readchaoschild 0 Posted ... My school uses fortinet and I cannot use airvpn on it because It is blocked I have tried udp and tcp (both openvpn and wireguard) as well as udp/tcp over ssh and ssl, nothing works I dont really know how to set up proxy/tor but ive tried that to the best of my knowledge i cant get it to work either all of the servers i have used do not work as well, when i try and connect it simply sends a sigterm signal and disconnects. Is there a way to use airvpn on Fortinet? Thanks Quote Share this post Link to post
Staff 10692 Posted ... @readchaoschild Hello! Since Fortinet anti-AirVPN filters essentially rely on blocks of our bootstrap servers, it is usually possible to bypass the block by running OpenVPN directly. You will have to renounce to Eddie and test a connection to port 443 over protocol TCP, with tls-crypt mode. The Configuration Generator will generate the file you need. Specific instructions for all desktop systems in order to use OpenVPN directly or an OpenVPN wrapper are avaialble in the respective OS pages:https://airvpn.org/download Worth a test, let us know... Kind regards Quote Share this post Link to post
ddkjsdjkvdsjkn 0 Posted ... On 12/4/2023 at 11:09 PM, Staff said: @readchaoschild Hello! Since Fortinet anti-AirVPN filters essentially rely on blocks of our bootstrap servers, it is usually possible to bypass the block by running OpenVPN directly. You will have to renounce to Eddie and test a connection to port 443 over protocol TCP, with tls-crypt mode. The Configuration Generator will generate the file you need. Specific instructions for all desktop systems in order to use OpenVPN directly or an OpenVPN wrapper are avaialble in the respective OS pages: https://airvpn.org/download Worth a test, let us know... Kind regards Hello, wondering if this still works. If so, can you guide me on how to set it up please. Thanks. Quote Share this post Link to post
