Zhuangzi
ANSWERED Eddie connection loop
Hi, I can't seem to connect to any server. I just updated Eddie to the latest version. Ideas would be welcome!
Eddie System/Environment Report - 18-4-2024 - 20:01 UTC
-- redacted for privacy ---
. 2024.04.18 21:59:29 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22631.0, Mono/.Net: v4.0.30319
. 2024.04.18 21:59:29 - Command line arguments (1): path="home"
. 2024.04.18 21:59:31 - Reading options from <redacted>
. 2024.04.18 21:59:32 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.04.18 21:59:32 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.04.18 21:59:32 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2024.04.18 21:59:33 - Ready
. 2024.04.18 21:59:34 - Collect information about AirVPN completed
I 2024.04.18 21:59:36 - Session starting.
I 2024.04.18 21:59:36 - Checking authorization ...
. 2024.04.18 21:59:37 - Added new network interface "Eddie", Wintun version 0.12
. 2024.04.18 21:59:38 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
. 2024.04.18 21:59:38 - IPv6 disabled with packet filtering.
! 2024.04.18 21:59:38 - Connecting to Menkent (Netherlands, Alblasserdam)
. 2024.04.18 21:59:38 - Routes, add 213.152.176.140/32 for interface "Wi-Fi (Intel(R) Dual Band Wireless-AC 7265)".
. 2024.04.18 21:59:38 - Routes, add 213.152.176.140/32 for interface "Wi-Fi (Intel(R) Dual Band Wireless-AC 7265)", already exists.
. 2024.04.18 21:59:38 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.18 21:59:38 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.18 21:59:38 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.18 21:59:38 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.18 21:59:38 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.18 21:59:38 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.18 21:59:38 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.18 21:59:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.176.140:443
. 2024.04.18 21:59:38 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.18 21:59:38 - OpenVPN > UDP link local: (not bound)
. 2024.04.18 21:59:38 - OpenVPN > UDP link remote: [AF_INET]213.152.176.140:443
. 2024.04.18 21:59:38 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.176.140:443, sid=da11f5b0 2dc642ff
. 2024.04.18 21:59:38 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.18 21:59:38 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.18 21:59:38 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.18 21:59:38 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.18 21:59:38 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.18 21:59:38 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.18 21:59:38 - OpenVPN > Restart pause, 5 second(s)
