Hypogeum
No Download Speed, But I get Upload Speed
Sorry for the lengthy log. I've had this issue in the past but can't seem to fix it this time. I'm not sure what the issue is, I've turned off my firewall and anti virus, but those werent it. What am I doing wrong?
. 2023.11.17 06:12:43 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:12:43 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:12:43 - OpenVPN > NETSH: C:\Windows\stem32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:1f27::1082/128 store=active
. 2023.11.17 06:12:44 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1f27::/64 -> fde6:7a:7d20:1f27::1082 metric 0) dev Eddie
. 2023.11.17 06:12:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1f27::/64 42 fe80::8 store=active
. 2023.11.17 06:12:44 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:12:44 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:12:44 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:12:44 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:12:44 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:12:44 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:12:44 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:12:44 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.35.39.1)
. 2023.11.17 06:12:44 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1f27::1)
. 2023.11.17 06:12:45 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:12:45 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:12:45 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:12:46 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:12:46 - Routes, add 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:12:46 - Routes, add 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:12:46 - Flushing DNS
! 2023.11.17 06:12:46 - Connected.
! 2023.11.17 06:12:55 - Disconnecting
. 2023.11.17 06:12:55 - Sending soft termination signal
. 2023.11.17 06:12:58 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:12:58 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1f27::/64)
. 2023.11.17 06:12:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1f27::/64 42 fe80::8 store=active
. 2023.11.17 06:12:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:1f27::1082 store=active
. 2023.11.17 06:12:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.35.39.132 store=active
. 2023.11.17 06:12:59 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2023.11.17 06:12:59 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:13:00 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:13:00 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:13:01 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:13:01 - Routes, delete 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:13:02 - Routes, delete 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:13:02 - Routes, delete 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:13:03 - Routes, delete 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:13:03 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:13:03 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:13:03 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:13:03 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:13:03 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:13:03 - Connection terminated.
. 2023.11.17 06:13:03 - Flushing DNS
! 2023.11.17 06:13:04 - Session terminated.
I 2023.11.17 06:16:46 - Session starting.
I 2023.11.17 06:16:48 - Checking authorization ...
. 2023.11.17 06:16:50 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:16:50 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:16:50 - Connecting to Ross (Canada, Montreal)
. 2023.11.17 06:16:50 - Routes, add 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:16:50 - Routes, add 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:16:50 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:16:50 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:16:50 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:16:50 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:16:50 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:16:50 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:16:50 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:16:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]139.28.218.237:443
. 2023.11.17 06:16:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:16:50 - OpenVPN > Attempting to establish TCP connection with [AF_INET]139.28.218.237:443 [nonblock]
. 2023.11.17 06:16:50 - OpenVPN > TCP connection established with [AF_INET]139.28.218.237:443
. 2023.11.17 06:16:50 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2023.11.17 06:16:50 - OpenVPN > TCP_CLIENT link remote: [AF_INET]139.28.218.237:443
. 2023.11.17 06:16:51 - OpenVPN > TLS: Initial packet from [AF_INET]139.28.218.237:443, sid=d9fe8bf0 6cf32c81
. 2023.11.17 06:16:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:16:51 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:16:51 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:16:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:16:51 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:16:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ross, emailAddress=info@airvpn.org
. 2023.11.17 06:16:51 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:16:51 - OpenVPN > [Ross] Peer Connection Initiated with [AF_INET]139.28.218.237:443
. 2023.11.17 06:16:51 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.35.39.1,dhcp-option DNS6 fde6:7a:7d20:1f27::1,tun-ipv6,route-gateway 10.35.39.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1f27::1082/64 fde6:7a:7d20:1f27::1,ifconfig 10.35.39.132 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2023.11.17 06:16:51 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:16:51 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.35.39.1'
. 2023.11.17 06:16:51 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1f27::1'
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2023.11.17 06:16:51 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:16:51 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:16:51 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:16:51 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:16:51 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:16:51 - OpenVPN > open_tun
. 2023.11.17 06:16:51 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:16:51 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.35.39.132 255.255.255.0
. 2023.11.17 06:16:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:16:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:16:52 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:16:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:1f27::1082/128 store=active
. 2023.11.17 06:16:52 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1f27::/64 -> fde6:7a:7d20:1f27::1082 metric 0) dev Eddie
. 2023.11.17 06:16:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1f27::/64 42 fe80::8 store=active
. 2023.11.17 06:16:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:16:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:16:52 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:16:52 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:16:52 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:16:52 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:16:52 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:16:53 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.35.39.1)
. 2023.11.17 06:16:53 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1f27::1)
. 2023.11.17 06:16:53 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:16:54 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:16:54 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:16:54 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:16:54 - Routes, add 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:16:55 - Routes, add 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:16:55 - Flushing DNS
I 2023.11.17 06:16:55 - Checking DNS
. 2023.11.17 06:17:28 - OpenVPN > read TCP_CLIENT: Unknown error (code=10060)
. 2023.11.17 06:17:28 - OpenVPN > Connection reset, restarting [-1]
. 2023.11.17 06:17:28 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2023.11.17 06:17:28 - OpenVPN > Restart pause, 5 second(s)
. 2023.11.17 06:17:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:17:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:17:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:17:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:17:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]139.28.218.237:443
. 2023.11.17 06:17:28 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:17:28 - OpenVPN > Attempting to establish TCP connection with [AF_INET]139.28.218.237:443 [nonblock]
! 2023.11.17 06:17:28 - Disconnecting
. 2023.11.17 06:17:28 - Sending soft termination signal
. 2023.11.17 06:17:31 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:17:31 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1f27::/64)
. 2023.11.17 06:17:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1f27::/64 42 fe80::8 store=active
. 2023.11.17 06:17:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:1f27::1082 store=active
. 2023.11.17 06:17:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.35.39.132 store=active
. 2023.11.17 06:17:31 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2023.11.17 06:17:31 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:17:32 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:17:32 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:17:32 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:17:33 - Routes, delete 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:17:33 - Routes, delete 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:17:33 - Routes, delete 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:17:34 - Routes, delete 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:17:34 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:17:34 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:17:34 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:17:34 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:17:34 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:17:34 - Connection terminated.
