Randomletters
(DD-WRT) OpenVPN connects on my PC, but not my PS3 or mobile (both show my true IP)
Forgive my newbness, but any help would be appreciated. I followed the instructions found here https://airvpn.org/ddwrt/ and my PC connects fine and shows the correct server, but all of the other devices on my network still show my old IP.
Am I doing something wrong, or am I expecting too much?
Normally all the devices behind the DD-WRT will use the tunnel transparently, unless you have splitted traffic with multiple routing tables (on the router), can you please check that?
I don't know how to check that...I installed DDWRT on my Netgear WNDR3700 v1 and followed the instructions in the link from my first post. I made no other alterations.
If you tell me where to look, I can send you whatever info you need.
