issue here, and I'm not sure where to start exactly.
The problem is probably not new, it's only that I didn't notice it before.
Here's my setup:
Proxmox > Debian > Docker > Gluetun > Multiple Qbittorrent instances
Qbittorrents are routed through gluetun.
I noticed I didn't get much upload, although I'm seeding a lot and was looking into the problem. I tested if ports were open on the dashboard here and it said Connection Refused (111).
I did some troubleshooting which got me to restart the stack of gluetun and qbittorrents. I checked if ports are open: Yes! (I didn't change anything in the config by the way)
Yay, Problem solved I thought.
Only after a couple days, the same error: Connection Refused.
I tested again now and the same thing happened after an hour or so.
Any ideas?
Here's docker-compose and gluetun logs:
https://pastebin.com/g7xw5E2R
It looks like a firewall issue of some kind, but there's no firewall running on the debian system. Maybe it's a gluetun issue, but I want to ask here as well
Thanks in advance
Thanks for the fast reply! I will look into it.
EDIT:
For future readers: the link above was exactly my problem. I fixed by delaying the health check to 2 minutes. Apparently this is used for OpenVPN only anyway. Since I use Wireguard it doesn't matter.
I added the following line to the environment in the gluetun docker-compose. 12 hours it's still running perfectly.
HEALTH_VPN_DURATION_INITIAL=120s
Edited ... by Blatantly0156
added my solution
It seems the healthcheck solution would be better though.
healthcheck:
    test: ["CMD-SHELL", "wget -qO- http://portcheck.transmissionbt.com/4330 | grep -q 1 || exit 1"]
    interval: 1m30s
    timeout: 10s
    retries: 3
    start_period: 40s
Edited ... by Gliglue
You could also run a script to check if the port is open, and if it's not restart the stack, then notify you via webhook.
Create a script file, put the below code in it (modify the CONFIGURATION section for your environment), make the file executable, then put it on a cron schedule (I check mine every 15 minutes, been running like this for a few months). I use Cronicle as my cron scheduler (it's nice using a single application to manage scheduling for multiple servers), but you could use crontab if you want simplicity.
#!/bin/sh
# CONFIGURATION
GLUETUN_CONTAINER="gluetun"
FORWARDED_PORT=YourForwardedPort
COMPOSE_DIR="/your/gluetun/docker/compose/directory"
WEBHOOK_URL="https://discord.com/api/webhooks/yourDiscordChannelWebhook"
# Get current VPN IP from inside the container using wget
VPN_IP=$(docker exec "$GLUETUN_CONTAINER" wget -qO- https://ipinfo.io/ip)
# Verify that we got an IP
if [ -z "$VPN_IP" ]; then
    echo "$(date) - ERROR: Could not retrieve VPN IP from container $GLUETUN_CONTAINER." >&2
    exit 1
fi
# Check if port is open using nc, suppressing nc's own output
if nc -z -w3 "$VPN_IP" "$FORWARDED_PORT" >/dev/null 2>&1; then
    echo "$(date) - Port $FORWARDED_PORT on $VPN_IP is open and reachable."
else
    echo "$(date) - Port $FORWARDED_PORT on $VPN_IP is closed. Restarting stack..."
    cd "$COMPOSE_DIR"
    docker compose down
    sleep 5
    docker compose up -d
    # Notify via Webhook about the restart
    curl -X POST -H "Content-Type: application/json" \
        -d '{"content":"VPN port forwarding failed. Gluetun stack restarted to repair the issue."}' \
        "$WEBHOOK_URL"
    echo "$(date) - Stack restarted in $COMPOSE_DIR due to port $FORWARDED_PORT being closed."
fi
