Not connected, Your IP: 216.73.216.208
Mytob
ANSWERED WebsitesTimeout With WireGuard Unifi USG
Got fiber to the home last week so I decided to switch from OpenVPN to Wireguard on my Ubiqity USG to make use of the higher thoughput offered from Wireguard. After switching from OpenVPN to Wireguard on my USG I am running into issues of various sites not working such as duckduckgo.com. Have checked again with OpenVPn and all works as expected. After doing a bit of searching the forums I came across others with a similar issue which suggested adjusting the MTU Value to 1300. This has had no effect on the issue. I have tried the same config files using the Windows client and it works fine. The USG will only seem to accept an IPV4 address as well for some reason? Any suggestions?
Please try MTU set to 1280 bytes, if you haven't already done so.
Hi 😃
Just tried 1280 via the config gen and has not made any difference unfortunatly. Did also just try a Wireguard config from VPN Unlimited and that is not having the same issue for some reason. Looked at the config files and there is no obvious differnce between them apart from having resolved hosts and the MTU line being omited from it. Can post cencored configs if its any help.
Thanks =)
10 hours ago, Mytob said:
Hi 😃
Thanks 😃
Is the Windows system successfully connecting with WireGuard through the same ISP and the same upstream router? If so, the problem should be Unifi specific.
Could you please send us the WireGuard log while the problem is ongoing? Can you also make sure that the WireGuard interface is up and running on the USG (please check the interface status by connecting via SSH to the device and entering either wg show or ip addr show command). Also check whether you can ping the VPN gateway directly from the Unifi device during your SSH session on the Unifi (ping 10.128.0.1) while the WireGuard connection is allegedly up.
Can confirm that i can access duckduckgo from Windows with a Windows wireguard client running. This is going over the same router and the same ISP as i am having issue with.
interface: wgclt1
  public key: u7FpkRwKI44Klsbzwzn/yFA1nsx8XWfpOLRV/kzIPzw=
  private key: (hidden)
  listening port: 36861
peer: PyLC<cut>
  preshared key: (hidden)
  endpoint: 83.143.245.53:1637
  allowed ips: 0.0.0.0/0
  latest handshake: 48 seconds ago
  latest receive: 2 seconds ago
  transfer: 5.58 GiB received, 7.02 GiB sent
  persistent keepalive: every 1 minute
  forced handshake: every 5 seconds
Working as far as i can tell!
root@UDM-SE:~# ping 10.128.0.1
PING 10.128.0.1 (10.128.0.1) 56(84) bytes of data.
^C
--- 10.128.0.1 ping statistics ---
151 packets transmitted, 0 received, 100% packet loss, time 155890ms
No luck on pinging from the USG
intrestingly though on Windows i get...
C:\Users\Ian>ping 10.128.0.1
Pinging 10.128.0.1 with 32 bytes of data:
Reply from 10.128.0.1: bytes=32 time=22ms TTL=63
Reply from 10.128.0.1: bytes=32 time=20ms TTL=63
Reply from 10.128.0.1: bytes=32 time=21ms TTL=63
Ping statistics for 10.128.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 20ms, Maximum = 22ms, Average = 21ms
From what I can gather it logs to messages which I have attached. The issues would have started from about 10/09/24 when I would have tried switchng to the Wireguard client.
.essages
@Mytob
While we can see multiple problems, none of them seems strictly related to WireGuard. Please re-check configuration through the official guide here:
https://help.ui.com/hc/en-us/articles/16357883221015-UniFi-Gateway-WireGuard-VPN-Client
and don't forget to set traffic routes to let devices send traffic over the VPN if necessary.
If the problem persists, we would suggest you contact Unifi support. If they reply and manage to solve the problem, please let the community know what the problem was: the info can be useful for future Unifi users.
