em9991 0 Posted ... hello, i am switching my gluetun container from mulvad to airvpn, and am having issues getting port forwarding to work. the container works fine when i do not have port forwarding enabled. my docker compose is below. it is populated with values from here: https://airvpn.org/generator/ gluetun: image: qmcgaw/gluetun container_name: gluetun cap_add: - NET_ADMIN devices: - /dev/net/tun:/dev/net/tun ports: - 8080:8080 #qbittorrent - 6881:6881 #qbittorrent - 6881:6881/udp #qbittorrent - 9696:9696 #prowlarr - 8989:8989 #sonarr - 7878:7878 #radarr - 6767:6767 #bazarr volumes: - ./gluetun:/gluetun environment: - VPN_SERVICE_PROVIDER=airvpn - VPN_TYPE=wireguard - WIREGUARD_PRIVATE_KEY= - WIREGUARD_PRESHARED_KEY= - WIREGUARD_ADDRESSES= - SERVER_COUNTRIES=United States - SERVER_CITITES="Chicago Illinois" - FIREWALL_VPN_INPUT_PORTS= - TZ=America/Chicago Quote Share this post Link to post
Staff 10417 Posted ... @em9991 Hello! All the ports listed in the compose file are not reserved to your account and the only port you reserved in your AirVPN account port panel is not listed in the compose file. By fixing the ports section you should be able to resolve the issue. Please reserve one random port for each listening program and adjust the compose and program settings accordingly. Kind regards Quote Share this post Link to post
