Slow Poke 3 Posted ... It seems that Reddit has imposed an overnight block on most Japan and Singapore servers. I did not take screenshots of all the blocked ones, but testing shows that only 1 Japan server and 2 or 3 Singapore servers are still unblocked as of this post. AFAIK, the blocking was not in place this time yesterday. Quote Share this post Link to post
monstrocity 37 Posted ... I have the same issue, and I hope there's a solution besides disconnecting from the VPN server or resorting to Tor just to peruse a few Reddit comments. It seems every day more and more restrictions / blocks are being applied to AirVPN IP ranges, probably other VPN providers as well. The number of websites I encounter being blocked by Cloudflare, Sucuri, or GoDaddy increases by the day. It's getting ridiculous. 2 hondagt and Valerian reacted to this Quote Share this post Link to post
Staff 10500 Posted ... Hello! This looks like a relatively new Reddit policy, not specifically aimed at VPN, but at any IP address not assigned to residential ISPs. In this case access is granted but only after you have logged in. Just tested from all Japan servers, including Taphao, and we could access. After the login all Reddit is accessible, as far as we see. To maintain a robust anonymity layer in Reddit you need an anonymous e-mail address created with the protection of AirVPN and/or Tor, of course. Follow the instructions you have published in your screenshots to login (the login page does not block access from Tor or VPN or datacenters). Two years ago Reddit started to prevent users to post more than a comment every 10 minutes if the connection came from a datacenter IP address ("if you are accessing from an hosting provider" hints to any non-residential IP address). The behavior you report seems quite new and we confirm that it happens even from dedicated servers completely unrelated from our VPN activities. However the system is still coughing because, on the other hand, as @mazurka7 correctly wrote, some VPN servers are not subjected to this filter. Kind regards 2 airvpn_8735g7bshdfs and Wolf666 reacted to this Quote Share this post Link to post
yyyzzz 0 Posted ... You can also get around this by using the old Reddit interface (just replace "www" with "old" in the URL). Quote Share this post Link to post
Huddling3504 3 Posted ... (edited) I just found out how to detour the blocking without using old.reddit.com. All you have to do is make a cookie following the next rules: - domain: .reddit.com - name: reddit_session - value: any value as you want. It supposed to have your Reddit session data, but it can be anything just to detour the blocking. e.g., 0 - path: / I used cookiebro extension to import and export a cookie but how to add a cookie is up to you. It is naive but it works anyway. I hope it helps, and they don't block this solution too soon. Or maybe you can use the cookiebro-cookie-.reddit.com-reddit_session.json which I confirmed working on firefox and chromium. Edited ... by Huddling3504 Attach cookie json file 2 1 IG-11, cyanocorax and monstrocity reacted to this Quote Share this post Link to post
monstrocity 37 Posted ... On 12/9/2023 at 10:34 AM, Huddling3504 said: I just found out how to detour the blocking without using old.reddit.com. All you have to do is make a cookie following the next rules: - domain: .reddit.com - name: reddit_session - value: any value as you want. It supposed to have your Reddit session data, but it can be anything just to detour the blocking. e.g., 0 - path: / I used cookiebro extension to import and export a cookie but how to add a cookie is up to you. It is naive but it works anyway. I hope it helps, and they don't block this solution too soon. Or maybe you can use the cookiebro-cookie-.reddit.com-reddit_session.json which I confirmed working on firefox and chromium. I got this to work in Brave but not in Firefox ESR. Quote Share this post Link to post
Zerolight 2 Posted ... On 12/9/2023 at 5:34 AM, Huddling3504 said: I just found out how to detour the blocking without using old.reddit.com. All you have to do is make a cookie following the next rules: - domain: .reddit.com - name: reddit_session - value: any value as you want. It supposed to have your Reddit session data, but it can be anything just to detour the blocking. e.g., 0 - path: / I used cookiebro extension to import and export a cookie but how to add a cookie is up to you. It is naive but it works anyway. I hope it helps, and they don't block this solution too soon. Or maybe you can use the cookiebro-cookie-.reddit.com-reddit_session.json which I confirmed working on firefox and chromium. Threw this together for anyone running userscript with greasemonkey or tampermonkey (tested on chrome only) Change the "EnterValueHere" to something else (once loaded reddit will show block message but refresh again and it will load) // ==UserScript== // @name Create Cookie Userscript for reddit // @version 1.0 // @description Creates a cookie when the page is loaded // @match *://www.reddit.com/* // @grant none // ==/UserScript== (function() { 'use strict'; // Function to create a cookie function createCookie(name, value, days) { var expires = ""; if (days) { var date = new Date(); date.setTime(date.getTime() + (days * 24 * 60 * 60 * 1000)); expires = "; expires=" + date.toGMTString(); } document.cookie = name + "=" + value + expires + "; path=/"; } // Call the createCookie function with your desired cookie name, value, and expiration in days createCookie("reddit_session", "EnterValueHere", 7); // Example: expires in 7 days })(); 2 jazz adams and Slow Poke reacted to this Quote Share this post Link to post
