Millennium Falcon
ANSWERED Out of nowhere, vpn won't connect!
AirVpn has been working flawlesly for 5+ years, and this morning it just keeps restarting, meaning it just disconnects and then tries to re-connect, but with no luck!
Help please,
. 2024.04.08 11:36:44 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22631.0, Mono/.Net: v4.0.30319
. 2024.04.08 11:36:44 - Command line arguments (1): path="home"
. 2024.04.08 11:36:47 - Reading options from C:\Users\kelly\AppData\Local\Eddie\default.profile
. 2024.04.08 11:36:49 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.04.08 11:36:49 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.04.08 11:36:49 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
! 2024.04.08 11:36:50 - Activation of Network Lock - Windows Filtering Platform
I 2024.04.08 11:36:51 - Ready
. 2024.04.08 11:36:53 - Collect information about AirVPN completed
I 2024.04.08 11:36:54 - Session starting.
I 2024.04.08 11:36:54 - Checking authorization ...
. 2024.04.08 11:36:57 - Collect information about AirVPN completed
. 2024.04.08 11:36:58 - Added new network interface "Eddie", Wintun version 0.12
. 2024.04.08 11:36:58 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:36:58 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:36:59 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:36:59 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:36:59 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:36:59 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:36:59 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:36:59 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:36:59 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:36:59 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:36:59 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:36:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:36:59 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:36:59 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:36:59 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:36:59 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=351e8aaa d1e4b326
. 2024.04.08 11:37:00 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:37:00 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:37:00 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:37:00 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:37:00 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:37:00 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:37:00 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:37:00 - Disconnecting
. 2024.04.08 11:37:00 - Sending soft termination signal
. 2024.04.08 11:37:04 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:37:05 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:05 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", not exists.
. 2024.04.08 11:37:05 - Connection terminated.
I 2024.04.08 11:37:08 - Checking authorization ...
. 2024.04.08 11:37:10 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:37:10 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:37:11 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:11 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:37:11 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:37:11 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:37:11 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:37:11 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:11 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:11 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:11 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:11 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:37:11 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:37:11 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:11 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=9ad4b178 62d34cde
. 2024.04.08 11:37:12 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:37:12 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:37:12 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:37:12 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:37:12 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:37:12 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:37:12 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:37:12 - Disconnecting
. 2024.04.08 11:37:12 - Sending soft termination signal
. 2024.04.08 11:37:17 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:37:17 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:17 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", not exists.
. 2024.04.08 11:37:17 - Connection terminated.
I 2024.04.08 11:37:20 - Checking authorization ...
. 2024.04.08 11:37:22 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:37:22 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:37:23 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:23 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:37:23 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:37:23 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:37:23 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:37:23 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:23 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:23 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:23 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:23 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:37:23 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:37:23 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:23 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=3a25aa8b 26506ae8
. 2024.04.08 11:37:23 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:37:23 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:37:23 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:37:23 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:37:23 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:37:23 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:37:23 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:37:23 - Disconnecting
. 2024.04.08 11:37:23 - Sending soft termination signal
. 2024.04.08 11:37:28 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:37:29 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:29 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", not exists.
. 2024.04.08 11:37:29 - Connection terminated.
I 2024.04.08 11:37:32 - Checking authorization ...
. 2024.04.08 11:37:34 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:37:34 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:37:34 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:35 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:37:35 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:37:35 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:37:35 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:37:35 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:35 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:35 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:35 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:35 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:37:35 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:37:35 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:35 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=00db1bd7 db19b8c6
. 2024.04.08 11:37:35 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:37:35 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:37:35 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:37:35 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:37:35 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:37:35 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:37:35 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:37:35 - Disconnecting
. 2024.04.08 11:37:35 - Sending soft termination signal
. 2024.04.08 11:37:40 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:37:41 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:41 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", not exists.
. 2024.04.08 11:37:41 - Connection terminated.
I 2024.04.08 11:37:44 - Checking authorization ...
. 2024.04.08 11:37:45 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:37:45 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:37:46 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:46 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:37:46 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:37:46 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:37:46 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:37:46 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:46 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:46 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:46 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:46 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:46 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:37:46 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:37:46 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:47 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=81ee2178 8a3943d9
. 2024.04.08 11:37:47 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:37:47 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:37:47 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:37:47 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:37:47 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:37:47 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:37:47 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:37:47 - Disconnecting
. 2024.04.08 11:37:47 - Sending soft termination signal
. 2024.04.08 11:37:52 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:37:52 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:52 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", not exists.
. 2024.04.08 11:37:52 - Connection terminated.
I 2024.04.08 11:37:55 - Checking authorization ...
. 2024.04.08 11:37:57 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:37:57 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:37:58 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:37:58 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:37:58 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:37:58 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:37:58 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:37:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:37:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:37:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:58 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:37:58 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:37:58 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:37:58 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=cc8b878f f5a55914
. 2024.04.08 11:37:58 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:37:58 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:37:58 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:37:58 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:37:58 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:37:58 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:37:58 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:37:58 - Disconnecting
. 2024.04.08 11:37:58 - Sending soft termination signal
. 2024.04.08 11:38:03 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:38:04 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:38:04 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", not exists.
. 2024.04.08 11:38:04 - Connection terminated.
I 2024.04.08 11:38:07 - Checking authorization ...
. 2024.04.08 11:38:09 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.04.08 11:38:09 - Connecting to Aquila (United States of America, Fremont, California)
. 2024.04.08 11:38:10 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
. 2024.04.08 11:38:10 - Routes, add 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)", already exists.
. 2024.04.08 11:38:10 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.04.08 11:38:10 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.04.08 11:38:10 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.04.08 11:38:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:38:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:38:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.08 11:38:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.08 11:38:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]23.130.104.132:443
. 2024.04.08 11:38:10 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.04.08 11:38:10 - OpenVPN > UDP link local: (not bound)
. 2024.04.08 11:38:10 - OpenVPN > UDP link remote: [AF_INET]23.130.104.132:443
. 2024.04.08 11:38:10 - OpenVPN > TLS: Initial packet from [AF_INET]23.130.104.132:443, sid=5ad1e0d4 eb5a90d8
. 2024.04.08 11:38:10 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.04.08 11:38:10 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.04.08 11:38:10 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.04.08 11:38:10 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.04.08 11:38:10 - OpenVPN > TLS Error: TLS handshake failed
. 2024.04.08 11:38:10 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.04.08 11:38:10 - OpenVPN > Restart pause, 5 second(s)
! 2024.04.08 11:38:10 - Disconnecting
. 2024.04.08 11:38:10 - Sending soft termination signal
. 2024.04.08 11:38:15 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2024.04.08 11:38:16 - Routes, delete 23.130.104.132/32 for interface "Wi-Fi (Qualcomm Atheros QCA9377 Wireless Network Adapter)".
Edited ... by Millennium Falcon
