worric 12 Posted ... Ello. I get an UDP packet exactly once every 30 seconds from some IP to the tun adapter - same source port, same destination port (different number, though). I haven't forwarded the ports in question in the AirVPN interface, which leads me to believe that something is faulty in the portforwarding feature of the AirVPN service. Could you please check if I'm right about this? Quote Share this post Link to post
Staff 10387 Posted ... Ello.I get an UDP packet exactly once every 30 seconds from some IP to the tun adapter - same source port, same destination port (different number, though). I haven't forwarded the ports in question in the AirVPN interface, which leads me to believe that something is faulty in the portforwarding feature of the AirVPN service.Could you please check if I'm right about this?Hello!We have checked that no unsolicited packet (except of course those toward your forwarded port) can reach your VPN IP address. Can you please contact us in private for further investigations?Kind regards Quote Share this post Link to post
