AuContraire 1 Posted ... I have been running Eddie successfully on a Pi 4 for a long time. I just acquired a Pi 5 and Eddie will not run, at least not properly. It gets to the “Elevated Privileges” box and hangs, with the main window just a black box DISCLOSURE: I began by running the Pi 5 on the same 3 amp power supply as the Pi 4. Pi 5 technically prefers a 5 amp supply. I wonder if the low power is an issue? I have ordered a 5 amp power supply and will comment again once I have it installed but if anyone has insight on this question it would be good to hear. Quote Share this post Link to post
Staff 10487 Posted ... Hello! Can you tell us the Operating System running in the Pi 5? We suspect an incompatibility with a specific Raspberry Pi OS version. Kind regards Quote Share this post Link to post
AuContraire 1 Posted ... I am running the recommended 64 bit Raspberry OS with desktop, ie aarch64, which is the same OS I run on the Pi 4 Quote Share this post Link to post
AuContraire 1 Posted ... I am now using a 5 amp power supply but Eddie behaviour is unchanged. Will not finish loading and it becomes completely hung. Cannot even close it. It even defeats the shutdown of the Pi. I have to literally pull the plug to do a reboot. I have uninstalled Eddie. Looking now for an alternative client. Please let me know if there is a solution. I like Eddie but it's not much use like this Quote Share this post Link to post
AuContraire 1 Posted ... I have now tried the following: I have used the system disk that works perfectly (including Eddie) in my Pi 4 and used it to boot up the Pi 5. Everything works fine except, you guessed it, Eddie fails in exactly the same way I return the disk to the Pi 4 and everything, including Eddie, works fine There is something specifically about Eddie that will not run on a Pi 5 regardless of the OS environment. Have you specifically tried running Eddie on a Pi 5? Quote Share this post Link to post
Staff 10487 Posted ... @AuContraire Hello! We will start an investigation as soon as possible. Currently our testing machines include Pi 3 B, Pi 3 B+ and Pi 4, and not Pi 5. We will update this thread when we have relevant information. Can you tell us in the meantime whether the AirVPN Suite fails to start? https://airvpn.org/linux/suite/ Kind regards Quote Share this post Link to post
AuContraire 1 Posted ... I have not tried installing AirVPN Suite. I will give that a try today Quote Share this post Link to post
AuContraire 1 Posted ... Which of the AirVPN Suite packages do you suggest I use? The only one that seems specifically for Raspberry is the 32 Bit and I know that the 32 bit version of Eddie will not even install. Quote Share this post Link to post
Staff 10487 Posted ... 21 hours ago, AuContraire said: Which of the AirVPN Suite packages do you suggest I use? The only one that seems specifically for Raspberry is the 32 Bit and I know that the 32 bit version of Eddie will not even install. Hello! Please avoid the 32 bit version. You need the 64 bit version (NOT the legacy version), direct link:https://eddie.website/repository/AirVPN-Suite/1.3.0/AirVPN-Suite-aarch64-1.3.0.tar.gz Kind regards Quote Share this post Link to post
trigonman 0 Posted ... I have the same issue with a Pi 5 and the Eddie client using the default Pi 5 software. Running the experimental V 2.24.1 aarch64 debian version from the terminal I get the error Error mapping file: mono_file_map_error failed file:./eddie-ui length:0x1679000 offset:0x4562944X error:Invalid argument(0x16). Quote Share this post Link to post
AuContraire 1 Posted ... I have been working with AirVPN support to solve this problem. I know they have just acquired a Pi5 for testing and hopefully there will be a patch for Eddie In the meantime they suggested I try AirVPN suite which is the Command Line version of their VPN client. I had problems getting it to run on the Pi5 too but they worked with me to solve the problems and now it works a charm, if you are comfortable with Command Line (I’m middling myself and I muddled through) I prepared for my own reference the following summary of the tweaks required in my instance: Running AirVPN Suite on Pi5 Install AirVPN Suite Please avoid the 32 bit version. You need the 64 bit version (NOT the legacy version), direct link: https://eddie.website/repository/AirVPN-Suite/1.3.0/AirVPN-Suite-aarch64-1.3.0.tar.gz If AirVPN Suite