weelilbit 0 Posted ... I cannot for the life of me get a connection with actual speeds lasting longer than a few seconds. I've tried different countries, different servers, and even blundered about to see if it's my port-forwarding (I definitely do not understand a lot about the tech behind any of this, hence that attempt), but nothing provides a solution. My up/down will spike to some relatively low number, then bottom out. Speed tests without the VPN on were fine. CanYouSeeMe says "Connection refused". Eddie System/Environment Report - 12/20/2023 - 4:54 AM UTC Eddie version: 2.21.8 Eddie OS build: macos_x64 Eddie architecture: x64 OS type: MacOS OS name: macOS 12.7.2 OS version: 12.7.2 (Build 21G1974) OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN: 2.5.5 - OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn) Hummingbird: 3.3.2 - Hummingbird - AirVPN OpenVPN 3 Client 1.2.0 - 22 March 2022 (/Applications/Eddie.app/Contents/MacOS/hummingbird) WireGuard: 1.0.20200827 SSH: OpenSSH_8.6p1, LibreSSL 3.3.6 (/usr/bin/ssh) SSL: stunnel 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel) Profile path: /Users/Corinne/.config/eddie/default.profile Data path: /Users/Corinne/.config/eddie Application path: /Applications/Eddie.app/Contents/MacOS Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie Command line arguments: (0 args) Network Lock Active: No Connected to VPN: No OS support IPv4: Yes OS support IPv6: Yes Detected DNS: 192.168.1.1 Test DNS IPv4: Ok Test DNS IPv6: Failed Test Ping IPv4: 91 ms Test Ping IPv6: Failed Test HTTP IPv4: Ok Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True mode.type: openvpn mode.protocol: UDP ---------------------------- Logs: . 2023.12.19 22:02:36 - Eddie version: 2.21.8 / macos_x64, System: MacOS, Name: macOS 12.7.2, Version: 12.7.2 (Build 21G1974), Mono/.Net: v4.0.30319 . 2023.12.19 22:02:37 - Raise system privileges . 2023.12.19 22:02:52 - Reading options from /Users/Corinne/.config/eddie/default.profile . 2023.12.19 22:02:57 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn) . 2023.12.19 22:02:57 - SSH - Version: OpenSSH_8.6p1, LibreSSL 3.3.6 (/usr/bin/ssh) . 2023.12.19 22:02:57 - SSL - Version: stunnel 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel) I 2023.12.19 22:02:57 - Ready . 2023.12.19 22:02:58 - Collect information about AirVPN completed I 2023.12.19 22:03:03 - Session starting. I 2023.12.19 22:03:03 - Checking authorization ... ! 2023.12.19 22:03:04 - Connecting to Norma (Sweden, Stockholm) . 2023.12.19 22:03:04 - Routes, add 31.3.152.102/32 for interface "en1". . 2023.12.19 22:03:04 - Routes, add 31.3.152.102/32 for interface "en1", already exists. . 2023.12.19 22:03:04 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 22:03:04 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 22:03:04 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:03:04 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:03:04 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:03:04 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:03:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]31.3.152.102:443 . 2023.12.19 22:03:04 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 22:03:04 - OpenVPN > UDP link local: (not bound) . 2023.12.19 22:03:04 - OpenVPN > UDP link remote: [AF_INET]31.3.152.102:443 . 2023.12.19 22:03:04 - OpenVPN > TLS: Initial packet from [AF_INET]31.3.152.102:443, sid=1c0ee47a a1cbb074 . 2023.12.19 22:03:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 22:03:04 - OpenVPN > VERIFY KU OK . 2023.12.19 22:03:04 - OpenVPN > Validating certificate extended key usage . 2023.12.19 22:03:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 22:03:04 - OpenVPN > VERIFY EKU OK . 2023.12.19 22:03:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Norma, emailAddress=info@airvpn.org . 2023.12.19 22:03:04 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 22:03:04 - OpenVPN > [Norma] Peer Connection Initiated with [AF_INET]31.3.152.102:443 . 2023.12.19 22:03:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.70.1,dhcp-option DNS6 fde6:7a:7d20:1546::1,tun-ipv6,route-gateway 10.25.70.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1546::10bd/64 fde6:7a:7d20:1546::1,ifconfig 10.25.70.191 255.255.255.0,peer-id 13,cipher AES-256-GCM' . 2023.12.19 22:03:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 22:03:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.25.70.1' . 2023.12.19 22:03:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1546::1' . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 22:03:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 22:03:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 22:03:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:03:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:03:04 - OpenVPN > Opened utun device utun3 . 2023.12.19 22:03:04 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 22:03:05 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 22:03:05 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 22:03:05 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 22:03:05 - OpenVPN > /sbin/ifconfig utun3 10.25.70.191 10.25.70.191 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 22:03:05 - OpenVPN > /sbin/route add -net 10.25.70.0 10.25.70.191 255.255.255.0 . 2023.12.19 22:03:05 - OpenVPN > add net 10.25.70.0: gateway 10.25.70.191 . 2023.12.19 22:03:05 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1546::10bd/64 mtu 1500 up . 2023.12.19 22:03:05 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1546::/64 -> fde6:7a:7d20:1546::10bd metric 0) dev utun3 . 2023.12.19 22:03:05 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1546:: -prefixlen 64 -iface utun3 . 2023.12.19 22:03:05 - OpenVPN > add net fde6:7a:7d20:1546::: gateway utun3: File exists . 2023.12.19 22:03:05 - OpenVPN > Initialization Sequence Completed . 2023.12.19 22:03:05 - DNS of a network adapter forced (Ethernet, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:03:05 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:03:05 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:03:05 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:03:05 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 22:03:05 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 22:03:05 - Routes, add ::/1 for interface "utun3". . 2023.12.19 22:03:05 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 22:03:05 - Routes, add 31.3.152.100/32 for interface "utun3". . 2023.12.19 22:03:05 - Routes, add 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3". . 2023.12.19 22:03:05 - Flushing DNS I 2023.12.19 22:03:05 - Checking route IPv4 I 2023.12.19 22:03:06 - Checking route IPv6 I 2023.12.19 22:03:07 - Checking DNS ! 2023.12.19 22:03:08 - Connected. ! 2023.12.19 22:13:11 - Disconnecting . 2023.12.19 22:13:11 - Sending soft termination signal . 2023.12.19 22:13:11 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 22:13:11 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 22:13:16 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 22:13:16 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1546::10bd . 2023.12.19 22:13:16 - OpenVPN > delete host fde6:7a:7d20:1546::10bd . 2023.12.19 22:13:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 22:13:17 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:13:17 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:13:17 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 22:13:17 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 22:13:17 - Routes, delete 31.3.152.102/32 for interface "en1". . 2023.12.19 22:13:17 - Routes, delete 31.3.152.100/32 for interface "utun3", not exists. . 2023.12.19 22:13:17 - Routes, delete 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3", not exists. . 2023.12.19 22:13:17 - Routes, delete 31.3.152.102/32 for interface "en1", not exists. . 2023.12.19 22:13:17 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 22:13:17 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 22:13:17 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 22:13:17 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 22:13:17 - Connection terminated. . 2023.12.19 22:13:17 - Flushing DNS ! 2023.12.19 22:13:17 - Session terminated. I 2023.12.19 22:14:40 - Session starting. I 2023.12.19 22:14:40 - Checking authorization ... ! 2023.12.19 22:14:40 - Connecting to Norma (Sweden, Stockholm) . 2023.12.19 22:14:40 - Routes, add 31.3.152.102/32 for interface "en1". . 2023.12.19 22:14:41 - Routes, add 31.3.152.102/32 for interface "en1", already exists. . 2023.12.19 22:14:41 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 22:14:41 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 22:14:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:14:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:14:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:14:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:14:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]31.3.152.102:443 . 2023.12.19 22:14:41 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 22:14:41 - OpenVPN > UDP link local: (not bound) . 2023.12.19 22:14:41 - OpenVPN > UDP link remote: [AF_INET]31.3.152.102:443 . 2023.12.19 22:14:41 - OpenVPN > TLS: Initial packet from [AF_INET]31.3.152.102:443, sid=70831268 59c26c06 . 2023.12.19 22:14:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 22:14:41 - OpenVPN > VERIFY KU OK . 2023.12.19 22:14:41 - OpenVPN > Validating certificate extended key usage . 2023.12.19 22:14:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 22:14:41 - OpenVPN > VERIFY EKU OK . 2023.12.19 22:14:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Norma, emailAddress=info@airvpn.org . 2023.12.19 22:14:41 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 22:14:41 - OpenVPN > [Norma] Peer Connection Initiated with [AF_INET]31.3.152.102:443 . 2023.12.19 22:14:41 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 22:14:41 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 22:14:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.70.1,dhcp-option DNS6 fde6:7a:7d20:1546::1,tun-ipv6,route-gateway 10.25.70.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1546::10bd/64 fde6:7a:7d20:1546::1,ifconfig 10.25.70.191 255.255.255.0,peer-id 20,cipher AES-256-GCM' . 2023.12.19 22:14:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 22:14:41 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.25.70.1' . 2023.12.19 22:14:41 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1546::1' . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 22:14:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 22:14:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 22:14:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:14:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:14:41 - OpenVPN > Opened utun device utun3 . 2023.12.19 22:14:41 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 22:14:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 22:14:41 - OpenVPN > /sbin/ifconfig utun3 10.25.70.191 10.25.70.191 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 22:14:41 - OpenVPN > /sbin/route add -net 10.25.70.0 10.25.70.191 255.255.255.0 . 2023.12.19 22:14:41 - OpenVPN > add net 10.25.70.0: gateway 10.25.70.191 . 2023.12.19 22:14:41 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1546::10bd/64 mtu 1500 up . 2023.12.19 22:14:41 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1546::/64 -> fde6:7a:7d20:1546::10bd metric 0) dev utun3 . 2023.12.19 22:14:41 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1546:: -prefixlen 64 -iface utun3 . 2023.12.19 22:14:41 - OpenVPN > add net fde6:7a:7d20:1546::: gateway utun3: File exists . 2023.12.19 22:14:41 - OpenVPN > Initialization Sequence Completed . 2023.12.19 22:14:42 - DNS of a network adapter forced (Ethernet, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:14:42 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:14:42 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:14:42 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:14:42 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 22:14:42 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 22:14:42 - Routes, add ::/1 for interface "utun3". . 2023.12.19 22:14:42 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 22:14:42 - Routes, add 31.3.152.100/32 for interface "utun3". . 2023.12.19 22:14:42 - Routes, add 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3". . 2023.12.19 22:14:42 - Flushing DNS I 2023.12.19 22:14:42 - Checking route IPv4 I 2023.12.19 22:14:42 - Checking route IPv6 I 2023.12.19 22:14:44 - Checking DNS ! 2023.12.19 22:14:45 - Connected. ! 2023.12.19 22:18:17 - Disconnecting . 2023.12.19 22:18:17 - Sending soft termination signal . 2023.12.19 22:18:17 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 22:18:17 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 22:18:22 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 22:18:22 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1546::10bd . 2023.12.19 22:18:22 - OpenVPN > delete host fde6:7a:7d20:1546::10bd . 2023.12.19 22:18:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 22:18:22 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:18:22 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:18:22 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 22:18:22 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 22:18:22 - Routes, delete 31.3.152.102/32 for interface "en1". . 2023.12.19 22:18:22 - Routes, delete 31.3.152.100/32 for interface "utun3", not exists. . 2023.12.19 22:18:22 - Routes, delete 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3", not exists. . 2023.12.19 22:18:22 - Routes, delete 31.3.152.102/32 for interface "en1", not exists. . 2023.12.19 22:18:22 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 22:18:22 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 22:18:22 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 22:18:22 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 22:18:22 - Connection terminated. . 2023.12.19 22:18:22 - Flushing DNS ! 2023.12.19 22:18:23 - Session terminated. I 2023.12.19 22:18:52 - Session starting. I 2023.12.19 22:18:52 - Checking authorization ... ! 2023.12.19 22:18:53 - Connecting to Norma (Sweden, Stockholm) . 2023.12.19 22:18:53 - Routes, add 31.3.152.102/32 for interface "en1". . 2023.12.19 22:18:53 - Routes, add 31.3.152.102/32 for interface "en1", already exists. . 2023.12.19 22:18:53 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 22:18:53 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 22:18:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:18:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:18:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:18:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:18:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]31.3.152.102:443 . 2023.12.19 22:18:53 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 22:18:53 - OpenVPN > UDP link local: (not bound) . 2023.12.19 22:18:53 - OpenVPN > UDP link remote: [AF_INET]31.3.152.102:443 . 2023.12.19 22:18:53 - OpenVPN > TLS: Initial packet from [AF_INET]31.3.152.102:443, sid=d36824eb 1fe83cfe . 2023.12.19 22:18:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 22:18:53 - OpenVPN > VERIFY KU OK . 2023.12.19 22:18:53 - OpenVPN > Validating certificate extended key usage . 2023.12.19 22:18:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 22:18:53 - OpenVPN > VERIFY EKU OK . 2023.12.19 22:18:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Norma, emailAddress=info@airvpn.org . 2023.12.19 22:18:53 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 22:18:53 - OpenVPN > [Norma] Peer Connection Initiated with [AF_INET]31.3.152.102:443 . 2023.12.19 22:18:54 - OpenVPN > SENT CONTROL [Norma]: 'PUSH_REQUEST' (status=1) . 2023.12.19 22:18:56 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 22:18:56 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 22:18:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.70.1,dhcp-option DNS6 fde6:7a:7d20:1546::1,tun-ipv6,route-gateway 10.25.70.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1546::10bd/64 fde6:7a:7d20:1546::1,ifconfig 10.25.70.191 255.255.255.0,peer-id 13,cipher AES-256-GCM' . 2023.12.19 22:18:56 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 22:18:56 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.25.70.1' . 2023.12.19 22:18:56 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1546::1' . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 22:18:56 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 22:18:56 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 22:18:56 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:18:56 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:18:56 - OpenVPN > Opened utun device utun3 . 2023.12.19 22:18:56 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 22:18:56 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 22:18:56 - OpenVPN > /sbin/ifconfig utun3 10.25.70.191 10.25.70.191 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 22:18:56 - OpenVPN > /sbin/route add -net 10.25.70.0 10.25.70.191 255.255.255.0 . 2023.12.19 22:18:56 - OpenVPN > add net 10.25.70.0: gateway 10.25.70.191 . 2023.12.19 22:18:56 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1546::10bd/64 mtu 1500 up . 2023.12.19 22:18:56 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1546::/64 -> fde6:7a:7d20:1546::10bd metric 0) dev utun3 . 