Air4141841 30 Posted ... I guess I am not understanding the issue. or the only one who knows you can click where it says reddit/login. (the first blue hyperlink) login and it works? Quote Share this post Link to post
monstrocity 37 Posted ... 8 hours ago, Air4141841 said: I guess I am not understanding the issue. or the only one who knows you can click where it says reddit/login. (the first blue hyperlink) login and it works? Some people only want to read comments about a particular topic, not be forced to login to read them. Reddit has implemented a soft block for VPN (and I believe Tor) users. If I visit the same Reddit page from my normal IP address, I can read comments without that whole "whoa there pardner..." nonsense. The cookie workarounds still do the trick though. Quote Share this post Link to post
Mordo 10 Posted ... Looks like the old.reddit method doesn't work anymore but found a great solution if you're a ublock origin or adguard user. copy/paste of reddit comment so blocked users can see it. Go to your uBlock Origin / AdGuard filter settings page and add this custom filter (in uBlock Origin it's under the "My filters" tab): reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '0') This will automatically create the reddit_session cookie as described in the post above. You have to make sure that you are using the latest uBlock Origin or AdGuard extension, because the cookie filter syntax has only been added recently to uBlock Origin. (The above filter only works with uBO version 1.53.0 or higher) Here are some more techy details about the cookie filter: It will create a session cookie, which will only last until the browser is closed. (This is good because see 2. and 3.) You will not be able to log-in to reddit while the cookie is set. (Also applies to manual method in the original post) If you want to log-in to reddit, you will have to remove or comment out the custom filter, then close and re-open your browser. Doing this will clear the session cookie and prevent your adblocker from automatically creating the fake session cookie again. You can comment out custom filters by prefixing them with an exclamation mark, e. g.: !reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '0') The cookie value is set to '0', this is a limitation of the new cookie filter syntax. Can't make it empty as of now unfortunately. It works fine with the value set to '0' though. reddit comment 2 1 forfor, caffeine0030 and jazz adams reacted to this Quote Share this post Link to post
VillainsCC 0 Posted ... They've really tightened up a bit this week at reddit. Killed off old.reddit and locked down page bookmarks so that you get the Whoa There Pardner! now as well. Up until the other day it only Whoa'd me on entering through a web link or search result link. This has also broken the search result links for VPN users. You search, see a reddit discussion that pertains to you, you click, reddit calls you Pardner, so you click the login link and your original search link is useless since pasting it into the browser will send you back to the OK Corral. You then have to manually search reddit for the thread DuckDuckGo (for example) told you about. And reddit search isn't that great at searching reddit. Welcome to the new reddit, where no one is welcome. Quote Share this post Link to post
Slow Poke 3 Posted ... On 3/29/2024 at 2:34 AM, Mordo said: Looks like the old.reddit method doesn't work anymore but found a great solution if you're a ublock origin or adguard user. copy/paste of reddit comment so blocked users can see it. Go to your uBlock Origin / AdGuard filter settings page and add this custom filter (in uBlock Origin it's under the "My filters" tab): reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '0') This will automatically create the reddit_session cookie as described in the post above. You have to make sure that you are using the latest uBlock Origin or AdGuard extension, because the cookie filter syntax has only been added recently to uBlock Origin. (The above filter only works with uBO version 1.53.0 or higher) Here are some more techy details about the cookie filter: It will create a session cookie, which will only last