Fails to Resolve DNS Requests DNS requests should not affect system ability to resolve names. Test for successful resolutions. Example from a terminal:dig airvpn.org If the result is a failure then produce the Bluetit log taken while the problem is ongoing. From a terminal:sudo journalctl | grep bluetit > bluetit.log Send to AirVPN support Check if systemd-resolved is running From a terminal: sudo systemctl status systemd-resolved For me this showed that systemd-resolved was not installed on my system. I installed it with: apt install systemd-resolved Reboot and run sudo systemctl status systemd-resolved again This solved my DNS resolution problems 1 derk reacted to this Quote Share this post Link to post
Juggler123 0 Posted ... I have exactly the same issue btw. I had a Pi 4 and it worked fine, now with the Pi 5 it's just a black box. 64bit ofc. I tried a few versions, tried using the mono portable etc. Everything that ran did the same thing. Quote Share this post Link to post
AuContraire 1 Posted ... AirVPN Suite does run on the Pi5 but the installation is potentially non-trivial. I posted notes from my installation in this thread The app is command line driven but good once you get the hang of it Quote Share this post Link to post
Juggler123 0 Posted ... Would love an update on this. I'm CLI for now but would really love the GUI back. Quote Share this post Link to post
AuContraire 1 Posted ... The last I heard they had obtained a pi5 and were working on the bug. I haven’t heard anything further either Quote Share this post Link to post
donsai 0 Posted ... on my pi5 eddie works, i follow the airvpn steps under download raspberry 64bit and eddie works under raspberry os, ubuntu 24.4 and 23.10 and debian bookworm (all 64bit) the only thing connect to recommended server freeze but choose one server always works Quote Share this post Link to post
AuContraire 1 Posted ... Donsai… Perhaps you have a patched version of Eddie. I will try a fresh download Quote Share this post Link to post
OxygenZ 0 Posted ... (edited) Getting the same error on the pi 500 with v2.24.6. Crazy that this still hasn't been fixed On 3/2/2024 at 3:43 AM, trigonman said: I have the same issue with a Pi 5 and the Eddie client using the default Pi 5 software. Running the experimental V 2.24.1 aarch64 debian version from the terminal I get the error Error mapping file: mono_file_map_error failed file:./eddie-ui length:0x1679000 offset:0x4562944X error:Invalid argument(0x16). Edited ... by OxygenZ Quote Share this post Link to post
oxygen4505 0 Posted ... hello, any news ? Did i missed somethings ? I can run cli version, but i would like gui , help Thx Quote Share this post Link to post
WhoisQ 0 Posted ... +1 for this sudo eddie-ui Error mapping file: mono_file_map_error failed file:./eddie-ui Quote Share this post Link to post
oxygen4505 0 Posted ... I took out my Raspberry Pi 4 again and did a fresh install. It's not working for me either, I have a problem with the libtiff library. I installed everything I could find related to libtiff, libtiff-dev, etc., but it's not working Quote Share this post Link to post
oxygen4505 0 Posted ... (edited) ok sudo apt install libtiff6 sudo ln -s /usr/lib/aarch64-linux-gnu/libtiff.so.6 /usr/lib/aarch64-linux-gnu/libtiff.so.5 seems to fix the problem for the raspberry pi 4 but it does not fix the other problem with the raspberry pi 5 😕 Edited ... by oxygen4505 Quote Share this post Link to post
AurelienL 0 Posted ... Any update on this ?? It's been more than a year now and the GUI is still not working with the message : Error mapping file: mono_file_map_error failed file:./eddie-ui length:0x1670000 offset:0x4562944X error:Invalid argument(0x16)... Thanks Quote Share this post Link to post
oxygen4505 0 Posted ... On 11/5/2025 at 6:57 PM, AurelienL said: Any update on this ?? It's been more than a year now and the GUI is still not working with the message : Error mapping file: mono_file_map_error failed file:./eddie-ui length:0x1670000 offset:0x4562944X error:Invalid argument(0x16)... Thanks Personally, I switched to the AirVPN Suite and gave up on Eddie UI on the Raspberry Pi 5. It’s a bit more complicated to set up at first if you’re not familiar with it (especially the network lock, in my case), but otherwise it looks solid and has been running reliably for several months at my place. Quote Share this post Link to post