2023.12.19 22:18:56 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1546:: -prefixlen 64 -iface utun3 . 2023.12.19 22:18:56 - OpenVPN > add net fde6:7a:7d20:1546::: gateway utun3: File exists . 2023.12.19 22:18:56 - OpenVPN > Initialization Sequence Completed . 2023.12.19 22:18:56 - DNS of a network adapter forced (Ethernet, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:18:56 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:18:56 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:18:56 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.25.70.1, fde6:7a:7d20:1546::1) . 2023.12.19 22:18:56 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 22:18:56 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 22:18:56 - Routes, add ::/1 for interface "utun3". . 2023.12.19 22:18:56 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 22:18:56 - Routes, add 31.3.152.100/32 for interface "utun3". . 2023.12.19 22:18:56 - Routes, add 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3". . 2023.12.19 22:18:56 - Flushing DNS I 2023.12.19 22:18:56 - Checking route IPv4 I 2023.12.19 22:18:57 - Checking route IPv6 I 2023.12.19 22:18:58 - Checking DNS ! 2023.12.19 22:18:59 - Connected. ! 2023.12.19 22:19:08 - Disconnecting . 2023.12.19 22:19:08 - Sending soft termination signal . 2023.12.19 22:19:08 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 22:19:08 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 22:19:13 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 22:19:13 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1546::10bd . 2023.12.19 22:19:13 - OpenVPN > delete host fde6:7a:7d20:1546::10bd . 2023.12.19 22:19:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 22:19:14 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:19:14 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:19:14 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 22:19:14 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 22:19:14 - Routes, delete 31.3.152.102/32 for interface "en1". . 2023.12.19 22:19:14 - Routes, delete 31.3.152.100/32 for interface "utun3", not exists. . 2023.12.19 22:19:14 - Routes, delete 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3", not exists. . 2023.12.19 22:19:14 - Routes, delete 31.3.152.102/32 for interface "en1", not exists. . 2023.12.19 22:19:14 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 22:19:14 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 22:19:14 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 22:19:14 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 22:19:14 - Connection terminated. . 2023.12.19 22:19:14 - Flushing DNS ! 2023.12.19 22:19:14 - Session terminated. I 2023.12.19 22:19:17 - Session starting. I 2023.12.19 22:19:17 - Checking authorization ... ! 2023.12.19 22:19:18 - Connecting to Lupus (Sweden, Stockholm) . 2023.12.19 22:19:18 - Routes, add 128.127.105.186/32 for interface "en1". . 2023.12.19 22:19:18 - Routes, add 128.127.105.186/32 for interface "en1", already exists. . 2023.12.19 22:19:18 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 22:19:18 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 22:19:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:19:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:19:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:19:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:19:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]128.127.105.186:443 . 2023.12.19 22:19:18 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 22:19:18 - OpenVPN > UDP link local: (not bound) . 2023.12.19 22:19:18 - OpenVPN > UDP link remote: [AF_INET]128.127.105.186:443 . 2023.12.19 22:19:18 - OpenVPN > TLS: Initial packet from [AF_INET]128.127.105.186:443, sid=222a8fdc 9ab08eac . 2023.12.19 22:19:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 22:19:18 - OpenVPN > VERIFY KU OK . 2023.12.19 22:19:18 - OpenVPN > Validating certificate extended key usage . 2023.12.19 22:19:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 22:19:18 - OpenVPN > VERIFY EKU OK . 2023.12.19 22:19:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Lupus, emailAddress=info@airvpn.org . 2023.12.19 22:19:18 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 22:19:18 - OpenVPN > [Lupus] Peer Connection Initiated with [AF_INET]128.127.105.186:443 . 2023.12.19 22:19:19 - OpenVPN > SENT CONTROL [Lupus]: 'PUSH_REQUEST' (status=1) . 2023.12.19 22:19:21 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 22:19:21 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 22:19:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.166.1,dhcp-option DNS6 fde6:7a:7d20:13a6::1,tun-ipv6,route-gateway 10.23.166.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:13a6::1066/64 fde6:7a:7d20:13a6::1,ifconfig 10.23.166.104 255.255.255.0,peer-id 13,cipher AES-256-GCM' . 2023.12.19 22:19:21 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 22:19:21 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.23.166.1' . 2023.12.19 22:19:21 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:13a6::1' . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 22:19:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 22:19:21 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 22:19:21 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:19:21 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:19:21 - OpenVPN > Opened utun device utun3 . 2023.12.19 22:19:21 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 22:19:21 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 22:19:21 - OpenVPN > /sbin/ifconfig utun3 10.23.166.104 10.23.166.104 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 22:19:21 - OpenVPN > /sbin/route add -net 10.23.166.0 10.23.166.104 255.255.255.0 . 2023.12.19 22:19:21 - OpenVPN > add net 10.23.166.0: gateway 10.23.166.104 . 2023.12.19 22:19:21 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:13a6::1066/64 mtu 1500 up . 2023.12.19 22:19:21 - OpenVPN > add_route_ipv6(fde6:7a:7d20:13a6::/64 -> fde6:7a:7d20:13a6::1066 metric 0) dev utun3 . 2023.12.19 22:19:21 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:13a6:: -prefixlen 64 -iface utun3 . 2023.12.19 22:19:21 - OpenVPN > add net fde6:7a:7d20:13a6::: gateway utun3: File exists . 2023.12.19 22:19:21 - OpenVPN > Initialization Sequence Completed . 2023.12.19 22:19:21 - DNS of a network adapter forced (Ethernet, from Automatic to 10.23.166.1, fde6:7a:7d20:13a6::1) . 2023.12.19 22:19:21 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.23.166.1, fde6:7a:7d20:13a6::1) . 2023.12.19 22:19:21 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.23.166.1, fde6:7a:7d20:13a6::1) . 2023.12.19 22:19:21 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.23.166.1, fde6:7a:7d20:13a6::1) . 2023.12.19 22:19:21 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 22:19:21 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 22:19:21 - Routes, add ::/1 for interface "utun3". . 2023.12.19 22:19:21 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 22:19:21 - Routes, add 128.127.105.184/32 for interface "utun3". . 2023.12.19 22:19:21 - Routes, add 2a00:7142:2c:56ee:f0d1:6384:9c2e:a497/128 for interface "utun3". . 2023.12.19 22:19:21 - Flushing DNS I 2023.12.19 22:19:22 - Checking route IPv4 I 2023.12.19 22:19:22 - Checking route IPv6 I 2023.12.19 22:19:23 - Checking DNS ! 2023.12.19 22:19:24 - Connected. ! 2023.12.19 22:21:34 - Disconnecting . 2023.12.19 22:21:34 - Sending soft termination signal . 2023.12.19 22:21:34 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 22:21:34 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 22:21:39 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 22:21:39 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:13a6::1066 . 2023.12.19 22:21:39 - OpenVPN > delete host fde6:7a:7d20:13a6::1066 . 2023.12.19 22:21:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 22:21:39 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:21:39 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:21:39 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 22:21:39 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 22:21:39 - Routes, delete 128.127.105.186/32 for interface "en1". . 2023.12.19 22:21:39 - Routes, delete 128.127.105.184/32 for interface "utun3", not exists. . 2023.12.19 22:21:39 - Routes, delete 2a00:7142:2c:56ee:f0d1:6384:9c2e:a497/128 for interface "utun3", not exists. . 2023.12.19 22:21:40 - Routes, delete 128.127.105.186/32 for interface "en1", not exists. . 2023.12.19 22:21:40 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 22:21:40 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 22:21:40 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 22:21:40 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 22:21:40 - Connection terminated. . 2023.12.19 22:21:40 - Flushing DNS ! 2023.12.19 22:21:40 - Session terminated. I 2023.12.19 22:22:38 - Session starting. . 2023.12.19 22:22:38 - Waiting for latency tests (117 to go) I 2023.12.19 22:22:40 - Checking authorization ... ! 2023.12.19 22:22:40 - Connecting to Tyl (Canada, Toronto, Ontario) . 2023.12.19 22:22:41 - Routes, add 184.75.223.205/32 for interface "en1". . 2023.12.19 22:22:41 - Routes, add 184.75.223.205/32 for interface "en1", already exists. . 2023.12.19 22:22:41 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 22:22:41 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 22:22:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:22:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:22:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.19 22:22:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.19 22:22:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.205:443 . 2023.12.19 22:22:41 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 22:22:41 - OpenVPN > UDP link local: (not bound) . 2023.12.19 22:22:41 - OpenVPN > UDP link remote: [AF_INET]184.75.223.205:443 . 2023.12.19 22:22:41 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.205:443, sid=2869ceae d6ce322b . 2023.12.19 22:22:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 22:22:41 - OpenVPN > VERIFY KU OK . 2023.12.19 22:22:41 - OpenVPN > Validating certificate extended key usage . 2023.12.19 22:22:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 22:22:41 - OpenVPN > VERIFY EKU OK . 2023.12.19 22:22:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org . 2023.12.19 22:22:41 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 22:22:41 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.205:443 . 2023.12.19 22:22:41 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 22:22:41 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 22:22:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.198.1,dhcp-option DNS6 fde6:7a:7d20:1bc6::1,tun-ipv6,route-gateway 10.31.198.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1bc6::102d/64 fde6:7a:7d20:1bc6::1,ifconfig 10.31.198.47 255.255.255.0,peer-id 9,cipher AES-256-GCM' . 2023.12.19 22:22:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 22:22:41 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.31.198.1' . 2023.12.19 22:22:41 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1bc6::1' . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 22:22:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 22:22:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 22:22:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:22:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:22:41 - OpenVPN > Opened utun device utun3 . 2023.12.19 22:22:41 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 22:22:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 22:22:41 - OpenVPN > /sbin/ifconfig utun3 10.31.198.47 10.31.198.47 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 22:22:41 - OpenVPN > /sbin/route add -net 10.31.198.0 10.31.198.47 255.255.255.0 . 2023.12.19 22:22:41 - OpenVPN > add net 10.31.198.0: gateway 10.31.198.47 . 2023.12.19 22:22:41 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1bc6::102d/64 mtu 1500 up . 2023.12.19 22:22:41 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1bc6::/64 -> fde6:7a:7d20:1bc6::102d metric 0) dev utun3 . 2023.12.19 22:22:41 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1bc6:: -prefixlen 64 -iface utun3 . 2023.12.19 22:22:41 - OpenVPN > add net fde6:7a:7d20:1bc6::: gateway utun3: File exists . 2023.12.19 22:22:41 - OpenVPN > Initialization Sequence Completed . 2023.12.19 22:22:42 - DNS of a network adapter forced (Ethernet, from Automatic to 10.31.198.1, fde6:7a:7d20:1bc6::1) . 2023.12.19 22:22:42 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.31.198.1, fde6:7a:7d20:1bc6::1) . 2023.12.19 22:22:42 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.31.198.1, fde6:7a:7d20:1bc6::1) . 2023.12.19 22:22:42 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.31.198.1, fde6:7a:7d20:1bc6::1) . 2023.12.19 22:22:42 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 22:22:42 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 22:22:42 - Routes, add ::/1 for interface "utun3". . 2023.12.19 22:22:42 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 22:22:42 - Routes, add 184.75.223.203/32 for interface "utun3". . 2023.12.19 22:22:42 - Routes, add 2606:6080:1002:5:a1ba:b510:7908:829e/128 for interface "utun3". . 2023.12.19 22:22:42 - Flushing DNS I 2023.12.19 22:22:42 - Checking route IPv4 I 2023.12.19 22:22:42 - Checking route IPv6 I 2023.12.19 22:22:43 - Checking DNS ! 2023.12.19 22:22:43 - Connected. ! 2023.12.19 22:32:43 - Disconnecting . 2023.12.19 22:32:43 - Sending soft termination signal . 2023.12.19 22:32:43 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 22:32:43 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 22:32:48 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 22:32:48 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1bc6::102d . 2023.12.19 22:32:48 - OpenVPN > delete host fde6:7a:7d20:1bc6::102d . 2023.12.19 22:32:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 22:32:48 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:32:48 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 22:32:48 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 22:32:48 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 22:32:49 - Routes, delete 184.75.223.205/32 for interface "en1". . 2023.12.19 22:32:49 - Routes, delete 184.75.223.203/32 for interface "utun3", not exists. . 2023.12.19 22:32:49 - Routes, delete 2606:6080:1002:5:a1ba:b510:7908:829e/128 for interface "utun3", not exists. . 2023.12.19 22:32:49 - Routes, delete 184.75.223.205/32 for interface "en1", not exists. . 2023.12.19 22:32:49 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 22:32:49 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 22:32:49 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 22:32:49 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 22:32:49 - Connection terminated. . 2023.12.19 22:32:49 - Flushing DNS ! 2023.12.19 22:32:49 - Session terminated. I 2023.12.19 22:32:50 - Session starting. I 2023.12.19 22:32:50 - Checking authorization ... ! 2023.12.19 22:32:51 - Connecting to Wurren (Canada, Toronto, Ontario) . 2023.12.19 22:32:51 - Routes, add 199.189.27.122/32 for interface "en1". . 2023.12.19 22:32:51 - Routes, add 199.189.27.122/32 for interface "en1", already exists. . 2023.12.19 22:32:51 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 22:32:51 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 22:32:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 22:32:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 22:32:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.189.27.122:443 . 2023.12.19 22:32:51 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 22:32:51 - OpenVPN > UDP link local: (not bound) . 2023.12.19 22:32:51 - OpenVPN > UDP link remote: [AF_INET]199.189.27.122:443 . 2023.12.19 22:32:51 - OpenVPN > TLS: Initial packet from [AF_INET]199.189.27.122:443, sid=518391b6 b6c83cde . 2023.12.19 22:32:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 22:32:51 - OpenVPN > VERIFY KU OK . 2023.12.19 22:32:51 - OpenVPN > Validating certificate extended key usage . 2023.12.19 22:32:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 22:32:51 - OpenVPN > VERIFY EKU OK . 2023.12.19 22:32:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wurren, emailAddress=info@airvpn.org . 2023.12.19 22:32:51 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 22:32:51 - OpenVPN > [Wurren] Peer Connection Initiated with [AF_INET]199.189.27.122:443 . 2023.12.19 22:32:52 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 22:32:52 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 22:32:52 - OpenVPN > SENT CONTROL [Wurren]: 'PUSH_REQUEST' (status=1) . 2023.12.19 22:32:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.196.1,dhcp-option DNS6 fde6:7a:7d20:5c4::1,tun-ipv6,route-gateway 10.9.196.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:5c4::106a/64 fde6:7a:7d20:5c4::1,ifconfig 10.9.196.108 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2023.12.19 22:32:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 22:32:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.9.196.1' . 2023.12.19 22:32:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:5c4::1' . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 22:32:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 22:32:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 22:32:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:32:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 22:32:52 - OpenVPN > Opened utun device utun3 . 