Koalaman
DBusConnectorException: DBusConnector: not primary owner (2)
Hi, I am always getting this error when I SSH into my Raspberry Pi and try to do stuff with Goldcrest. I have already added "Jack" to the AirVPN group. But it still doesnt work, same error.
jack@jack ~ $ goldcrest --disconnect
Goldcrest - AirVPN Bluetit Client 1.3.0 - 1 June 2023
2023-11-24 17:00:26 Reading run control directives from file /home/jack/.config/goldcrest.rc
2023-11-24 17:00:26 DBusConnectorException: DBusConnector: not primary owner (2)
Any ideas?
Any ideas?
"Not primary owner" hints to some other Goldcrest process already running, can you please check?
Hi:
jack@jack ~ $ ps aux | grep goldcrest
root        3789  0.1  0.1  11584  4280 ?        S    09:48   0:00 su -c goldcrest --air-connect --air-key Seconddevice --air-country Singapore -N off -C CHACHA20-POLY1305 -U Koalaman -P XXXXXX
root        3809  0.1  0.1  85556  3860 ?        Sl   09:48   0:00 goldcrest --air-connect --air-key Seconddevice --air-country Singapore -N off -C CHACHA20-POLY1305 -U Koalaman -P XXXXXX
jack       4122  0.0  0.0   5912   692 pts/0    S+   09:51   0:00 grep goldcrest
jack@jack ~ $
Sorry I dont know too much yet about Linux, still learning day by day.
@Koalaman
The command to disconnect a session is valid if no other Goldcrest process is already running. By Suite's default D-Bus policy only one client can talk to Bluetit at a time, the "primary owner" according to D-Bus terminology.
Goldcrest's disconnect option is originally meant to disconnect a session started by Bluetit autonomously, i.e. when Bluetit is configured to connect at startup. If you need to terminate a current connection established via Goldcrest, you just have to send a SIGTERM or SIGINT to Goldcrest. For example, press CTRL-C on the terminal from which you launched Goldcrest, or send Goldcrest the signal, for example
sudo killall goldcrest
