I'm trying to install ARM 64 bit, Portable mono on a raspberry pi and I installed mono and everything but when i try to run it with "mono Eddie-UI.exe" I get "Cannot open assembly 'Eddie-UI.exe' : No such file or directory .". I do not know why it refuses to run.
Eddie-UI.exe is not found. Please check the path and the file name (case sensitive) but also try to run eddie-ui (do not bypass it with "mono ...") which is the sh script which is meant to be run to start the software (with GUI). What is your Raspberry Pi version and which exact OS you run on it?