2023.12.19 22:32:52 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 22:32:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 22:32:52 - OpenVPN > /sbin/ifconfig utun3 10.9.196.108 10.9.196.108 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 22:32:52 - OpenVPN > /sbin/route add -net 10.9.196.0 10.9.196.108 255.255.255.0 . 2023.12.19 22:32:52 - OpenVPN > add net 10.9.196.0: gateway 10.9.196.108 . 2023.12.19 22:32:52 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:5c4::106a/64 mtu 1500 up . 2023.12.19 22:32:52 - OpenVPN > add_route_ipv6(fde6:7a:7d20:5c4::/64 -> fde6:7a:7d20:5c4::106a metric 0) dev utun3 . 2023.12.19 22:32:52 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:5c4:: -prefixlen 64 -iface utun3 . 2023.12.19 22:32:52 - OpenVPN > add net fde6:7a:7d20:5c4::: gateway utun3: File exists . 2023.12.19 22:32:52 - OpenVPN > Initialization Sequence Completed . 2023.12.19 22:32:52 - DNS of a network adapter forced (Ethernet, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 22:32:52 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 22:32:52 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 22:32:52 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 22:32:52 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 22:32:52 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 22:32:52 - Routes, add ::/1 for interface "utun3". . 2023.12.19 22:32:52 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 22:32:53 - Routes, add 199.189.27.123/32 for interface "utun3". . 2023.12.19 22:32:53 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun3". . 2023.12.19 22:32:53 - Flushing DNS I 2023.12.19 22:32:53 - Checking route IPv4 I 2023.12.19 22:32:53 - Checking route IPv6 I 2023.12.19 22:32:54 - Checking DNS ! 2023.12.19 22:32:54 - Connected. . 2023.12.19 22:33:00 - Collect information about AirVPN completed . 2023.12.19 23:03:04 - Collect information about AirVPN completed . 2023.12.19 23:29:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 23:29:55 - OpenVPN > VERIFY KU OK . 2023.12.19 23:29:55 - OpenVPN > Validating certificate extended key usage . 2023.12.19 23:29:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 23:29:55 - OpenVPN > VERIFY EKU OK . 2023.12.19 23:29:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wurren, emailAddress=info@airvpn.org . 2023.12.19 23:29:55 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:29:55 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:29:55 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 23:33:18 - Collect information about AirVPN completed ! 2023.12.19 23:40:09 - Disconnecting . 2023.12.19 23:40:09 - Sending soft termination signal . 2023.12.19 23:40:09 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 23:40:09 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 23:40:14 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 23:40:14 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:5c4::106a . 2023.12.19 23:40:14 - OpenVPN > delete host fde6:7a:7d20:5c4::106a . 2023.12.19 23:40:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 23:40:14 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:40:14 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:40:14 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 23:40:14 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 23:40:14 - Routes, delete 199.189.27.122/32 for interface "en1". . 2023.12.19 23:40:14 - Routes, delete 199.189.27.123/32 for interface "utun3", not exists. . 2023.12.19 23:40:14 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun3", not exists. . 2023.12.19 23:40:14 - Routes, delete 199.189.27.122/32 for interface "en1", not exists. . 2023.12.19 23:40:14 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 23:40:14 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 23:40:14 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 23:40:14 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 23:40:14 - Connection terminated. . 2023.12.19 23:40:14 - Flushing DNS ! 2023.12.19 23:40:14 - Session terminated. I 2023.12.19 23:45:04 - Session starting. I 2023.12.19 23:45:04 - Checking authorization ... ! 2023.12.19 23:45:05 - Connecting to Wurren (Canada, Toronto, Ontario) . 2023.12.19 23:45:05 - Routes, add 199.189.27.122/32 for interface "en1". . 2023.12.19 23:45:05 - Routes, add 199.189.27.122/32 for interface "en1", already exists. . 2023.12.19 23:45:05 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 23:45:05 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 23:45:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 23:45:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 23:45:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.189.27.122:443 . 2023.12.19 23:45:05 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 23:45:05 - OpenVPN > UDP link local: (not bound) . 2023.12.19 23:45:05 - OpenVPN > UDP link remote: [AF_INET]199.189.27.122:443 . 2023.12.19 23:45:05 - OpenVPN > TLS: Initial packet from [AF_INET]199.189.27.122:443, sid=6009c2a7 39eb5873 . 2023.12.19 23:45:05 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 23:45:05 - OpenVPN > VERIFY KU OK . 2023.12.19 23:45:05 - OpenVPN > Validating certificate extended key usage . 2023.12.19 23:45:05 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 23:45:05 - OpenVPN > VERIFY EKU OK . 2023.12.19 23:45:05 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wurren, emailAddress=info@airvpn.org . 2023.12.19 23:45:05 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 23:45:05 - OpenVPN > [Wurren] Peer Connection Initiated with [AF_INET]199.189.27.122:443 . 2023.12.19 23:45:06 - OpenVPN > SENT CONTROL [Wurren]: 'PUSH_REQUEST' (status=1) . 2023.12.19 23:45:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.196.1,dhcp-option DNS6 fde6:7a:7d20:5c4::1,tun-ipv6,route-gateway 10.9.196.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:5c4::106a/64 fde6:7a:7d20:5c4::1,ifconfig 10.9.196.108 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.19 23:45:06 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 23:45:06 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.9.196.1' . 2023.12.19 23:45:06 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:5c4::1' . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 23:45:06 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 23:45:06 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 23:45:06 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:45:06 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:45:06 - OpenVPN > Opened utun device utun3 . 2023.12.19 23:45:06 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 23:45:06 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 23:45:06 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 23:45:06 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 23:45:06 - OpenVPN > /sbin/ifconfig utun3 10.9.196.108 10.9.196.108 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 23:45:06 - OpenVPN > /sbin/route add -net 10.9.196.0 10.9.196.108 255.255.255.0 . 2023.12.19 23:45:06 - OpenVPN > add net 10.9.196.0: gateway 10.9.196.108 . 2023.12.19 23:45:06 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:5c4::106a/64 mtu 1500 up . 2023.12.19 23:45:06 - OpenVPN > add_route_ipv6(fde6:7a:7d20:5c4::/64 -> fde6:7a:7d20:5c4::106a metric 0) dev utun3 . 2023.12.19 23:45:06 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:5c4:: -prefixlen 64 -iface utun3 . 2023.12.19 23:45:06 - OpenVPN > add net fde6:7a:7d20:5c4::: gateway utun3: File exists . 2023.12.19 23:45:06 - OpenVPN > Initialization Sequence Completed . 2023.12.19 23:45:06 - DNS of a network adapter forced (Ethernet, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:45:06 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:45:06 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:45:06 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:45:06 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 23:45:06 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 23:45:06 - Routes, add ::/1 for interface "utun3". . 2023.12.19 23:45:06 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 23:45:06 - Routes, add 199.189.27.123/32 for interface "utun3". . 2023.12.19 23:45:06 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun3". . 2023.12.19 23:45:06 - Flushing DNS I 2023.12.19 23:45:06 - Checking route IPv4 I 2023.12.19 23:45:07 - Checking route IPv6 I 2023.12.19 23:45:07 - Checking DNS ! 2023.12.19 23:45:08 - Connected. ! 2023.12.19 23:47:33 - Disconnecting . 2023.12.19 23:47:33 - Sending soft termination signal . 2023.12.19 23:47:33 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 23:47:33 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 23:47:39 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 23:47:39 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:5c4::106a . 2023.12.19 23:47:39 - OpenVPN > delete host fde6:7a:7d20:5c4::106a . 2023.12.19 23:47:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 23:47:39 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:47:39 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:47:39 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 23:47:39 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 23:47:39 - Routes, delete 199.189.27.122/32 for interface "en1". . 2023.12.19 23:47:39 - Routes, delete 199.189.27.123/32 for interface "utun3", not exists. . 2023.12.19 23:47:39 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun3", not exists. . 2023.12.19 23:47:39 - Routes, delete 199.189.27.122/32 for interface "en1", not exists. . 2023.12.19 23:47:39 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 23:47:39 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 23:47:39 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 23:47:39 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 23:47:39 - Connection terminated. . 2023.12.19 23:47:39 - Flushing DNS ! 2023.12.19 23:47:39 - Session terminated. I 2023.12.19 23:47:44 - Session starting. I 2023.12.19 23:47:44 - Checking authorization ... ! 2023.12.19 23:47:44 - Connecting to Sualocin (Canada, Toronto, Ontario) . 2023.12.19 23:47:44 - Routes, add 184.75.221.42/32 for interface "en1". . 2023.12.19 23:47:44 - Routes, add 184.75.221.42/32 for interface "en1", already exists. . 2023.12.19 23:47:45 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 23:47:45 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 23:47:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 23:47:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 23:47:45 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.42:443 . 2023.12.19 23:47:45 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 23:47:45 - OpenVPN > UDP link local: (not bound) . 2023.12.19 23:47:45 - OpenVPN > UDP link remote: [AF_INET]184.75.221.42:443 . 2023.12.19 23:47:45 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.42:443, sid=30a9bf44 395df16c . 2023.12.19 23:47:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 23:47:45 - OpenVPN > VERIFY KU OK . 2023.12.19 23:47:45 - OpenVPN > Validating certificate extended key usage . 2023.12.19 23:47:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 23:47:45 - OpenVPN > VERIFY EKU OK . 2023.12.19 23:47:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sualocin, emailAddress=info@airvpn.org . 2023.12.19 23:47:45 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 23:47:45 - OpenVPN > [Sualocin] Peer Connection Initiated with [AF_INET]184.75.221.42:443 . 2023.12.19 23:47:45 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 23:47:45 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 23:47:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.196.1,dhcp-option DNS6 fde6:7a:7d20:1ac4::1,tun-ipv6,route-gateway 10.30.196.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1ac4::10df/64 fde6:7a:7d20:1ac4::1,ifconfig 10.30.196.225 255.255.255.0,peer-id 2,cipher AES-256-GCM' . 2023.12.19 23:47:45 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 23:47:45 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.30.196.1' . 2023.12.19 23:47:45 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1ac4::1' . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 23:47:45 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 23:47:45 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 23:47:45 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:47:45 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:47:45 - OpenVPN > Opened utun device utun3 . 2023.12.19 23:47:45 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 23:47:45 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 23:47:45 - OpenVPN > /sbin/ifconfig utun3 10.30.196.225 10.30.196.225 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 23:47:45 - OpenVPN > /sbin/route add -net 10.30.196.0 10.30.196.225 255.255.255.0 . 2023.12.19 23:47:45 - OpenVPN > add net 10.30.196.0: gateway 10.30.196.225 . 2023.12.19 23:47:45 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1ac4::10df/64 mtu 1500 up . 2023.12.19 23:47:45 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1ac4::/64 -> fde6:7a:7d20:1ac4::10df metric 0) dev utun3 . 2023.12.19 23:47:45 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1ac4:: -prefixlen 64 -iface utun3 . 2023.12.19 23:47:45 - OpenVPN > add net fde6:7a:7d20:1ac4::: gateway utun3: File exists . 2023.12.19 23:47:45 - OpenVPN > Initialization Sequence Completed . 2023.12.19 23:47:46 - DNS of a network adapter forced (Ethernet, from Automatic to 10.30.196.1, fde6:7a:7d20:1ac4::1) . 2023.12.19 23:47:46 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.30.196.1, fde6:7a:7d20:1ac4::1) . 2023.12.19 23:47:46 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.30.196.1, fde6:7a:7d20:1ac4::1) . 2023.12.19 23:47:46 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.30.196.1, fde6:7a:7d20:1ac4::1) . 2023.12.19 23:47:46 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 23:47:46 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 23:47:46 - Routes, add ::/1 for interface "utun3". . 2023.12.19 23:47:46 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 23:47:46 - Routes, add 184.75.221.43/32 for interface "utun3". . 2023.12.19 23:47:46 - Routes, add 2606:6080:1001:f:ed79:9361:ea0e:3e88/128 for interface "utun3". . 2023.12.19 23:47:46 - Flushing DNS I 2023.12.19 23:47:46 - Checking route IPv4 I 2023.12.19 23:47:47 - Checking route IPv6 I 2023.12.19 23:47:47 - Checking DNS ! 2023.12.19 23:47:47 - Connected. ! 2023.12.19 23:49:53 - Disconnecting . 2023.12.19 23:49:53 - Sending soft termination signal . 2023.12.19 23:49:53 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 23:49:53 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 23:49:58 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 23:49:58 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1ac4::10df . 2023.12.19 23:49:58 - OpenVPN > delete host fde6:7a:7d20:1ac4::10df . 2023.12.19 23:49:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 23:49:58 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:49:58 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:49:58 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 23:49:58 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 23:49:59 - Routes, delete 184.75.221.42/32 for interface "en1". . 2023.12.19 23:49:59 - Routes, delete 184.75.221.43/32 for interface "utun3", not exists. . 2023.12.19 23:49:59 - Routes, delete 2606:6080:1001:f:ed79:9361:ea0e:3e88/128 for interface "utun3", not exists. . 2023.12.19 23:49:59 - Routes, delete 184.75.221.42/32 for interface "en1", not exists. . 2023.12.19 23:49:59 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 23:49:59 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 23:49:59 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 23:49:59 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 23:49:59 - Connection terminated. . 2023.12.19 23:49:59 - Flushing DNS ! 2023.12.19 23:49:59 - Session terminated. I 2023.12.19 23:50:42 - Session starting. I 2023.12.19 23:50:42 - Checking authorization ... ! 2023.12.19 23:50:43 - Connecting to Wurren (Canada, Toronto, Ontario) . 2023.12.19 23:50:43 - Routes, add 199.189.27.122/32 for interface "en1". . 2023.12.19 23:50:43 - Routes, add 199.189.27.122/32 for interface "en1", already exists. . 2023.12.19 23:50:43 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.19 23:50:43 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.19 23:50:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 23:50:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2023.12.19 23:50:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.189.27.122:443 . 2023.12.19 23:50:43 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2023.12.19 23:50:43 - OpenVPN > UDP link local: (not bound) . 2023.12.19 23:50:43 - OpenVPN > UDP link remote: [AF_INET]199.189.27.122:443 . 2023.12.19 23:50:43 - OpenVPN > TLS: Initial packet from [AF_INET]199.189.27.122:443, sid=a81b95b9 4ebfdcc2 . 2023.12.19 23:50:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.19 23:50:43 - OpenVPN > VERIFY KU OK . 2023.12.19 23:50:43 - OpenVPN > Validating certificate extended key usage . 2023.12.19 23:50:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.19 23:50:43 - OpenVPN > VERIFY EKU OK . 2023.12.19 23:50:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wurren, emailAddress=info@airvpn.org . 2023.12.19 23:50:43 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.19 23:50:43 - OpenVPN > [Wurren] Peer Connection Initiated with [AF_INET]199.189.27.122:443 . 