until the browser is closed. (This is good because see 2. and 3.) You will not be able to log-in to reddit while the cookie is set. (Also applies to manual method in the original post) If you want to log-in to reddit, you will have to remove or comment out the custom filter, then close and re-open your browser. Doing this will clear the session cookie and prevent your adblocker from automatically creating the fake session cookie again. You can comment out custom filters by prefixing them with an exclamation mark, e. g.: !reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '0') The cookie value is set to '0', this is a limitation of the new cookie filter syntax. Can't make it empty as of now unfortunately. It works fine with the value set to '0' though. reddit comment This seems to have stopped working. Can anyone who is using this confirm? The cookie injection via userscript also doesn't seem to work anymore. Can anyone also confirm that? Quote Share this post Link to post
caffeine0030 1 Posted ... (edited) On 4/8/2024 at 9:38 AM, mazurka7 said: This seems to have stopped working. Can anyone who is using this confirm? The cookie injection via userscript also doesn't seem to work anymore. Can anyone also confirm that? Doesnt work anymore edit: works sometimes on firefox Edited ... by caffeine0030 Quote Share this post Link to post
monstrocity 37 Posted ... cookies json configured with cookiebro extension still works for me in Brave browser. Quote Share this post Link to post
Crewman6639 5 Posted ... I use redlib now to view reddit along with libredirect. Quote Share this post Link to post
Mordo 10 Posted ... Everything still works for me on ublock origin with 1 small adjustment. I think reddit blocked anyone with a Reddit session data value of 0. i use: reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '1') As you can see, the only change is the last number from 0 to 1 and everything works again. 2 5 Slow Poke, forfor, j7j3 and 4 others reacted to this Quote Share this post Link to post
j7j3 7 Posted ... On 4/22/2024 at 11:17 PM, Mordo said: Everything still works for me on ublock origin with 1 small adjustment. I think reddit blocked anyone with a Reddit session data value of 0. i use: reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '1') As you can see, the only change is the last number from 0 to 1 and everything works again. Thanks for that and fsck Reddit 2 BlueBanana and John Gow reacted to this Quote Share this post Link to post
Mordo 10 Posted ... (edited) They blocked all numbers below 6 digits.... reddit.com#%#//scriptlet('set-cookie-reload', 'reddit_session', '123456') They only blocked numbers below 6 digits, a simple "a" will also work. Edited ... by Mordo Quote Share this post Link to post
BishopRed 2 Posted ... They have updated their blocking it seems. The original post now has a comment that works with the latest version of uBlock: Quote Looks like reddit now relies on the format of the cookie value, so simple 0 does not cut it anymore. It's some 8 digit number, followed by a datetime, followed by a uuid, all separated by comma. They're probably performing a split by comma operation and expect it to be 3 items, but don't check the values, so this works: reddit.com#%#//scriptlet('trusted-set-cookie-reload', 'reddit_session', '0,0,0') You have to enable "Allow custom filters requiring trust" and use trusted-set-cookie, as set-cookie-reload does not seem to do anything when supplied with a value of length over 4 characters. 2 jazz adams and cyanocorax reacted to this Quote Share this post Link to post
NooB_wow 0 Posted ... Hi, it looks like after today this won’t work anymore. Does anyone have any ideas? Quote Share this post Link to post
caffeine0030 1 Posted ... On 8/8/2024 at 2:11 AM, BinaryApe said: They have updated their blocking it seems. The original post now has a comment that works with the latest version of uBlock: It appears they are at it again. Anyone know the newest working bypass? Quote Share this post Link to post
Mothball 0 Posted ... I'm still using the filter from the reddit thread and it appears to work without issue. Tested in firefox and chrome. Quote Share this post Link to post
monstrocity 37 Posted ... reddit.com#%#//scriptlet('trusted-set-cookie-reload', 'reddit_session', '0,0,0') In Firefox this still works in Ublock Origin by going into advanced settings - I am an advanced user. Change these two settings: filterAuthorMode true trustedListPrefixes ublock- user- In Brave I don't use Ublock Origin and decided to manually install the LibRedirect extension. which has been blacklisted from the Chrome Webstore of course. Or, I use redlib. (As suggested above by Crewman6639.) If you have Safe Browsing turned off, and Brave keeps cancelling or deleting the LibRedirect crx download, go to brave://flags/ Search for "Override download danger level" and click on Enabled. Quote Share this post Link to post
