loganj
Safe and Secure E-mail Recommendation
Under the AirVPN TOPIC: Important notice about security, AirVPN posted:
"3) If/when you need to communicate with us, always use a secure and safe e-mail account which can't be used to reveal your identity. In this way you can buy an account via Bitcoin or LibertyReserve by directly asking to us."
What e-mail service does AirVPN consider to be a "secure and safe e-mail account which can't be used to reveal your identity"?
Thank you
Thank you
With some precautions you have plenty of choices. Pay attention to access your mail provider (either it has a mail-to-www wrapper or direct access to SMTP and POP3/IMAP servers) always when you're behind the VPN or behind TOR (in this case remember to tunnel your mail client over TOR) and never use that account with e-mail whose content can disclose your identity.
Pick a provider that provides access either to https web mail wrappers or to SMTP and POP3/IMAP over TLS.
We recommend gpg usage as well.
http://www.gnupg.org/
A/I (Autistici Inventati) have quite a good reputation as free, privacy aware mail provider:
http://www.autistici.org/en