2023.12.19 23:50:44 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.19 23:50:44 - OpenVPN > SENT CONTROL [Wurren]: 'PUSH_REQUEST' (status=1) . 2023.12.19 23:50:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.196.1,dhcp-option DNS6 fde6:7a:7d20:5c4::1,tun-ipv6,route-gateway 10.9.196.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:5c4::106a/64 fde6:7a:7d20:5c4::1,ifconfig 10.9.196.108 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.19 23:50:44 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.19 23:50:44 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.9.196.1' . 2023.12.19 23:50:44 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:5c4::1' . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2023.12.19 23:50:44 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.19 23:50:44 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.19 23:50:44 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:50:44 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.19 23:50:44 - OpenVPN > Opened utun device utun3 . 2023.12.19 23:50:44 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.19 23:50:44 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.19 23:50:44 - OpenVPN > /sbin/ifconfig utun3 10.9.196.108 10.9.196.108 netmask 255.255.255.0 mtu 1500 up . 2023.12.19 23:50:44 - OpenVPN > /sbin/route add -net 10.9.196.0 10.9.196.108 255.255.255.0 . 2023.12.19 23:50:44 - OpenVPN > add net 10.9.196.0: gateway 10.9.196.108 . 2023.12.19 23:50:44 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:5c4::106a/64 mtu 1500 up . 2023.12.19 23:50:44 - OpenVPN > add_route_ipv6(fde6:7a:7d20:5c4::/64 -> fde6:7a:7d20:5c4::106a metric 0) dev utun3 . 2023.12.19 23:50:44 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:5c4:: -prefixlen 64 -iface utun3 . 2023.12.19 23:50:44 - OpenVPN > add net fde6:7a:7d20:5c4::: gateway utun3: File exists . 2023.12.19 23:50:44 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.19 23:50:44 - OpenVPN > Initialization Sequence Completed . 2023.12.19 23:50:44 - DNS of a network adapter forced (Ethernet, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:50:44 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:50:44 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:50:44 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.9.196.1, fde6:7a:7d20:5c4::1) . 2023.12.19 23:50:44 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.19 23:50:44 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.19 23:50:44 - Routes, add ::/1 for interface "utun3". . 2023.12.19 23:50:44 - Routes, add 8000::/1 for interface "utun3". . 2023.12.19 23:50:44 - Routes, add 199.189.27.123/32 for interface "utun3". . 2023.12.19 23:50:44 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun3". . 2023.12.19 23:50:44 - Flushing DNS I 2023.12.19 23:50:44 - Checking route IPv4 I 2023.12.19 23:50:45 - Checking route IPv6 I 2023.12.19 23:50:45 - Checking DNS ! 2023.12.19 23:50:46 - Connected. ! 2023.12.19 23:53:32 - Disconnecting . 2023.12.19 23:53:32 - Sending soft termination signal . 2023.12.19 23:53:32 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.19 23:53:32 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.12.19 23:53:37 - OpenVPN > Closing TUN/TAP interface . 2023.12.19 23:53:37 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:5c4::106a . 2023.12.19 23:53:37 - OpenVPN > delete host fde6:7a:7d20:5c4::106a . 2023.12.19 23:53:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.12.19 23:53:37 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:53:37 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.19 23:53:37 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.19 23:53:37 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.19 23:53:37 - Routes, delete 199.189.27.122/32 for interface "en1". . 2023.12.19 23:53:37 - Routes, delete 199.189.27.123/32 for interface "utun3", not exists. . 2023.12.19 23:53:37 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun3", not exists. . 2023.12.19 23:53:37 - Routes, delete 199.189.27.122/32 for interface "en1", not exists. . 2023.12.19 23:53:37 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.19 23:53:37 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.19 23:53:37 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.19 23:53:37 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.19 23:53:37 - Connection terminated. . 2023.12.19 23:53:37 - Flushing DNS ! 2023.12.19 23:53:37 - Session terminated. ---------------------------- Network Interfaces and Routes: { "routes": [ { "destination": "0.0.0.0\/0", "expire": "", "flags": "UGScg", "gateway": "192.168.1.1", "interface": "en1", "mtu": "1500", "refs": "75", "rt_ifa": "192.168.1.154", "use": "2249" }, { "destination": "127", "expire": "", "flags": "UCS", "gateway": "127.0.0.1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "127.0.0.1", "use": "0" }, { "destination": "127.0.0.1\/32", "expire": "", "flags": "UH", "gateway": "127.0.0.1", "interface": "lo0", "mtu": "16384", "refs": "3", "rt_ifa": "127.0.0.1", "use": "21429" }, { "destination": "169.254\/32", "expire": "!", "flags": "UCS", "gateway": "link#5", "interface": "en1", "mtu": "1500", "refs": "1", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "192.168.1\/32", "expire": "!", "flags": "UCS", "gateway": "link#5", "interface": "en1", "mtu": "1500", "refs": "5", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "192.168.1.1\/32", "expire": "!", "flags": "UCS", "gateway": "link#5", "interface": "en1", "mtu": "1500", "refs": "1", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "192.168.1.1\/32", "expire": "1192", "flags": "UHLWIir", "gateway": "48:5d:36:37:67:5c", "interface": "en1", "mtu": "1500", "refs": "14", "rt_ifa": "192.168.1.154", "use": "74" }, { "destination": "192.168.1.22\/32", "expire": "1124", "flags": "UHLWIi", "gateway": "c2:17:17:d5:47:44", "interface": "en1", "mtu": "1500", "refs": "2", "rt_ifa": "192.168.1.154", "use": "89" }, { "destination": "192.168.1.99\/32", "expire": "918", "flags": "UHLWI", "gateway": "26:f7:c7:1f:fe:34", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "36" }, { "destination": "192.168.1.152\/32", "expire": "1195", "flags": "UHLWI", "gateway": "10:78:5b:2e:d5:10", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "113" }, { "destination": "192.168.1.154\/32", "expire": "!", "flags": "UCS", "gateway": "link#5", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "192.168.1.186\/32", "expire": "1195", "flags": "UHLWI", "gateway": "0:6:78:45:b7:90", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "192.168.1.254\/32", "expire": "346", "flags": "UHLWI", "gateway": "34:68:95:1d:79:70", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "224.0.0\/4", "expire": "!", "flags": "UmCS", "gateway": "link#5", "interface": "en1", "mtu": "1500", "refs": "1", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "224.0.0.251\/32", "expire": "", "flags": "UHmLWI", "gateway": "1:0:5e:0:0:fb", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "255.255.255.255\/32", "expire": "!", "flags": "UCS", "gateway": "link#5", "interface": "en1", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.1.154", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun0", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::df96:c352:859d:2322%utun0", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun1", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::acb1:6233:3a15:aea0%utun1", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun2", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun2", "use": "0" }, { "destination": "::1\/128", "expire": "", "flags": "UHL", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "1", "rt_ifa": "::1", "use": "23" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::1", "interface": "lo0", "mtu": "16384", "refs": "1", "rt_ifa": "fe80::1%lo0", "use": "0" }, { "destination": "fe80::1\/128", "expire": "", "flags": "UHLI", "gateway": "link#1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::1%lo0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UCI", "gateway": "link#10", "interface": "awdl0", "mtu": "1484", "refs": "1", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%awdl0", "use": "0" }, { "destination": "fe80::2096:8eff:fe6c:e3c7\/128", "expire": "", "flags": "UHLI", "gateway": "22:96:8e:6c:e3:c7", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%awdl0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UCI", "gateway": "link#11", "interface": "llw0", "mtu": "1500", "refs": "1", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%llw0", "use": "0" }, { "destination": "fe80::2096:8eff:fe6c:e3c7\/128", "expire": "", "flags": "UHLI", "gateway": "22:96:8e:6c:e3:c7", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%llw0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::df96:c352:859d:2322", "interface": "utun0", "mtu": "1380", "refs": "2", "rt_ifa": "fe80::df96:c352:859d:2322%utun0", "use": "0" }, { "destination": "fe80::df96:c352:859d:2322\/128", "expire": "", "flags": "UHLI", "gateway": "link#12", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::df96:c352:859d:2322%utun0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::acb1:6233:3a15:aea0", "interface": "utun1", "mtu": "2000", "refs": "2", "rt_ifa": "fe80::acb1:6233:3a15:aea0%utun1", "use": "0" }, { "destination": "fe80::acb1:6233:3a15:aea0\/128", "expire": "", "flags": "UHLI", "gateway": "link#13", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::acb1:6233:3a15:aea0%utun1", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun2", "mtu": "1000", "refs": "2", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun2", "use": "0" }, { "destination": "fe80::ce81:b1c:bd2c:69e\/128", "expire": "", "flags": "UHLI", "gateway": "link#14", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun2", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "::1", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "link#10", "interface": "awdl0", "mtu": "1484", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%awdl0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "link#11", "interface": "llw0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%llw0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::df96:c352:859d:2322", "interface": "utun0", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::df96:c352:859d:2322%utun0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::acb1:6233:3a15:aea0", "interface": "utun1", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::acb1:6233:3a15:aea0%utun1", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun2", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun2", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "::1", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "link#10", "interface": "awdl0", "mtu": "1484", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%awdl0", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "link#11", "interface": "llw0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%llw0", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::df96:c352:859d:2322", "interface": "utun0", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::df96:c352:859d:2322%utun0", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::acb1:6233:3a15:aea0", "interface": "utun1", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::acb1:6233:3a15:aea0%utun1", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun2", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun2", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "::1", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "link#10", "interface": "awdl0", "mtu": "1484", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%awdl0", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "link#11", "interface": "llw0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::2096:8eff:fe6c:e3c7%llw0", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::df96:c352:859d:2322", "interface": "utun0", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::df96:c352:859d:2322%utun0", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::acb1:6233:3a15:aea0", "interface": "utun1", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::acb1:6233:3a15:aea0%utun1", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun2", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun2", "use": "0" } ], "ipv4-default-gateway": "192.168.1.1", "ipv4-default-interface": "en1", "ipv6-default-gateway": "fe80::", "ipv6-default-interface": "utun0", "interfaces": [ { "friendly": "lo0", "id": "lo0", "name": "lo0", "description": "lo0", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "127.0.0.1", "::1", "fe80::1" ], "bind": true }, { "friendly": "gif0", "id": "gif0", "name": "gif0", "description": "gif0", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "stf0", "id": "stf0", "name": "stf0", "description": "stf0", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Ethernet", "id": "en0", "name": "en0", "description": "en0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [], "bind": false }, { "friendly": "Wi-Fi", "id": "en1", "name": "en1", "description": "en1", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.1.154" ], "bind": true }, { "friendly": "Thunderbolt 2", "id": "en3", "name": "en3", "description": "en3", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Thunderbolt 1", "id": "en2", "name": "en2", "description": "en2", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Thunderbolt Bridge", "id": "bridge0", "name": "bridge0", "description": "bridge0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [], "bind": false }, { "friendly": "p2p0", "id": "p2p0", "name": "p2p0", "description": "p2p0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "awdl0", "id": "awdl0", "name": "awdl0", "description": "awdl0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::2096:8eff:fe6c:e3c7" ], "bind": true }, { "friendly": "llw0", "id": "llw0", "name": "llw0", "description": "llw0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::2096:8eff:fe6c:e3c7" ], "bind": true }, { "friendly": "utun0", "id": "utun0", "name": "utun0", "description": "utun0", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::df96:c352:859d:2322" ], "bind": true }, { "friendly": "utun1", "id": "utun1", "name": "utun1", "description": "utun1", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::acb1:6233:3a15:aea0" ], "bind": true }, { "friendly": "utun2", "id": "utun2", "name": "utun2", "description": "utun2", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::ce81:b1c:bd2c:69e" ], "bind": true } ] } ---------------------------- ifconfig: lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP> inet 127.0.0.1 netmask 0xff000000 inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 nd6 options=201<PERFORMNUD,DAD> gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280 stf0: flags=0<> mtu 1280 en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO> ether 38:c9:86:50:95:3a media: autoselect (none) status: inactive en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 28:f0:76:4b:92:da inet 192.168.1.154 netmask 0xffffff00 broadcast 192.168.1.255 media: autoselect status: active en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=460<TSO4,TSO6,CHANNEL_IO> ether 82:19:07:6e:6f:01 media: autoselect <full-duplex> status: inactive en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=460<TSO4,TSO6,CHANNEL_IO> ether 82:19:07:6e:6f:00 media: autoselect <full-duplex> status: inactive bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=63<RXCSUM,TXCSUM,TSO4,TSO6> ether 82:19:07:6e:6f:00 Configuration: id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0 maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200 root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0 ipfilter disabled flags 0x0 member: en2 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 7 priority 0 path cost 0 member: en3 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 6 priority 0 path cost 0 media: <unknown type> status: inactive p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304 options=400<CHANNEL_IO> ether 0a:f0:76:4b:92:da media: autoselect status: inactive awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484 options=400<CHANNEL_IO> ether 22:96:8e:6c:e3:c7 inet6 fe80::2096:8eff:fe6c:e3c7%awdl0 prefixlen 64 scopeid 0xa nd6 options=201<PERFORMNUD,DAD> media: autoselect status: active llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 22:96:8e:6c:e3:c7 inet6 fe80::2096:8eff:fe6c:e3c7%llw0 prefixlen 64 scopeid 0xb nd6 options=201<PERFORMNUD,DAD> media: autoselect status: active utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380 inet6 fe80::df96:c352:859d:2322%utun0 prefixlen 64 scopeid 0xc nd6 options=201<PERFORMNUD,DAD> utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000 inet6 fe80::acb1:6233:3a15:aea0%utun1 prefixlen 64 scopeid 0xd nd6 options=201<PERFORMNUD,DAD> utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000 inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0xe nd6 options=201<PERFORMNUD,DAD> Quote Share this post Link to post
Staff 10336 Posted ... Hello! Let's verify whether changing connection mode helps or not, just in case the ISP is interfering with UDP and/or OpenVPN: from Eddie's main window please select "Preferences" > "Protocols" uncheck "Automatic" select the line with OpenVPN, protocol TCP, port 443, entry-IP address 3 (three). The line will be highlighted click "Save" and test again connections to various servers Kind regards Quote Share this post Link to post
