igs1962 0 Posted ... Apologies if this has been asked before. I read though some threads and some of the information seemed inconsistent. I want to run utorrent through air vpn. I understand I need to log into air vpn before loading utorrent. Do I need to do anything else to make utorrent work through air vpn? How can I tell whether utorrent is working through air vpn, other than looking at the volume of data? Finally, I find the port forwarding thing a bit unclear. Do I need to use that to use air vpn? Or to use torrent through air vpn? Thanks in advance. Quote Share this post Link to post
Staff 10487 Posted ... Apologies if this has been asked before. I read though some threads and some of the information seemed inconsistent.I want to run utorrent through air vpn. I understand I need to log into air vpn before loading utorrent.Do I need to do anything else to make utorrent work through air vpn? How can I tell whether utorrent is working through air vpn, other than looking at the volume of data?Hello!No particular configuration is needed for uTorrent. For additional security, you can perform the following test:http://checkmytorrentip.comFinally, I find the port forwarding thing a bit unclear. Do I need to use that to use air vpn? Or to use torrent through air vpn?Please see here:https://airvpn.org/faq#port_forwardingand here:https://airvpn.org/faq#p2pKind regards Quote Share this post Link to post
