Boindil 0 Posted ... Hi, I have downloaded and installed the latest version of eddie-ui for Fedora. However, there are DNS leaks when using Airvpn. Is there any way for me to stop the leaks in the official version? The experimental version runs without leaks. Can I use this for myself, or is it not recommended? Share this post Link to post
Staff 10478 Posted ... Hello! Latest Eddie 2.23.2 has been tested publicly for such a long time that we would say that you can safely run it. If you prefer to stay with 2.21.8 then you can consider to disable systemd-resolved which is the cause of the leaks you mention when it works in on-link mode bypassing resolv.conf file. While Eddie 2.23 and the AirVPN Suite for Linux offer full support with proper DNS management for every systemd-resolved working mode, Eddie 2.21 doesn't. Kind regards Share this post Link to post
