soupamoupes
ANSWERED Not connecting due to an TLS warning
This is the log
. 2024.07.04 11:34:35 - Using WinTun network interface "Eddie (Eddie Tunnel)"
! 2024.07.04 11:34:35 - Connecting to Mensa (United States of America, Dallas, Texas)
. 2024.07.04 11:34:36 - Routes, add xxx.xxx.xxx/32 for interface "Wi-Fi (Qualcomm Atheros QCA61x4 Wireless Network Adapter)".
. 2024.07.04 11:34:36 - Routes, add xxx.xxx.xxx/32 for interface "Wi-Fi (Qualcomm Atheros QCA61x4 Wireless Network Adapter)", already exists.
. 2024.07.04 11:34:36 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.07.04 11:34:36 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.07.04 11:34:36 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.07.04 11:34:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.07.04 11:34:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.07.04 11:34:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.07.04 11:34:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.07.04 11:34:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]204.8.98.52:443
. 2024.07.04 11:34:36 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.07.04 11:34:36 - OpenVPN > UDP link local: (not bound)
. 2024.07.04 11:34:36 - OpenVPN > UDP link remote: [AF_INET]204.8.98.52:443
. 2024.07.04 11:34:36 - OpenVPN > TLS: Initial packet from [AF_INET]204.8.98.52:443, sid=f0d1fac5 9eb5f0c7
. 2024.07.04 11:34:36 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.07.04 11:34:36 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.07.04 11:34:36 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.07.04 11:34:36 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.07.04 11:34:36 - OpenVPN > TLS Error: TLS handshake failed
. 2024.07.04 11:34:36 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.07.04 11:34:36 - OpenVPN > Restart pause, 5 second(s)
! 2024.07.04 11:34:36 - Disconnecting
. 2024.07.04 11:34:36 - Sending soft termination signal
. 2024.07.04 11:34:41 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