weelilbit 0 Posted ... Unfortunately, no go. Did my best to try a wide variety of servers. How many is sufficient for testing? . 2023.12.20 16:03:33 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:03:33 - OpenVPN > [Norma] Peer Connection Initiated with [AF_INET]31.3.152.102:443 . 2023.12.20 16:03:33 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:03:33 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:03:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.71.1,dhcp-option DNS6 fde6:7a:7d20:1547::1,tun-ipv6,route-gateway 10.25.71.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1547::1071/64 fde6:7a:7d20:1547::1,ifconfig 10.25.71.115 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:03:33 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:03:33 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.25.71.1' . 2023.12.20 16:03:33 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1547::1' . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:03:33 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:03:33 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:03:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:03:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:03:33 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:03:33 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:03:33 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:03:33 - OpenVPN > /sbin/ifconfig utun3 10.25.71.115 10.25.71.115 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:03:33 - OpenVPN > /sbin/route add -net 10.25.71.0 10.25.71.115 255.255.255.0 . 2023.12.20 16:03:33 - OpenVPN > add net 10.25.71.0: gateway 10.25.71.115 . 2023.12.20 16:03:33 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1547::1071/64 mtu 1500 up . 2023.12.20 16:03:33 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1547::/64 -> fde6:7a:7d20:1547::1071 metric 0) dev utun3 . 2023.12.20 16:03:33 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1547:: -prefixlen 64 -iface utun3 . 2023.12.20 16:03:33 - OpenVPN > add net fde6:7a:7d20:1547::: gateway utun3: File exists . 2023.12.20 16:03:33 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:03:34 - DNS of a network adapter forced (Ethernet, from Automatic to 10.25.71.1, fde6:7a:7d20:1547::1) . 2023.12.20 16:03:34 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.25.71.1, fde6:7a:7d20:1547::1) . 2023.12.20 16:03:34 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.25.71.1, fde6:7a:7d20:1547::1) . 2023.12.20 16:03:34 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.25.71.1, fde6:7a:7d20:1547::1) . 2023.12.20 16:03:34 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:03:34 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:03:34 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:03:34 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:03:34 - Routes, add 31.3.152.100/32 for interface "utun3". . 2023.12.20 16:03:34 - Routes, add 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3". . 2023.12.20 16:03:34 - Flushing DNS I 2023.12.20 16:03:34 - Checking route IPv4 I 2023.12.20 16:03:35 - Checking route IPv6 I 2023.12.20 16:03:37 - Checking DNS ! 2023.12.20 16:03:38 - Connected. ! 2023.12.20 16:04:13 - Disconnecting . 2023.12.20 16:04:13 - Sending soft termination signal . 2023.12.20 16:04:14 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:04:14 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:04:14 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1547::1071 . 2023.12.20 16:04:14 - OpenVPN > delete host fde6:7a:7d20:1547::1071 . 2023.12.20 16:04:14 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:04:14 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:04:14 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:04:14 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:04:14 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:04:14 - Routes, delete 31.3.152.102/32 for interface "en1". . 2023.12.20 16:04:14 - Routes, delete 31.3.152.100/32 for interface "utun3", not exists. . 2023.12.20 16:04:14 - Routes, delete 2a00:7142:4a:b749:d89c:1b40:7ba2:9390/128 for interface "utun3", not exists. . 2023.12.20 16:04:14 - Routes, delete 31.3.152.102/32 for interface "en1", not exists. . 2023.12.20 16:04:14 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:04:14 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:04:14 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:04:14 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:04:14 - Connection terminated. . 2023.12.20 16:04:14 - Flushing DNS ! 2023.12.20 16:04:14 - Session terminated. I 2023.12.20 16:04:20 - Session starting. I 2023.12.20 16:04:20 - Checking authorization ... ! 2023.12.20 16:04:21 - Connecting to Kang (United States of America, Miami) . 2023.12.20 16:04:21 - Routes, add 104.129.48.69/32 for interface "en1". . 2023.12.20 16:04:21 - Routes, add 104.129.48.69/32 for interface "en1", already exists. . 2023.12.20 16:04:22 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:04:22 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:04:22 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:04:22 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:04:22 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:04:22 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:04:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.129.48.69:443 . 2023.12.20 16:04:22 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:04:22 - OpenVPN > Attempting to establish TCP connection with [AF_INET]104.129.48.69:443 [nonblock] . 2023.12.20 16:04:22 - OpenVPN > TCP connection established with [AF_INET]104.129.48.69:443 . 2023.12.20 16:04:22 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:04:22 - OpenVPN > TCP_CLIENT link remote: [AF_INET]104.129.48.69:443 . 2023.12.20 16:04:22 - OpenVPN > TLS: Initial packet from [AF_INET]104.129.48.69:443, sid=2f0e3f96 0f9a91c4 . 2023.12.20 16:04:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:04:22 - OpenVPN > VERIFY KU OK . 2023.12.20 16:04:22 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:04:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:04:22 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:04:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Kang, emailAddress=info@airvpn.org . 2023.12.20 16:04:22 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:04:22 - OpenVPN > [Kang] Peer Connection Initiated with [AF_INET]104.129.48.69:443 . 2023.12.20 16:04:23 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:04:23 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:04:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.135.1,dhcp-option DNS6 fde6:7a:7d20:1c87::1,tun-ipv6,route-gateway 10.32.135.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1c87::1005/64 fde6:7a:7d20:1c87::1,ifconfig 10.32.135.7 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:04:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:04:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.32.135.1' . 2023.12.20 16:04:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1c87::1' . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:04:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:04:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:04:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:04:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:04:23 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:04:23 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:04:23 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:04:23 - OpenVPN > /sbin/ifconfig utun3 10.32.135.7 10.32.135.7 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:04:23 - OpenVPN > /sbin/route add -net 10.32.135.0 10.32.135.7 255.255.255.0 . 2023.12.20 16:04:23 - OpenVPN > add net 10.32.135.0: gateway 10.32.135.7 . 2023.12.20 16:04:23 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1c87::1005/64 mtu 1500 up . 2023.12.20 16:04:23 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1c87::/64 -> fde6:7a:7d20:1c87::1005 metric 0) dev utun3 . 2023.12.20 16:04:23 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1c87:: -prefixlen 64 -iface utun3 . 2023.12.20 16:04:23 - OpenVPN > add net fde6:7a:7d20:1c87::: gateway utun3: File exists . 2023.12.20 16:04:23 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:04:23 - DNS of a network adapter forced (Ethernet, from Automatic to 10.32.135.1, fde6:7a:7d20:1c87::1) . 2023.12.20 16:04:23 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.32.135.1, fde6:7a:7d20:1c87::1) . 2023.12.20 16:04:23 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.32.135.1, fde6:7a:7d20:1c87::1) . 2023.12.20 16:04:23 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.32.135.1, fde6:7a:7d20:1c87::1) . 2023.12.20 16:04:23 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:04:23 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:04:23 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:04:23 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:04:23 - Routes, add 104.129.48.67/32 for interface "utun3". . 2023.12.20 16:04:23 - Routes, add 2607:ff48:aa81:202:5b4:b37f:fc76:1b1f/128 for interface "utun3". . 2023.12.20 16:04:23 - Flushing DNS I 2023.12.20 16:04:23 - Checking route IPv4 I 2023.12.20 16:04:24 - Checking route IPv6 I 2023.12.20 16:04:25 - Checking DNS ! 2023.12.20 16:04:26 - Connected. ! 2023.12.20 16:05:13 - Disconnecting . 2023.12.20 16:05:13 - Sending soft termination signal . 2023.12.20 16:05:13 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:05:13 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:05:13 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1c87::1005 . 2023.12.20 16:05:13 - OpenVPN > delete host fde6:7a:7d20:1c87::1005 . 2023.12.20 16:05:13 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:05:13 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:05:13 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:05:13 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:05:13 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:05:13 - Routes, delete 104.129.48.69/32 for interface "en1". . 2023.12.20 16:05:13 - Routes, delete 104.129.48.67/32 for interface "utun3", not exists. . 2023.12.20 16:05:13 - Routes, delete 2607:ff48:aa81:202:5b4:b37f:fc76:1b1f/128 for interface "utun3", not exists. . 2023.12.20 16:05:13 - Routes, delete 104.129.48.69/32 for interface "en1", not exists. . 2023.12.20 16:05:13 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:05:14 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:05:14 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:05:14 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:05:14 - Connection terminated. . 2023.12.20 16:05:14 - Flushing DNS ! 2023.12.20 16:05:14 - Session terminated. I 2023.12.20 16:05:20 - Session starting. I 2023.12.20 16:05:20 - Checking authorization ... ! 2023.12.20 16:05:21 - Connecting to Phact (Latvia, Riga) . 2023.12.20 16:05:21 - Routes, add 46.183.216.165/32 for interface "en1". . 2023.12.20 16:05:21 - Routes, add 46.183.216.165/32 for interface "en1", already exists. . 2023.12.20 16:05:21 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:05:21 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:05:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:05:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:05:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:05:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:05:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]46.183.216.165:443 . 2023.12.20 16:05:21 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:05:21 - OpenVPN > Attempting to establish TCP connection with [AF_INET]46.183.216.165:443 [nonblock] . 2023.12.20 16:05:21 - OpenVPN > TCP connection established with [AF_INET]46.183.216.165:443 . 2023.12.20 16:05:21 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:05:21 - OpenVPN > TCP_CLIENT link remote: [AF_INET]46.183.216.165:443 . 2023.12.20 16:05:21 - OpenVPN > TLS: Initial packet from [AF_INET]46.183.216.165:443, sid=2205ca6d 396beeee . 2023.12.20 16:05:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:05:21 - OpenVPN > VERIFY KU OK . 2023.12.20 16:05:21 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:05:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:05:21 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:05:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Phact, emailAddress=info@airvpn.org . 2023.12.20 16:05:22 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:05:22 - OpenVPN > [Phact] Peer Connection Initiated with [AF_INET]46.183.216.165:443 . 2023.12.20 16:05:22 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:05:22 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:05:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.167.1,dhcp-option DNS6 fde6:7a:7d20:16a7::1,tun-ipv6,route-gateway 10.26.167.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:16a7::103f/64 fde6:7a:7d20:16a7::1,ifconfig 10.26.167.65 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:05:22 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:05:22 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.26.167.1' . 2023.12.20 16:05:22 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:16a7::1' . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:05:22 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:05:22 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:05:22 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:05:22 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:05:22 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:05:22 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:05:22 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:05:22 - OpenVPN > /sbin/ifconfig utun3 10.26.167.65 10.26.167.65 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:05:22 - OpenVPN > /sbin/route add -net 10.26.167.0 10.26.167.65 255.255.255.0 . 2023.12.20 16:05:22 - OpenVPN > add net 10.26.167.0: gateway 10.26.167.65 . 2023.12.20 16:05:22 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:16a7::103f/64 mtu 1500 up . 2023.12.20 16:05:22 - OpenVPN > add_route_ipv6(fde6:7a:7d20:16a7::/64 -> fde6:7a:7d20:16a7::103f metric 0) dev utun3 . 2023.12.20 16:05:22 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:16a7:: -prefixlen 64 -iface utun3 . 2023.12.20 16:05:22 - OpenVPN > add net fde6:7a:7d20:16a7::: gateway utun3: File exists . 2023.12.20 16:05:22 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:05:23 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.167.1, fde6:7a:7d20:16a7::1) . 2023.12.20 16:05:23 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.26.167.1, fde6:7a:7d20:16a7::1) . 2023.12.20 16:05:23 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.26.167.1, fde6:7a:7d20:16a7::1) . 2023.12.20 16:05:23 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.26.167.1, fde6:7a:7d20:16a7::1) . 2023.12.20 16:05:23 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:05:23 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:05:23 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:05:23 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:05:23 - Routes, add 46.183.216.163/32 for interface "utun3". . 2023.12.20 16:05:23 - Routes, add 2a02:4840:2:237:b0bd:6f2c:c975:5bf0/128 for interface "utun3". . 2023.12.20 16:05:23 - Flushing DNS I 2023.12.20 16:05:23 - Checking route IPv4 I 2023.12.20 16:05:24 - Checking route IPv6 I 2023.12.20 16:05:26 - Checking DNS ! 2023.12.20 16:05:28 - Connected. ! 2023.12.20 16:06:10 - Disconnecting . 2023.12.20 16:06:10 - Sending soft termination signal . 2023.12.20 16:06:10 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:06:10 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:06:10 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:16a7::103f . 2023.12.20 16:06:10 - OpenVPN > delete host fde6:7a:7d20:16a7::103f . 2023.12.20 16:06:10 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:06:10 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:06:10 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:06:10 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:06:10 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:06:10 - Routes, delete 46.183.216.165/32 for interface "en1". . 2023.12.20 16:06:10 - Routes, delete 46.183.216.163/32 for interface "utun3", not exists. . 2023.12.20 16:06:10 - Routes, delete 2a02:4840:2:237:b0bd:6f2c:c975:5bf0/128 for interface "utun3", not exists. . 2023.12.20 16:06:10 - Routes, delete 46.183.216.165/32 for interface "en1", not exists. . 2023.12.20 16:06:10 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:06:10 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:06:10 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:06:10 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:06:10 - Connection terminated. . 2023.12.20 16:06:10 - Flushing DNS ! 2023.12.20 16:06:10 - Session terminated. I 2023.12.20 16:06:14 - Session starting. I 2023.12.20 16:06:14 - Checking authorization ... ! 2023.12.20 16:06:14 - Connecting to Asterion (United Kingdom of Great Britain and Northern Ireland, London) . 2023.12.20 16:06:14 - Routes, add 217.151.98.170/32 for interface "en1". . 2023.12.20 16:06:14 - Routes, add 217.151.98.170/32 for interface "en1", already exists. . 2023.12.20 16:06:14 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:06:14 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:06:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:06:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:06:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:06:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:06:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.170:443 . 