JJGGY 0 Posted ... Hello. periodically, the service stops working and freezes at the IPv4 stage. I haven't been able to launch a vpn for a week, please help me. Logs attached below. Thank you! Eddie_20240128_173316.txt Quote Share this post Link to post
Staff 10464 Posted ... Hello! The following errors: Quote . 2024.01.28 17:28:04 - OpenVPN > write UDP: Unknown error (code=10065) . 2024.01.28 17:28:04 - OpenVPN > write UDP: Unknown error (code=10065) . 2024.01.28 17:28:04 - OpenVPN > write UDP: Unknown error (code=10065) . 2024.01.28 17:28:04 - Above log line repeated 57 times more hint to an UDP block. Please check any packet filtering tool both on your router and system and make sure that no UDP block is enforced. If you find nothing blocking, it is possible that your ISP is the culprit. Maybe the block is against OpenVPN and not against UDP. To discern, please try a different connection mode: from Eddie's main window please select "Preferences" > "Protocols" uncheck "Automatic" select any line with WireGuard. The line will be highlighted. click "Save" and re-start a connection to apply the change please make sure to test a few servers in different locations around your node If the above connection mode fails too, please try the following, different connection mode: from Eddie's main window please select "Preferences" > "Protocols" uncheck "Automatic" select the line with OpenVPN, port 443, protocol TCP, entry-IP address 3 (three) click "Save" and re-start a connection to apply the change please make sure to test a few servers in different locations around your node Kind regards Quote Share this post Link to post
