Guest rbj
Strange ping (at least to me)
Guest rbj
I'm pretty sure this isn't right, but I don't know what if anything I should do about it:
rbj@misty:~$ ping 212.118.180.25
PING 212.118.180.25 (212.118.180.25) 56(84) bytes of data.
From 212.9.160.65 icmp_seq=1 Time to live exceeded
From 212.9.160.65 icmp_seq=2 Time to live exceeded
From 212.9.160.65 icmp_seq=3 Time to live exceeded
It seems there are some intermittent connectivity/routing/packet loss problems on the frontend you're pinging. We'll keep an eye on it. In the moment of writing the issue seems resolved.
If you can't access that frontend, switch to the second:
85.17.207.151 airvpn.org
Guest rbj
Still have same problem on two machines.
And what is: 212.9.160.65 ? Why am I getting switched to a German site?
Also how do I use the 2nd ip? Where does it go?
Thank you much.
Thank you much.
The correct IP is 212.117.180.25.
Try to ping it. Previous problems should be resolved now.
In order to access the alternative frontend please insert in your hosts file:
Make sure it is the only entry pertaining to airvpn.org.
Guest rbj
I had written down the wrong number as you pointed out. Guess I truly wasn't awake yet. I'm so sorry for the trouble I caused. Pinging AirVPN is working fine once I entered the correct address.
Thank you so much and I apologize once more..