2023.12.20 16:06:14 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:06:14 - OpenVPN > Attempting to establish TCP connection with [AF_INET]217.151.98.170:443 [nonblock] . 2023.12.20 16:06:14 - OpenVPN > TCP connection established with [AF_INET]217.151.98.170:443 . 2023.12.20 16:06:14 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:06:14 - OpenVPN > TCP_CLIENT link remote: [AF_INET]217.151.98.170:443 . 2023.12.20 16:06:15 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.170:443, sid=3a19adca 99c326e0 . 2023.12.20 16:06:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:06:15 - OpenVPN > VERIFY KU OK . 2023.12.20 16:06:15 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:06:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:06:15 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:06:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Asterion, emailAddress=info@airvpn.org . 2023.12.20 16:06:15 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:06:15 - OpenVPN > [Asterion] Peer Connection Initiated with [AF_INET]217.151.98.170:443 . 2023.12.20 16:06:16 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:06:16 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:06:16 - OpenVPN > SENT CONTROL [Asterion]: 'PUSH_REQUEST' (status=1) . 2023.12.20 16:06:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.10.39.1,dhcp-option DNS6 fde6:7a:7d20:627::1,tun-ipv6,route-gateway 10.10.39.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:627::1030/64 fde6:7a:7d20:627::1,ifconfig 10.10.39.50 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:06:16 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:06:16 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.10.39.1' . 2023.12.20 16:06:16 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:627::1' . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:06:16 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:06:16 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:06:16 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:06:16 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:06:16 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:06:16 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:06:16 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:06:16 - OpenVPN > /sbin/ifconfig utun3 10.10.39.50 10.10.39.50 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:06:16 - OpenVPN > /sbin/route add -net 10.10.39.0 10.10.39.50 255.255.255.0 . 2023.12.20 16:06:16 - OpenVPN > add net 10.10.39.0: gateway 10.10.39.50 . 2023.12.20 16:06:16 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:627::1030/64 mtu 1500 up . 2023.12.20 16:06:16 - OpenVPN > add_route_ipv6(fde6:7a:7d20:627::/64 -> fde6:7a:7d20:627::1030 metric 0) dev utun3 . 2023.12.20 16:06:16 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:627:: -prefixlen 64 -iface utun3 . 2023.12.20 16:06:16 - OpenVPN > add net fde6:7a:7d20:627::: gateway utun3: File exists . 2023.12.20 16:06:16 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:06:16 - DNS of a network adapter forced (Ethernet, from Automatic to 10.10.39.1, fde6:7a:7d20:627::1) . 2023.12.20 16:06:16 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.10.39.1, fde6:7a:7d20:627::1) . 2023.12.20 16:06:16 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.10.39.1, fde6:7a:7d20:627::1) . 2023.12.20 16:06:16 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.10.39.1, fde6:7a:7d20:627::1) . 2023.12.20 16:06:16 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:06:16 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:06:16 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:06:16 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:06:16 - Routes, add 217.151.98.168/32 for interface "utun3". . 2023.12.20 16:06:16 - Routes, add 2001:ac8:31:4:1ce5:5dfc:8948:fb43/128 for interface "utun3". . 2023.12.20 16:06:16 - Flushing DNS I 2023.12.20 16:06:16 - Checking route IPv4 I 2023.12.20 16:06:17 - Checking route IPv6 I 2023.12.20 16:06:19 - Checking DNS ! 2023.12.20 16:06:21 - Connected. ! 2023.12.20 16:06:54 - Disconnecting . 2023.12.20 16:06:54 - Sending soft termination signal . 2023.12.20 16:06:54 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:06:54 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:06:54 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:627::1030 . 2023.12.20 16:06:54 - OpenVPN > delete host fde6:7a:7d20:627::1030 . 2023.12.20 16:06:54 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:06:54 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:06:54 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:06:54 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:06:54 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:06:54 - Routes, delete 217.151.98.170/32 for interface "en1". . 2023.12.20 16:06:54 - Routes, delete 217.151.98.168/32 for interface "utun3", not exists. . 2023.12.20 16:06:54 - Routes, delete 2001:ac8:31:4:1ce5:5dfc:8948:fb43/128 for interface "utun3", not exists. . 2023.12.20 16:06:54 - Routes, delete 217.151.98.170/32 for interface "en1", not exists. . 2023.12.20 16:06:54 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:06:54 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:06:54 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:06:54 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:06:54 - Connection terminated. . 2023.12.20 16:06:54 - Flushing DNS ! 2023.12.20 16:06:54 - Session terminated. I 2023.12.20 16:07:02 - Session starting. I 2023.12.20 16:07:02 - Checking authorization ... ! 2023.12.20 16:07:03 - Connecting to Turais (Czechia, Prague) . 2023.12.20 16:07:03 - Routes, add 185.156.174.157/32 for interface "en1". . 2023.12.20 16:07:03 - Routes, add 185.156.174.157/32 for interface "en1", already exists. . 2023.12.20 16:07:03 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:07:03 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:07:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:07:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:07:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:07:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:07:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.174.157:443 . 2023.12.20 16:07:03 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:07:03 - OpenVPN > Attempting to establish TCP connection with [AF_INET]185.156.174.157:443 [nonblock] . 2023.12.20 16:07:03 - OpenVPN > TCP connection established with [AF_INET]185.156.174.157:443 . 2023.12.20 16:07:03 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:07:03 - OpenVPN > TCP_CLIENT link remote: [AF_INET]185.156.174.157:443 . 2023.12.20 16:07:03 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.174.157:443, sid=d38937a9 aa4989e4 . 2023.12.20 16:07:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:07:04 - OpenVPN > VERIFY KU OK . 2023.12.20 16:07:04 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:07:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:07:04 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:07:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Turais, emailAddress=info@airvpn.org . 2023.12.20 16:07:04 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:07:04 - OpenVPN > [Turais] Peer Connection Initiated with [AF_INET]185.156.174.157:443 . 2023.12.20 16:07:04 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:07:04 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:07:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.167.1,dhcp-option DNS6 fde6:7a:7d20:1ba7::1,tun-ipv6,route-gateway 10.31.167.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1ba7::10d9/64 fde6:7a:7d20:1ba7::1,ifconfig 10.31.167.219 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:07:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:07:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.31.167.1' . 2023.12.20 16:07:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1ba7::1' . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:07:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:07:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:07:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:07:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:07:04 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:07:04 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:07:04 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:07:04 - OpenVPN > /sbin/ifconfig utun3 10.31.167.219 10.31.167.219 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:07:04 - OpenVPN > /sbin/route add -net 10.31.167.0 10.31.167.219 255.255.255.0 . 2023.12.20 16:07:04 - OpenVPN > add net 10.31.167.0: gateway 10.31.167.219 . 2023.12.20 16:07:04 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1ba7::10d9/64 mtu 1500 up . 2023.12.20 16:07:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1ba7::/64 -> fde6:7a:7d20:1ba7::10d9 metric 0) dev utun3 . 2023.12.20 16:07:04 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1ba7:: -prefixlen 64 -iface utun3 . 2023.12.20 16:07:04 - OpenVPN > add net fde6:7a:7d20:1ba7::: gateway utun3: File exists . 2023.12.20 16:07:04 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:07:05 - DNS of a network adapter forced (Ethernet, from Automatic to 10.31.167.1, fde6:7a:7d20:1ba7::1) . 2023.12.20 16:07:05 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.31.167.1, fde6:7a:7d20:1ba7::1) . 2023.12.20 16:07:05 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.31.167.1, fde6:7a:7d20:1ba7::1) . 2023.12.20 16:07:05 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.31.167.1, fde6:7a:7d20:1ba7::1) . 2023.12.20 16:07:05 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:07:05 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:07:05 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:07:05 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:07:05 - Routes, add 185.156.174.155/32 for interface "utun3". . 2023.12.20 16:07:05 - Routes, add 2001:ac8:33:9:e73c:6d13:9649:a714/128 for interface "utun3". . 2023.12.20 16:07:05 - Flushing DNS I 2023.12.20 16:07:05 - Checking route IPv4 I 2023.12.20 16:07:06 - Checking route IPv6 I 2023.12.20 16:07:08 - Checking DNS ! 2023.12.20 16:07:10 - Connected. ! 2023.12.20 16:07:45 - Disconnecting . 2023.12.20 16:07:45 - Sending soft termination signal . 2023.12.20 16:07:46 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:07:46 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:07:46 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1ba7::10d9 . 2023.12.20 16:07:46 - OpenVPN > delete host fde6:7a:7d20:1ba7::10d9 . 2023.12.20 16:07:46 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:07:46 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:07:46 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:07:46 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:07:46 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:07:46 - Routes, delete 185.156.174.157/32 for interface "en1". . 2023.12.20 16:07:46 - Routes, delete 185.156.174.155/32 for interface "utun3", not exists. . 2023.12.20 16:07:46 - Routes, delete 2001:ac8:33:9:e73c:6d13:9649:a714/128 for interface "utun3", not exists. . 2023.12.20 16:07:46 - Routes, delete 185.156.174.157/32 for interface "en1", not exists. . 2023.12.20 16:07:46 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:07:46 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:07:46 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:07:46 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:07:46 - Connection terminated. . 2023.12.20 16:07:46 - Flushing DNS ! 2023.12.20 16:07:46 - Session terminated. I 2023.12.20 16:07:49 - Session starting. I 2023.12.20 16:07:49 - Checking authorization ... ! 2023.12.20 16:07:50 - Connecting to Alcor (Ukraine, Kiev) . 2023.12.20 16:07:50 - Routes, add 91.231.84.43/32 for interface "en1". . 2023.12.20 16:07:50 - Routes, add 91.231.84.43/32 for interface "en1", already exists. . 2023.12.20 16:07:50 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:07:50 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:07:50 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:07:50 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:07:50 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:07:50 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:07:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]91.231.84.43:443 . 2023.12.20 16:07:50 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:07:50 - OpenVPN > Attempting to establish TCP connection with [AF_INET]91.231.84.43:443 [nonblock] . 2023.12.20 16:07:50 - OpenVPN > TCP connection established with [AF_INET]91.231.84.43:443 . 2023.12.20 16:07:50 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:07:50 - OpenVPN > TCP_CLIENT link remote: [AF_INET]91.231.84.43:443 . 2023.12.20 16:07:50 - OpenVPN > TLS: Initial packet from [AF_INET]91.231.84.43:443, sid=b46b9ec5 3cfe9f51 . 2023.12.20 16:07:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:07:51 - OpenVPN > VERIFY KU OK . 2023.12.20 16:07:51 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:07:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:07:51 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:07:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alcor, emailAddress=info@airvpn.org . 2023.12.20 16:07:51 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:07:51 - OpenVPN > [Alcor] Peer Connection Initiated with [AF_INET]91.231.84.43:443 . 2023.12.20 16:07:52 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:07:52 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:07:52 - OpenVPN > SENT CONTROL [Alcor]: 'PUSH_REQUEST' (status=1) . 2023.12.20 16:07:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.5.167.1,dhcp-option DNS6 fde6:7a:7d20:1a7::1,tun-ipv6,route-gateway 10.5.167.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1a7::1059/64 fde6:7a:7d20:1a7::1,ifconfig 10.5.167.91 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:07:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:07:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.5.167.1' . 2023.12.20 16:07:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1a7::1' . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:07:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:07:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:07:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:07:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:07:52 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:07:52 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:07:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:07:52 - OpenVPN > /sbin/ifconfig utun3 10.5.167.91 10.5.167.91 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:07:52 - OpenVPN > /sbin/route add -net 10.5.167.0 10.5.167.91 255.255.255.0 . 2023.12.20 16:07:52 - OpenVPN > add net 10.5.167.0: gateway 10.5.167.91 . 2023.12.20 16:07:52 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1a7::1059/64 mtu 1500 up . 2023.12.20 16:07:52 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1a7::/64 -> fde6:7a:7d20:1a7::1059 metric 0) dev utun3 . 2023.12.20 16:07:52 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1a7:: -prefixlen 64 -iface utun3 . 2023.12.20 16:07:52 - OpenVPN > add net fde6:7a:7d20:1a7::: gateway utun3: File exists . 2023.12.20 16:07:52 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:07:52 - DNS of a network adapter forced (Ethernet, from Automatic to 10.5.167.1, fde6:7a:7d20:1a7::1) . 2023.12.20 16:07:52 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.5.167.1, fde6:7a:7d20:1a7::1) . 2023.12.20 16:07:52 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.5.167.1, fde6:7a:7d20:1a7::1) . 2023.12.20 16:07:52 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.5.167.1, fde6:7a:7d20:1a7::1) . 2023.12.20 16:07:52 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:07:52 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:07:52 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:07:53 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:07:53 - Routes, add 91.231.84.41/32 for interface "utun3". . 2023.12.20 16:07:53 - Routes, add 2a02:128:2:4:32c3:4ef6:19b9:149b/128 for interface "utun3". . 2023.12.20 16:07:53 - Flushing DNS I 2023.12.20 16:07:53 - Checking route IPv4 I 2023.12.20 16:07:55 - Checking route IPv6 I 2023.12.20 16:07:57 - Checking DNS ! 2023.12.20 16:08:03 - Connected. ! 2023.12.20 16:09:06 - Disconnecting . 2023.12.20 16:09:06 - Sending soft termination signal . 2023.12.20 16:09:06 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:09:06 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:09:06 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1a7::1059 . 2023.12.20 16:09:06 - OpenVPN > delete host fde6:7a:7d20:1a7::1059 . 2023.12.20 16:09:06 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:09:06 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:09:06 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:09:06 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:09:06 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:09:06 - Routes, delete 91.231.84.43/32 for interface "en1". . 2023.12.20 16:09:06 - Routes, delete 91.231.84.41/32 for interface "utun3", not exists. . 2023.12.20 16:09:06 - Routes, delete 2a02:128:2:4:32c3:4ef6:19b9:149b/128 for interface "utun3", not exists. . 2023.12.20 16:09:06 - Routes, delete 91.231.84.43/32 for interface "en1", not exists. . 