Not connected, Your IP: 216.73.217.154
castortroy86
ANSWERED DNS IPv6 is reset when disconnecting
In Windows 11 Network settings, I set Quad9 DNS for IPv6 over HTTPS.
If I now use eddie and then disconnect from the VPN, my windows DNS settings becomes my IPv6 router/gateway.
I want it to stay on quad9.
It's unexpected, can you please attach the link to a system report, generated after the problem has happened? Please see here to do so:
https://airvpn.org/forums/topic/50663-youve-been-asked-for-a-support-filesystem-report-–-heres-what-to-do/
Can you also test Eddie 2.24.x and check whether the problem persists or is solved? Please see here to download Eddie 2.24 beta version:
https://airvpn.org/forums/topic/57401-eddie-desktop-224-beta-released/
