Here are my logs.  Client keeps restarting.  Re-installed twice.
. 2024.04.09 15:18:03 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22631.0, Mono/.Net: v4.0.30319
. 2024.04.09 15:18:04 - Reading options from C:\Users\dawgw\AppData\Local\Eddie\default.profile
. 2024.04.09 15:18:05 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.04.09 15:18:05 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.04.09 15:18:05 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2024.04.09 15:18:05 - Ready
. 2024.04.09 15:18:07 - Collect information about AirVPN completed
I 2024.04.09 15:18:32 - Session starting.
I 2024.04.09 15:18:34 - Checking authorization ...
. 2024.04.09 15:18:35 - Added new network interface "Eddie", Wintun version 0.12
. 2024.04.09 15:18:35 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.09 15:18:35 - Connecting to Polis (United States of America, Raleigh, North Carolina)
. 2024.04.09 15:18:36 - Routes, add 198.54.130.30/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)".
. 2024.04.09 15:18:36 - Routes, add 198.54.130.30/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)", already exists.
. 2024.04.09 15:18:36 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.09 15:18:36 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.09 15:18:36 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.09 15:18:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.09 15:18:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.09 15:18:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.09 15:18:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.09 15:18:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]198.54.130.30:443
. 2024.04.09 15:18:36 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.09 15:18:36 - OpenVPN > UDP link local: (not bound)
. 2024.04.09 15:18:36 - OpenVPN > UDP link remote: [AF_INET]198.54.130.30:443
. 2024.04.09 15:18:36 - OpenVPN > TLS: Initial packet from [AF_INET]198.54.130.30:443, sid=1bb244c8 65ecb4ac
. 2024.04.09 15:18:36 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.09 15:18:36 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.09 15:18:36 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.09 15:18:36 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.09 15:18:36 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.09 15:18:36 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.09 15:18:36 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.09 15:18:36 - Disconnecting
. 2024.04.09 15:18:36 - Sending soft termination signal
. 2024.04.09 15:18:42 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.09 15:18:42 - Routes, delete 198.54.130.30/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)".
. 2024.04.09 15:18:42 - Routes, delete 198.54.130.30/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)", not exists.
. 2024.04.09 15:18:42 - Connection terminated.
I 2024.04.09 15:18:45 - Checking authorization ...
. 2024.04.09 15:18:46 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.09 15:18:46 - Connecting to Garnet (Netherlands, Alblasserdam)
. 2024.04.09 15:18:46 - Routes, add 213.152.162.76/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)".
. 2024.04.09 15:18:46 - Routes, add 213.152.162.76/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)", already exists.
. 2024.04.09 15:18:47 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.09 15:18:47 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.09 15:18:47 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.09 15:18:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.09 15:18:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.09 15:18:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.09 15:18:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.09 15:18:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.76:443
. 2024.04.09 15:18:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.09 15:18:47 - OpenVPN > UDP link local: (not bound)
. 2024.04.09 15:18:47 - OpenVPN > UDP link remote: [AF_INET]213.152.162.76:443
. 2024.04.09 15:18:47 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.76:443, sid=9e499c96 91540e0b
. 2024.04.09 15:18:47 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.09 15:18:47 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.09 15:18:47 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.09 15:18:47 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.09 15:18:47 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.09 15:18:47 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.09 15:18:47 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.09 15:18:47 - Disconnecting
. 2024.04.09 15:18:47 - Sending soft termination signal
. 2024.04.09 15:18:52 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.09 15:18:52 - Routes, delete 213.152.162.76/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)".
. 2024.04.09 15:18:52 - Routes, delete 213.152.162.76/32 for interface "Wi-Fi (Realtek RTL8822BE 802.11ac PCIe Adapter)", not exists.
. 2024.04.09 15:18:52 - Connection terminated.
I 2024.04.09 15:18:55 - Checking authorization ...