2023.12.20 16:09:06 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:09:06 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:09:06 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:09:06 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:09:06 - Connection terminated. . 2023.12.20 16:09:06 - Flushing DNS ! 2023.12.20 16:09:06 - Session terminated. I 2023.12.20 16:09:09 - Session starting. I 2023.12.20 16:09:09 - Checking authorization ... ! 2023.12.20 16:09:10 - Connecting to Canes (Romania, Bucharest) . 2023.12.20 16:09:10 - Routes, add 86.105.9.69/32 for interface "en1". . 2023.12.20 16:09:10 - Routes, add 86.105.9.69/32 for interface "en1", already exists. . 2023.12.20 16:09:10 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:09:10 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:09:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:09:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:09:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:09:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:09:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]86.105.9.69:443 . 2023.12.20 16:09:10 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:09:10 - OpenVPN > Attempting to establish TCP connection with [AF_INET]86.105.9.69:443 [nonblock] . 2023.12.20 16:09:10 - OpenVPN > TCP connection established with [AF_INET]86.105.9.69:443 . 2023.12.20 16:09:10 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:09:10 - OpenVPN > TCP_CLIENT link remote: [AF_INET]86.105.9.69:443 . 2023.12.20 16:09:11 - OpenVPN > TLS: Initial packet from [AF_INET]86.105.9.69:443, sid=c3aadb3f 84744d56 . 2023.12.20 16:09:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:09:11 - OpenVPN > VERIFY KU OK . 2023.12.20 16:09:11 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:09:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:09:11 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:09:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Canes, emailAddress=info@airvpn.org . 2023.12.20 16:09:11 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:09:11 - OpenVPN > [Canes] Peer Connection Initiated with [AF_INET]86.105.9.69:443 . 2023.12.20 16:09:12 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:09:12 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:09:12 - OpenVPN > SENT CONTROL [Canes]: 'PUSH_REQUEST' (status=1) . 2023.12.20 16:09:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.12.71.1,dhcp-option DNS6 fde6:7a:7d20:847::1,tun-ipv6,route-gateway 10.12.71.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:847::1035/64 fde6:7a:7d20:847::1,ifconfig 10.12.71.55 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:09:12 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:09:12 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.12.71.1' . 2023.12.20 16:09:12 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:847::1' . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:09:12 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:09:12 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:09:12 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:09:12 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:09:12 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:09:12 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:09:12 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:09:12 - OpenVPN > /sbin/ifconfig utun3 10.12.71.55 10.12.71.55 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:09:12 - OpenVPN > /sbin/route add -net 10.12.71.0 10.12.71.55 255.255.255.0 . 2023.12.20 16:09:12 - OpenVPN > add net 10.12.71.0: gateway 10.12.71.55 . 2023.12.20 16:09:12 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:847::1035/64 mtu 1500 up . 2023.12.20 16:09:12 - OpenVPN > add_route_ipv6(fde6:7a:7d20:847::/64 -> fde6:7a:7d20:847::1035 metric 0) dev utun3 . 2023.12.20 16:09:12 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:847:: -prefixlen 64 -iface utun3 . 2023.12.20 16:09:12 - OpenVPN > add net fde6:7a:7d20:847::: gateway utun3: File exists . 2023.12.20 16:09:12 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:09:12 - DNS of a network adapter forced (Ethernet, from Automatic to 10.12.71.1, fde6:7a:7d20:847::1) . 2023.12.20 16:09:12 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.12.71.1, fde6:7a:7d20:847::1) . 2023.12.20 16:09:12 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.12.71.1, fde6:7a:7d20:847::1) . 2023.12.20 16:09:12 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.12.71.1, fde6:7a:7d20:847::1) . 2023.12.20 16:09:12 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:09:13 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:09:13 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:09:13 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:09:13 - Routes, add 86.105.9.67/32 for interface "utun3". . 2023.12.20 16:09:13 - Routes, add 2a04:9dc0:c1:131:c7bc:6837:5008:ba7a/128 for interface "utun3". . 2023.12.20 16:09:13 - Flushing DNS I 2023.12.20 16:09:13 - Checking route IPv4 I 2023.12.20 16:09:14 - Checking route IPv6 I 2023.12.20 16:09:16 - Checking DNS ! 2023.12.20 16:09:19 - Connected. ! 2023.12.20 16:09:52 - Disconnecting . 2023.12.20 16:09:52 - Sending soft termination signal . 2023.12.20 16:09:52 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:09:52 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:09:52 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:847::1035 . 2023.12.20 16:09:52 - OpenVPN > delete host fde6:7a:7d20:847::1035 . 2023.12.20 16:09:52 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:09:53 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:09:53 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:09:53 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:09:53 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:09:53 - Routes, delete 86.105.9.69/32 for interface "en1". . 2023.12.20 16:09:53 - Routes, delete 86.105.9.67/32 for interface "utun3", not exists. . 2023.12.20 16:09:53 - Routes, delete 2a04:9dc0:c1:131:c7bc:6837:5008:ba7a/128 for interface "utun3", not exists. . 2023.12.20 16:09:53 - Routes, delete 86.105.9.69/32 for interface "en1", not exists. . 2023.12.20 16:09:53 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:09:53 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:09:53 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:09:53 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:09:53 - Connection terminated. . 2023.12.20 16:09:53 - Flushing DNS ! 2023.12.20 16:09:53 - Session terminated. I 2023.12.20 16:09:58 - Session starting. I 2023.12.20 16:09:58 - Checking authorization ... ! 2023.12.20 16:09:59 - Connecting to Dubhe (Germany, Frankfurt) . 2023.12.20 16:09:59 - Routes, add 141.98.102.245/32 for interface "en1". . 2023.12.20 16:09:59 - Routes, add 141.98.102.245/32 for interface "en1", already exists. . 2023.12.20 16:09:59 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:09:59 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:09:59 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:09:59 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:09:59 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:09:59 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:09:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]141.98.102.245:443 . 2023.12.20 16:09:59 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:09:59 - OpenVPN > Attempting to establish TCP connection with [AF_INET]141.98.102.245:443 [nonblock] . 2023.12.20 16:09:59 - OpenVPN > TCP connection established with [AF_INET]141.98.102.245:443 . 2023.12.20 16:09:59 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:09:59 - OpenVPN > TCP_CLIENT link remote: [AF_INET]141.98.102.245:443 . 2023.12.20 16:09:59 - OpenVPN > TLS: Initial packet from [AF_INET]141.98.102.245:443, sid=f76c41f8 02c61943 . 2023.12.20 16:10:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:10:00 - OpenVPN > VERIFY KU OK . 2023.12.20 16:10:00 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:10:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:10:00 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:10:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Dubhe, emailAddress=info@airvpn.org . 2023.12.20 16:10:00 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:10:00 - OpenVPN > [Dubhe] Peer Connection Initiated with [AF_INET]141.98.102.245:443 . 2023.12.20 16:10:00 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:10:00 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:10:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.7.1,dhcp-option DNS6 fde6:7a:7d20:1607::1,tun-ipv6,route-gateway 10.26.7.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1607::10e6/64 fde6:7a:7d20:1607::1,ifconfig 10.26.7.232 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:10:00 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:10:00 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.26.7.1' . 2023.12.20 16:10:00 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1607::1' . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:10:00 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:10:00 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:10:00 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:10:00 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:10:00 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:10:00 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:10:00 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:10:00 - OpenVPN > /sbin/ifconfig utun3 10.26.7.232 10.26.7.232 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:10:00 - OpenVPN > /sbin/route add -net 10.26.7.0 10.26.7.232 255.255.255.0 . 2023.12.20 16:10:00 - OpenVPN > add net 10.26.7.0: gateway 10.26.7.232 . 2023.12.20 16:10:00 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1607::10e6/64 mtu 1500 up . 2023.12.20 16:10:00 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1607::/64 -> fde6:7a:7d20:1607::10e6 metric 0) dev utun3 . 2023.12.20 16:10:00 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1607:: -prefixlen 64 -iface utun3 . 2023.12.20 16:10:00 - OpenVPN > add net fde6:7a:7d20:1607::: gateway utun3: File exists . 2023.12.20 16:10:00 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:10:01 - DNS of a network adapter forced (Ethernet, from Automatic to 10.26.7.1, fde6:7a:7d20:1607::1) . 2023.12.20 16:10:01 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.26.7.1, fde6:7a:7d20:1607::1) . 2023.12.20 16:10:01 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.26.7.1, fde6:7a:7d20:1607::1) . 2023.12.20 16:10:01 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.26.7.1, fde6:7a:7d20:1607::1) . 2023.12.20 16:10:01 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:10:01 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:10:01 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:10:01 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:10:01 - Routes, add 141.98.102.243/32 for interface "utun3". . 2023.12.20 16:10:01 - Routes, add 2001:ac8:20:9a:95b2:21aa:48b5:7069/128 for interface "utun3". . 2023.12.20 16:10:01 - Flushing DNS I 2023.12.20 16:10:01 - Checking route IPv4 I 2023.12.20 16:10:02 - Checking route IPv6 I 2023.12.20 16:10:04 - Checking DNS ! 2023.12.20 16:10:06 - Connected. ! 2023.12.20 16:10:38 - Disconnecting . 2023.12.20 16:10:38 - Sending soft termination signal . 2023.12.20 16:10:38 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:10:38 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:10:38 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1607::10e6 . 2023.12.20 16:10:38 - OpenVPN > delete host fde6:7a:7d20:1607::10e6 . 2023.12.20 16:10:38 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:10:38 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:10:38 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:10:38 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:10:38 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:10:39 - Routes, delete 141.98.102.245/32 for interface "en1". . 2023.12.20 16:10:39 - Routes, delete 141.98.102.243/32 for interface "utun3", not exists. . 2023.12.20 16:10:39 - Routes, delete 2001:ac8:20:9a:95b2:21aa:48b5:7069/128 for interface "utun3", not exists. . 2023.12.20 16:10:39 - Routes, delete 141.98.102.245/32 for interface "en1", not exists. . 2023.12.20 16:10:39 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:10:39 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:10:39 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:10:39 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:10:39 - Connection terminated. . 2023.12.20 16:10:39 - Flushing DNS ! 2023.12.20 16:10:39 - Session terminated. I 2023.12.20 16:10:42 - Session starting. I 2023.12.20 16:10:42 - Checking authorization ... ! 2023.12.20 16:10:43 - Connecting to Taurus (Spain, Madrid) . 2023.12.20 16:10:43 - Routes, add 194.99.104.37/32 for interface "en1". . 2023.12.20 16:10:43 - Routes, add 194.99.104.37/32 for interface "en1", already exists. . 2023.12.20 16:10:43 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:10:43 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:10:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:10:43 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:10:43 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:10:43 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:10:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.99.104.37:443 . 2023.12.20 16:10:43 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:10:43 - OpenVPN > Attempting to establish TCP connection with [AF_INET]194.99.104.37:443 [nonblock] . 2023.12.20 16:10:43 - OpenVPN > TCP connection established with [AF_INET]194.99.104.37:443 . 2023.12.20 16:10:43 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:10:43 - OpenVPN > TCP_CLIENT link remote: [AF_INET]194.99.104.37:443 . 2023.12.20 16:10:43 - OpenVPN > TLS: Initial packet from [AF_INET]194.99.104.37:443, sid=986d1d6f 309bec20 . 2023.12.20 16:10:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:10:44 - OpenVPN > VERIFY KU OK . 2023.12.20 16:10:44 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:10:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:10:44 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:10:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Taurus, emailAddress=info@airvpn.org . 2023.12.20 16:10:44 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:10:44 - OpenVPN > [Taurus] Peer Connection Initiated with [AF_INET]194.99.104.37:443 . 2023.12.20 16:10:45 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:10:45 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:10:45 - OpenVPN > SENT CONTROL [Taurus]: 'PUSH_REQUEST' (status=1) . 2023.12.20 16:10:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.33.39.1,dhcp-option DNS6 fde6:7a:7d20:1d27::1,tun-ipv6,route-gateway 10.33.39.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1d27::105c/64 fde6:7a:7d20:1d27::1,ifconfig 10.33.39.94 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:10:45 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:10:45 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.33.39.1' . 2023.12.20 16:10:45 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1d27::1' . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:10:45 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:10:45 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:10:45 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:10:45 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:10:45 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:10:45 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:10:45 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:10:45 - OpenVPN > /sbin/ifconfig utun3 10.33.39.94 10.33.39.94 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:10:45 - OpenVPN > /sbin/route add -net 10.33.39.0 10.33.39.94 255.255.255.0 . 2023.12.20 16:10:45 - OpenVPN > add net 10.33.39.0: gateway 10.33.39.94 . 2023.12.20 16:10:45 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1d27::105c/64 mtu 1500 up . 2023.12.20 16:10:45 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1d27::/64 -> fde6:7a:7d20:1d27::105c metric 0) dev utun3 . 2023.12.20 16:10:45 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1d27:: -prefixlen 64 -iface utun3 . 2023.12.20 16:10:45 - OpenVPN > add net fde6:7a:7d20:1d27::: gateway utun3: File exists . 2023.12.20 16:10:45 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:10:45 - DNS of a network adapter forced (Ethernet, from Automatic to 10.33.39.1, fde6:7a:7d20:1d27::1) . 2023.12.20 16:10:45 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.33.39.1, fde6:7a:7d20:1d27::1) . 2023.12.20 16:10:45 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.33.39.1, fde6:7a:7d20:1d27::1) . 2023.12.20 16:10:45 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.33.39.1, fde6:7a:7d20:1d27::1) . 2023.12.20 16:10:45 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:10:45 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:10:45 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:10:45 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:10:45 - Routes, add 194.99.104.35/32 for interface "utun3". . 2023.12.20 16:10:45 - Routes, add 2001:ac8:23:11:bc89:45cc:7672:58e6/128 for interface "utun3". . 2023.12.20 16:10:45 - Flushing DNS I 2023.12.20 16:10:45 - Checking route IPv4 I 2023.12.20 16:10:47 - Checking route IPv6 I 2023.12.20 16:10:49 - Checking DNS ! 2023.12.20 16:10:51 - Connected. ! 2023.12.20 16:12:03 - Disconnecting . 2023.12.20 16:12:03 - Sending soft termination signal . 