Not connected, Your IP: 216.73.216.28
Sceptrum
ANSWERED Acces denied when trying to connect
I'm getting an IService> OpenThreadToken Acces Denied message in the OpenVPN client, when I try to connect. What is the issue? Am I banned? As far as I'm concerned, I haven't violated any known terms.
Just for a definitive confirmation, your account is not banned and has no limitations whatsoever. It must be a local problem. In the following thread, two users with this problem found out that it was caused by BitDefender:
https://forums.openvpn.net/viewtopic.php?p=120189
Can you check, if you run BitDefender?
Yes, I use that one. I'm gonna report this to them, I presume this is an issue on their end. Thanks for the quick response, I swear I was trying to google it, but probably I missed it somehow.
