firefox4dawin 0 Posted ... The vpn seems to be doing a connection loop again for some reason, and again, none of the above fixes are solving the problem log.txt Quote Share this post Link to post
choonietookie 0 Posted ... Started using zero tier to play LAN games with a friend recently and now today (after a windows update - might have been the cause), I began having trouble connecting to any airvpn servers. it was something like this in the log. 2024.04.01 20:39:47 - Routes, add () for interface "Zerotier network device". I went to change it from automatic to my ethernet interface but it would not properly switch, it kept trying to use the Zerotier interface. I got it working by disabling the zerotier interface in windows and then restarting eddie. Switching it back to automatic finally worked. Is there any fix for this so I don't have to enable / disable the zerotier interface every time? Or perhaps a reason why it would default to that interface instead of the usual ethernet interface? Quote Share this post Link to post
Staff 10716 Posted ... @choonietookie Hello! We have moved your message into this thread because the problem is related to the "ZeroTier" interface for both of you. The interface is apparently causing troubles to Eddie. We'll investigate. In the meantime @firefox4dawin you can disable the interface to solve the problem, as reported by choonietookie. Can you please verify (you both) whether the same problem occurs with Eddie 2.24.x (with the ZeroTier interface enabled)? Please see here to download it. https://airvpn.org/forums/topic/57401-eddie-desktop-224-beta-released/ Kind regards Quote Share this post Link to post
choonietookie 0 Posted ... (edited) 10 hours ago, Staff said: @choonietookie Hello! We have moved your message into this thread because the problem is related to the "ZeroTier" interface for both of you. The interface is apparently causing troubles to Eddie. We'll investigate. In the meantime @firefox4dawin you can disable the interface to solve the problem, as reported by choonietookie. Can you please verify (you both) whether the same problem occurs with Eddie 2.24.x (with the ZeroTier interface enabled)? Please see here to download it. https://airvpn.org/forums/topic/57401-eddie-desktop-224-beta-released/ Kind regards Hi, thank you for the response. Initially I was using the stable branch version 2.21.8. In an attempt to fix the problem, I uninstalled and reinstalled using the current experimental branch, 2.42.2. I also tried restarting my pc a couple times lol. Both versions seem to have the issue. Eddie is working again today even with the zerotier interface enabled. Edited ... by choonietookie Quote Share this post Link to post
choonietookie 0 Posted ... (edited) 14 hours ago, firefox4dawin said: The vpn seems to be doing a connection loop again for some reason, and again, none of the above fixes are solving the problem log.txt 32.46 kB · 3 downloads Open up start menu, type settings, go to network and internet, and at the bottom click advanced network settings. Click the disable button next to the zerotier virtual port interface. Restart eddie and it should work. I was then able to re-enable the zerotier interface and it did not interfere with eddie anymore. 🤷 Edited ... by choonietookie Quote Share this post Link to post
airvpn_8735g7bshdfs 0 Posted ... There is definitely still something off with Eddie - when there is a Zerotier Network Adapter on Win11 Eddie always connects to this one. Even if I select my physical ethernet port in Settings > Networking > "Ethernet 2" (or any other) Only workaround I find atm to use Eddie without uninstalling Zerotier is: Disabling the adapter in Control Panel > Network and Internet > Network Connections and restarting Eddie (reconnecting doesnt help as Eddie tries to connect using the disabled Zerotier adapter). This is very annoying behaviour, especially that it still tries to use the Zerotier connection, even if manually configured to use another one. Quote Share this post Link to post
su1 0 Posted ... No updates for this? This is the case for me as well. The only way is to disable the Zerotier connection. I've tried all the options under the Networking tab, no luck. Any ideas/workarounds? Quote Share this post Link to post
Goetia 0 Posted ... This issue is occurring for me with multiple NICs and ZeroTier. I have tried forcing specific configurations through the Networking tab, but it selects whatever network interface it wants. The only way I can get it to connect is to disable the other interfaces. This bug is quickly becoming a dealbreaker for me. It would be much appreciated to have a fix or an update. Quote Share this post Link to post
oubliettex1 0 Posted ... Still an issue as of 12/21/25 on 2.24.6, was really wondering why I was getting stuck trying to handshake with a peer over and over again and finally spotted that Eddie was defaulting to the ZeroTier interface until I disabled it and restarted Eddie. Quote Share this post Link to post
magicrectangle 0 Posted ... I just updated to Eddie 2.26.2 and started having this problem. I wasn't having it with an older version (several years old, sorry, don't know what the version was) but now I am. Rather frustrating that it's a known bug for two years with no fix. Setting the interface in the settings doesn't stop it from targeting the zero tier interface. Quote Share this post Link to post
