FPyro 2 Posted ... Hey! Just got forcibly disconnected, now when I try to reconnect I get this: Tue Dec 04 02:23:35 2012 OpenVPN 2.3_beta1 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Sep 21 2012 Tue Dec 04 02:23:35 2012 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.10:25343 Tue Dec 04 02:23:35 2012 Need hold release from management interface, waiting... Tue Dec 04 02:23:36 2012 MANAGEMENT: Client connected from [AF_INET]127.0.0.10:25343 Tue Dec 04 02:23:36 2012 MANAGEMENT: CMD 'state on' Tue Dec 04 02:23:36 2012 MANAGEMENT: CMD 'log all on' Tue Dec 04 02:23:36 2012 MANAGEMENT: CMD 'hold off' Tue Dec 04 02:23:36 2012 MANAGEMENT: CMD 'hold release' Tue Dec 04 02:23:36 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Tue Dec 04 02:23:36 2012 Socket Buffers: R=[516096->516096] S=[172032->172032] Tue Dec 04 02:23:36 2012 UDPv4 link local: [undef] Tue Dec 04 02:23:36 2012 UDPv4 link remote: [AF_INET]46.165.208.69:443 Tue Dec 04 02:23:36 2012 MANAGEMENT: >STATE:1354584216,WAIT,,, Tue Dec 04 02:23:36 2012 MANAGEMENT: >STATE:1354584216,AUTH,,, Tue Dec 04 02:23:36 2012 TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=729e6c41 89679d2b Tue Dec 04 02:23:36 2012 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org Tue Dec 04 02:23:36 2012 VERIFY OK: nsCertType=SERVER Tue Dec 04 02:23:36 2012 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org Tue Dec 04 02:23:36 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Tue Dec 04 02:23:36 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Tue Dec 04 02:23:36 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Tue Dec 04 02:23:36 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Tue Dec 04 02:23:36 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Tue Dec 04 02:23:36 2012 [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443 Tue Dec 04 02:23:37 2012 MANAGEMENT: >STATE:1354584217,GET_CONFIG,,, Tue Dec 04 02:23:38 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:23:43 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:23:48 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:23:54 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:23:59 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:04 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:09 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:14 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:19 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:24 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:29 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:34 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Dec 04 02:24:39 2012 No reply from server after sending 12 push requests Tue Dec 04 02:24:39 2012 SIGUSR1[soft,no-push-reply] received, process restarting Tue Dec 04 02:24:39 2012 MANAGEMENT: >STATE:1354584279,RECONNECTING,no-push-reply,, Tue Dec 04 02:24:39 2012 Restart pause, 2 second(s) Tue Dec 04 02:24:41 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Tue Dec 04 02:24:41 2012 Socket Buffers: R=[516096->516096] S=[172032->172032] Tue Dec 04 02:24:41 2012 UDPv4 link local: [undef] Tue Dec 04 02:24:41 2012 UDPv4 link remote: [AF_INET]46.165.208.69:443 Tue Dec 04 02:24:41 2012 MANAGEMENT: >STATE:1354584281,WAIT,,, Server status looks really strange too.... almost no server has any load... something must be seriously wrong, could you pls check? Thank you Quote Share this post Link to post
Staff 10487 Posted ... We are experiencing an issue with the backend servers and we are working to solve it. Kind regards Quote Share this post Link to post
XSlim 1 Posted ... since the weekend before last often disconnects and won't reconnect says already connected restarted pc router and reinstalled doesn't work with client or without Quote Share this post Link to post
LTJBukem 0 Posted ... Is Serpentis Sweden Down or just me? I was able to connect about 1.5 hours ago from this post (nomatter timezone) but now I cannot connect. Also.. Anyone know the extension to add to the AIRVPN file you download. I thought it was .tlbk but now it shows a problem. I cannot connect to out of country servers (sweden) nor U.S. based Arizonaor VEGA... (where I am located (U.S.A.) Is there a log I can get to have someone help me? If so where?....The region which origin I really do not wish to divulge) But is it me or something wrong with AIRVPN Today? Maybe a server crash? Any thoughts would help as well as the extension I run MAC OSX 10.6.6 on the system I use AirVPN.. Log details I am willing to provide if y ou can tell me where to get em. 2nd month on Air VPN, still N00B. Be patient. Apparently I can build computers... set up a secure SPA network.... Alter REG, but VPN.. I'm still learning.. Quote Share this post Link to post
loganj 0 Posted ... I was also having problems. I was automatically disconnected and could not reconnect. Thank you Quote Share this post Link to post
Staff 10487 Posted ... Hello! The problem has been addressed. Normal connectivity should be totally restored. Please do not hesitate to write here or contact us if you still experience issues. Kind regards Quote Share this post Link to post