2023.12.20 16:12:03 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:12:03 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:12:03 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1d27::105c . 2023.12.20 16:12:03 - OpenVPN > delete host fde6:7a:7d20:1d27::105c . 2023.12.20 16:12:03 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:12:03 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:12:03 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:12:03 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:12:03 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:12:03 - Routes, delete 194.99.104.37/32 for interface "en1". . 2023.12.20 16:12:04 - Routes, delete 194.99.104.35/32 for interface "utun3", not exists. . 2023.12.20 16:12:04 - Routes, delete 2001:ac8:23:11:bc89:45cc:7672:58e6/128 for interface "utun3", not exists. . 2023.12.20 16:12:04 - Routes, delete 194.99.104.37/32 for interface "en1", not exists. . 2023.12.20 16:12:04 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:12:04 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:12:04 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:12:04 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:12:04 - Connection terminated. . 2023.12.20 16:12:04 - Flushing DNS ! 2023.12.20 16:12:04 - Session terminated. I 2023.12.20 16:12:07 - Session starting. I 2023.12.20 16:12:07 - Checking authorization ... ! 2023.12.20 16:12:08 - Connecting to Ainalrami (Japan, Tokyo) . 2023.12.20 16:12:08 - Routes, add 45.87.213.85/32 for interface "en1". . 2023.12.20 16:12:08 - Routes, add 45.87.213.85/32 for interface "en1", already exists. . 2023.12.20 16:12:08 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:12:08 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:12:08 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:12:08 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:12:08 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:12:08 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:12:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]45.87.213.85:443 . 2023.12.20 16:12:08 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:12:08 - OpenVPN > Attempting to establish TCP connection with [AF_INET]45.87.213.85:443 [nonblock] . 2023.12.20 16:12:08 - OpenVPN > TCP connection established with [AF_INET]45.87.213.85:443 . 2023.12.20 16:12:08 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:12:08 - OpenVPN > TCP_CLIENT link remote: [AF_INET]45.87.213.85:443 . 2023.12.20 16:12:08 - OpenVPN > TLS: Initial packet from [AF_INET]45.87.213.85:443, sid=e27dac61 868e6f18 . 2023.12.20 16:12:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:12:09 - OpenVPN > VERIFY KU OK . 2023.12.20 16:12:09 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:12:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:12:09 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:12:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ainalrami, emailAddress=info@airvpn.org . 2023.12.20 16:12:10 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:12:10 - OpenVPN > [Ainalrami] Peer Connection Initiated with [AF_INET]45.87.213.85:443 . 2023.12.20 16:12:11 - OpenVPN > SENT CONTROL [Ainalrami]: 'PUSH_REQUEST' (status=1) . 2023.12.20 16:12:11 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:12:11 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:12:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.231.1,dhcp-option DNS6 fde6:7a:7d20:1ee7::1,tun-ipv6,route-gateway 10.34.231.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1ee7::1009/64 fde6:7a:7d20:1ee7::1,ifconfig 10.34.231.11 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:12:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:12:11 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.34.231.1' . 2023.12.20 16:12:11 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1ee7::1' . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:12:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:12:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:12:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:12:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:12:11 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:12:11 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:12:11 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:12:11 - OpenVPN > /sbin/ifconfig utun3 10.34.231.11 10.34.231.11 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:12:11 - OpenVPN > /sbin/route add -net 10.34.231.0 10.34.231.11 255.255.255.0 . 2023.12.20 16:12:11 - OpenVPN > add net 10.34.231.0: gateway 10.34.231.11 . 2023.12.20 16:12:11 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1ee7::1009/64 mtu 1500 up . 2023.12.20 16:12:11 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1ee7::/64 -> fde6:7a:7d20:1ee7::1009 metric 0) dev utun3 . 2023.12.20 16:12:11 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1ee7:: -prefixlen 64 -iface utun3 . 2023.12.20 16:12:11 - OpenVPN > add net fde6:7a:7d20:1ee7::: gateway utun3: File exists . 2023.12.20 16:12:11 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:12:11 - DNS of a network adapter forced (Ethernet, from Automatic to 10.34.231.1, fde6:7a:7d20:1ee7::1) . 2023.12.20 16:12:11 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.34.231.1, fde6:7a:7d20:1ee7::1) . 2023.12.20 16:12:11 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.34.231.1, fde6:7a:7d20:1ee7::1) . 2023.12.20 16:12:11 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.34.231.1, fde6:7a:7d20:1ee7::1) . 2023.12.20 16:12:11 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:12:11 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:12:11 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:12:11 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:12:12 - Routes, add 45.87.213.83/32 for interface "utun3". . 2023.12.20 16:12:12 - Routes, add 2001:ac8:40:96:be6d:6aec:5e7f:aef1/128 for interface "utun3". . 2023.12.20 16:12:12 - Flushing DNS I 2023.12.20 16:12:12 - Checking route IPv4 I 2023.12.20 16:12:13 - Checking route IPv6 I 2023.12.20 16:12:16 - Checking DNS ! 2023.12.20 16:12:20 - Connected. ! 2023.12.20 16:13:03 - Disconnecting . 2023.12.20 16:13:03 - Sending soft termination signal . 2023.12.20 16:13:03 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:13:03 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:13:03 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1ee7::1009 . 2023.12.20 16:13:03 - OpenVPN > delete host fde6:7a:7d20:1ee7::1009 . 2023.12.20 16:13:03 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:13:03 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:13:03 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:13:03 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:13:03 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:13:04 - Routes, delete 45.87.213.85/32 for interface "en1". . 2023.12.20 16:13:04 - Routes, delete 45.87.213.83/32 for interface "utun3", not exists. . 2023.12.20 16:13:04 - Routes, delete 2001:ac8:40:96:be6d:6aec:5e7f:aef1/128 for interface "utun3", not exists. . 2023.12.20 16:13:04 - Routes, delete 45.87.213.85/32 for interface "en1", not exists. . 2023.12.20 16:13:04 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:13:04 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:13:04 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:13:04 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:13:04 - Connection terminated. . 2023.12.20 16:13:04 - Flushing DNS ! 2023.12.20 16:13:04 - Session terminated. I 2023.12.20 16:13:08 - Session starting. I 2023.12.20 16:13:08 - Checking authorization ... ! 2023.12.20 16:13:08 - Connecting to Markab (Czechia, Prague) . 2023.12.20 16:13:08 - Routes, add 185.156.174.29/32 for interface "en1". . 2023.12.20 16:13:08 - Routes, add 185.156.174.29/32 for interface "en1", already exists. . 2023.12.20 16:13:09 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:13:09 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:13:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:13:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:13:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:13:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:13:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.174.29:443 . 2023.12.20 16:13:09 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:13:09 - OpenVPN > Attempting to establish TCP connection with [AF_INET]185.156.174.29:443 [nonblock] . 2023.12.20 16:13:09 - OpenVPN > TCP connection established with [AF_INET]185.156.174.29:443 . 2023.12.20 16:13:09 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:13:09 - OpenVPN > TCP_CLIENT link remote: [AF_INET]185.156.174.29:443 . 2023.12.20 16:13:09 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.174.29:443, sid=b46677bf 4a2b7e8d ! 2023.12.20 16:13:09 - Disconnecting . 2023.12.20 16:13:09 - Sending soft termination signal . 2023.12.20 16:13:09 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:13:09 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:13:09 - Routes, delete 185.156.174.29/32 for interface "en1". . 2023.12.20 16:13:09 - Routes, delete 185.156.174.29/32 for interface "en1", not exists. . 2023.12.20 16:13:09 - Connection terminated. I 2023.12.20 16:13:09 - Cancel requested. ! 2023.12.20 16:13:09 - Session terminated. I 2023.12.20 16:13:13 - Session starting. I 2023.12.20 16:13:13 - Checking authorization ... ! 2023.12.20 16:13:13 - Connecting to Fulu (Brazil, Sao Paulo) . 2023.12.20 16:13:13 - Routes, add 146.70.163.93/32 for interface "en1". . 2023.12.20 16:13:13 - Routes, add 146.70.163.93/32 for interface "en1", already exists. . 2023.12.20 16:13:14 - OpenVPN > OpenVPN 2.5.5 x86_64-apple-darwin19.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb 8 2022 . 2023.12.20 16:13:14 - OpenVPN > library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 . 2023.12.20 16:13:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:13:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:13:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.12.20 16:13:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.12.20 16:13:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]146.70.163.93:443 . 2023.12.20 16:13:14 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144] . 2023.12.20 16:13:14 - OpenVPN > Attempting to establish TCP connection with [AF_INET]146.70.163.93:443 [nonblock] . 2023.12.20 16:13:14 - OpenVPN > TCP connection established with [AF_INET]146.70.163.93:443 . 2023.12.20 16:13:14 - OpenVPN > TCP_CLIENT link local: (not bound) . 2023.12.20 16:13:14 - OpenVPN > TCP_CLIENT link remote: [AF_INET]146.70.163.93:443 . 2023.12.20 16:13:14 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.163.93:443, sid=f1cd4214 9a82e9f8 . 2023.12.20 16:13:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2023.12.20 16:13:14 - OpenVPN > VERIFY KU OK . 2023.12.20 16:13:14 - OpenVPN > Validating certificate extended key usage . 2023.12.20 16:13:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2023.12.20 16:13:14 - OpenVPN > VERIFY EKU OK . 2023.12.20 16:13:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Fulu, emailAddress=info@airvpn.org . 2023.12.20 16:13:15 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2023.12.20 16:13:15 - OpenVPN > [Fulu] Peer Connection Initiated with [AF_INET]146.70.163.93:443 . 2023.12.20 16:13:16 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2023.12.20 16:13:16 - OpenVPN > Error: route: writing to routing socket: File exists . 2023.12.20 16:13:16 - OpenVPN > SENT CONTROL [Fulu]: 'PUSH_REQUEST' (status=1) . 2023.12.20 16:13:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.39.1,dhcp-option DNS6 fde6:7a:7d20:1c27::1,tun-ipv6,route-gateway 10.32.39.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1c27::101a/64 fde6:7a:7d20:1c27::1,ifconfig 10.32.39.28 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2023.12.20 16:13:16 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2023.12.20 16:13:16 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.32.39.1' . 2023.12.20 16:13:16 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1c27::1' . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: peer-id set . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2023.12.20 16:13:16 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2023.12.20 16:13:16 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2023.12.20 16:13:16 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:13:16 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2023.12.20 16:13:16 - OpenVPN > Opened utun device utun3 . 2023.12.20 16:13:16 - OpenVPN > /sbin/ifconfig utun3 delete . 2023.12.20 16:13:16 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2023.12.20 16:13:16 - OpenVPN > /sbin/ifconfig utun3 10.32.39.28 10.32.39.28 netmask 255.255.255.0 mtu 1500 up . 2023.12.20 16:13:16 - OpenVPN > /sbin/route add -net 10.32.39.0 10.32.39.28 255.255.255.0 . 2023.12.20 16:13:16 - OpenVPN > add net 10.32.39.0: gateway 10.32.39.28 . 2023.12.20 16:13:16 - OpenVPN > /sbin/ifconfig utun3 inet6 fde6:7a:7d20:1c27::101a/64 mtu 1500 up . 2023.12.20 16:13:16 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1c27::/64 -> fde6:7a:7d20:1c27::101a metric 0) dev utun3 . 2023.12.20 16:13:16 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1c27:: -prefixlen 64 -iface utun3 . 2023.12.20 16:13:16 - OpenVPN > add net fde6:7a:7d20:1c27::: gateway utun3: File exists . 2023.12.20 16:13:16 - OpenVPN > Initialization Sequence Completed . 2023.12.20 16:13:16 - DNS of a network adapter forced (Ethernet, from Automatic to 10.32.39.1, fde6:7a:7d20:1c27::1) . 2023.12.20 16:13:16 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.32.39.1, fde6:7a:7d20:1c27::1) . 2023.12.20 16:13:16 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.32.39.1, fde6:7a:7d20:1c27::1) . 2023.12.20 16:13:16 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.32.39.1, fde6:7a:7d20:1c27::1) . 2023.12.20 16:13:16 - Routes, add 0.0.0.0/1 for interface "utun3". . 2023.12.20 16:13:16 - Routes, add 128.0.0.0/1 for interface "utun3". . 2023.12.20 16:13:16 - Routes, add ::/1 for interface "utun3". . 2023.12.20 16:13:16 - Routes, add 8000::/1 for interface "utun3". . 2023.12.20 16:13:16 - Routes, add 146.70.163.91/32 for interface "utun3". . 2023.12.20 16:13:16 - Routes, add 2a0d:5600:75:25:7e61:a643:dfaa:c11c/128 for interface "utun3". . 2023.12.20 16:13:16 - Flushing DNS I 2023.12.20 16:13:16 - Checking route IPv4 I 2023.12.20 16:13:18 - Checking route IPv6 I 2023.12.20 16:13:20 - Checking DNS ! 2023.12.20 16:13:23 - Connected. ! 2023.12.20 16:14:16 - Disconnecting . 2023.12.20 16:14:16 - Sending soft termination signal . 2023.12.20 16:14:16 - OpenVPN > event_wait : Interrupted system call (code=4) . 2023.12.20 16:14:16 - OpenVPN > Closing TUN/TAP interface . 2023.12.20 16:14:16 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1c27::101a . 2023.12.20 16:14:16 - OpenVPN > delete host fde6:7a:7d20:1c27::101a . 2023.12.20 16:14:16 - OpenVPN > SIGINT[hard,] received, process exiting . 2023.12.20 16:14:16 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:14:16 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists. . 2023.12.20 16:14:16 - Routes, delete ::/1 for interface "utun3", not exists. . 2023.12.20 16:14:16 - Routes, delete 8000::/1 for interface "utun3", not exists. . 2023.12.20 16:14:16 - Routes, delete 146.70.163.93/32 for interface "en1". . 2023.12.20 16:14:16 - Routes, delete 146.70.163.91/32 for interface "utun3", not exists. . 2023.12.20 16:14:17 - Routes, delete 2a0d:5600:75:25:7e61:a643:dfaa:c11c/128 for interface "utun3", not exists. . 2023.12.20 16:14:17 - Routes, delete 146.70.163.93/32 for interface "en1", not exists. . 2023.12.20 16:14:17 - DNS of a network adapter restored to original settings (Ethernet, to Automatic) . 2023.12.20 16:14:17 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic) . 2023.12.20 16:14:17 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2023.12.20 16:14:17 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic) . 2023.12.20 16:14:17 - Connection terminated. . 2023.12.20 16:14:17 - Flushing DNS ! 2023.12.20 16:14:17 - Session terminated. Quote Share this post Link to post
Staff 10336 Posted ... @weelilbit Hello! Three servers in three different locations around your node should be more than enough. The problem unfortunately persists. Can you please test with Tunnelblick, just to make sure that the problem is not a specific block against Eddie (from some tool like LittleSnitch for example), or in general a specific Eddie related problem? Tunnelblick is a free and open source software for Mac, a wrapper and a GUI to OpenVPN, you can find instructions here:https://airvpn.org/macos/tunnelblick/ Kind regards Quote Share this post Link to post
weelilbit 0 Posted ... Worked through the instructions link and when I went to complete the final step and initiate the connection, I received a pop-up message: • DNS server address fde6:7a:7d20:1126::1 is not being used but was expected to be used for VPN 'AirVPN_All-servers_UDP-443-Entry3'. Quote Share this post Link to post
Staff 10336 Posted ... 10 hours ago, weelilbit said: Worked through the instructions link and when I went to complete the final step and initiate the connection, I received a pop-up message: • DNS server address fde6:7a:7d20:1126::1 is not being used but was expected to be used for VPN 'AirVPN_All-servers_UDP-443-Entry3'. Hello! OK, we suspect that's irrelevant. What about the connection and the throughput? Kind regards Quote Share this post Link to post
