Trubl13
ANSWERED AirVPN connecting then terminating, connecting & terminating
VPN not connecting, going thru each server connecting then disconnecting.  I've set Network Lock mode to None.  Getting  OpenVPN > Exiting due to fatal error.
Here is log file of last connection try:
. 2024.03.25 12:59:27 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22631.0, Mono/.Net: v4.0.30319
. 2024.03.25 12:59:27 - Command line arguments (1): path="home"
. 2024.03.25 12:59:28 - Reading options from C:\Users\notyo\AppData\Local\Eddie\default.profile
. 2024.03.25 12:59:28 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.03.25 12:59:28 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.03.25 12:59:28 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2024.03.25 12:59:29 - Ready
. 2024.03.25 12:59:30 - Collect information about AirVPN completed
I 2024.03.25 12:59:33 - Checking login ...
! 2024.03.25 12:59:34 - Logged in.
I 2024.03.25 12:59:42 - Session starting.
I 2024.03.25 12:59:43 - Checking authorization ...
. 2024.03.25 12:59:44 - Using WinTun network interface "Local Area Connection (Kaspersky VPN)"
! 2024.03.25 12:59:44 - Connecting to Nahn (Canada, Vancouver)
. 2024.03.25 12:59:44 - Routes, add 192.30.89.69/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller)".
. 2024.03.25 12:59:44 - Routes, add 192.30.89.69/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller)", already exists.
. 2024.03.25 12:59:44 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.03.25 12:59:44 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.03.25 12:59:44 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.03.25 12:59:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.03.25 12:59:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.03.25 12:59:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.03.25 12:59:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.03.25 12:59:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.69:443
. 2024.03.25 12:59:44 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.03.25 12:59:44 - OpenVPN > UDP link local: (not bound)
. 2024.03.25 12:59:44 - OpenVPN > UDP link remote: [AF_INET]192.30.89.69:443
. 2024.03.25 12:59:44 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.69:443, sid=9802d7a5 1df2a7ac
. 2024.03.25 12:59:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2024.03.25 12:59:44 - OpenVPN > VERIFY KU OK
. 2024.03.25 12:59:44 - OpenVPN > Validating certificate extended key usage
. 2024.03.25 12:59:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2024.03.25 12:59:44 - OpenVPN > VERIFY EKU OK
. 2024.03.25 12:59:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org
. 2024.03.25 12:59:45 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2024.03.25 12:59:45 - OpenVPN > [Nahn] Peer Connection Initiated with [AF_INET]192.30.89.69:443
. 2024.03.25 12:59:45 - OpenVPN > SENT CONTROL [Nahn]: 'PUSH_REQUEST' (status=1)
. 2024.03.25 12:59:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.35.66.1,dhcp-option DNS6 fde6:7a:7d20:1f42::1,tun-ipv6,route-gateway 10.35.66.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1f42::1018/64 fde6:7a:7d20:1f42::1,ifconfig 10.35.66.26 255.255.255.0,peer-id 8,cipher AES-256-GCM'
. 2024.03.25 12:59:45 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2024.03.25 12:59:45 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.35.66.1'
. 2024.03.25 12:59:45 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1f42::1'
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2024.03.25 12:59:45 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2024.03.25 12:59:45 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2024.03.25 12:59:45 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2024.03.25 12:59:45 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2024.03.25 12:59:45 - OpenVPN > interactive service msg_channel=0
. 2024.03.25 12:59:45 - OpenVPN > open_tun
. 2024.03.25 12:59:45 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system.  You should be able to create an adapter by using tapctl.exe utility.
. 2024.03.25 12:59:45 - OpenVPN > Exiting due to fatal error
! 2024.03.25 12:59:45 - Disconnecting
. 2024.03.25 12:59:45 - Routes, delete 192.30.89.69/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller)".
. 2024.03.25 12:59:46 - Routes, delete 192.30.89.69/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller)", not exists.
. 2024.03.25 12:59:46 - Connection terminated.
I 2024.03.25 12:59:49 - Checking authorization ...
Just started using airvpn a couple of days ago.  Trying to use on a unraid server thru deluge container, 1st couple of hours were OK, then started to have issues with certain containers, traced problem back to airvpn not connecting??
Any help greatly appreciated
Tim N
Solution worked, able to get connected thru eddie.  Switched to wireguard, added eddie to the VPN interface name, I did not install tapctl.exe utility since I change to WireGuard.
Now on to setting up AirVPN on Deluge container for Unraid.  I may be requesting more help :)
Tim N