I 2023.11.17 06:17:34 - Cancel requested.
! 2023.11.17 06:17:35 - Session terminated.
I 2023.11.17 06:20:19 - Session starting.
I 2023.11.17 06:20:21 - Checking authorization ...
. 2023.11.17 06:20:23 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:20:23 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:20:23 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:20:23 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:20:23 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:20:24 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:20:24 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:20:24 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:20:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:20:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:20:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:20:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:20:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:20:24 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:20:24 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:20:24 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:20:24 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=2f3da7a1 4d52aef8
. 2023.11.17 06:20:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:20:24 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:20:24 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:20:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:20:24 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:20:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:20:24 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:20:24 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:20:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.230.1,dhcp-option DNS6 fde6:7a:7d20:12e6::1,tun-ipv6,route-gateway 10.22.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e6::108d/64 fde6:7a:7d20:12e6::1,ifconfig 10.22.230.143 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2023.11.17 06:20:24 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:20:24 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.230.1'
. 2023.11.17 06:20:24 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e6::1'
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:20:24 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:20:24 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:20:24 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:20:24 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:20:24 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:20:24 - OpenVPN > open_tun
. 2023.11.17 06:20:24 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:20:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.230.143 255.255.255.0
. 2023.11.17 06:20:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:20:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:20:25 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:20:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e6::108d/128 store=active
. 2023.11.17 06:20:25 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e6::/64 -> fde6:7a:7d20:12e6::108d metric 0) dev Eddie
. 2023.11.17 06:20:25 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:20:25 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:20:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:20:25 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:20:25 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:20:25 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:20:25 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:20:25 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:20:25 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.230.1)
. 2023.11.17 06:20:26 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e6::1)
. 2023.11.17 06:20:26 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:20:26 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:20:27 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:20:27 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:20:27 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:20:27 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:20:27 - Flushing DNS
! 2023.11.17 06:20:28 - Connected.
. 2023.11.17 06:20:28 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:21:18 - Above log line repeated 22 times more
! 2023.11.17 06:21:18 - Disconnecting
. 2023.11.17 06:21:18 - Sending soft termination signal
. 2023.11.17 06:21:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:21:23 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:21:23 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e6::/64)
. 2023.11.17 06:21:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:21:23 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e6::108d store=active
. 2023.11.17 06:21:23 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.230.143 store=active
. 2023.11.17 06:21:23 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:21:24 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:21:24 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:21:25 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:21:25 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:21:25 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:21:26 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:21:26 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:21:26 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:21:26 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:21:27 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:21:27 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:21:27 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:21:27 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:21:27 - Connection terminated.
. 2023.11.17 06:21:27 - Flushing DNS
! 2023.11.17 06:21:27 - Session terminated.
I 2023.11.17 06:21:55 - Session starting.
I 2023.11.17 06:21:57 - Checking authorization ...
. 2023.11.17 06:21:59 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:21:59 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:21:59 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:21:59 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:21:59 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:22:00 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:22:00 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:22:00 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:22:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:22:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:22:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:22:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:22:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:22:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:22:00 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:22:00 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:22:00 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=356fa76e cc842b70
. 2023.11.17 06:22:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:22:00 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:22:00 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:22:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:22:00 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:22:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:22:00 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:22:00 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:22:01 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2023.11.17 06:22:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.230.1,dhcp-option DNS6 fde6:7a:7d20:12e6::1,tun-ipv6,route-gateway 10.22.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e6::108d/64 fde6:7a:7d20:12e6::1,ifconfig 10.22.230.143 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2023.11.17 06:22:03 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:22:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.230.1'
. 2023.11.17 06:22:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e6::1'
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:22:03 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:22:03 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:22:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:22:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:22:03 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:22:03 - OpenVPN > open_tun
. 2023.11.17 06:22:03 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:22:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.230.143 255.255.255.0
. 2023.11.17 06:22:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:22:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:22:03 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:22:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e6::108d/128 store=active
. 2023.11.17 06:22:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e6::/64 -> fde6:7a:7d20:12e6::108d metric 0) dev Eddie
. 2023.11.17 06:22:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:22:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:22:04 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:22:04 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:22:04 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:22:04 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:22:04 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:22:04 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.230.1)
. 2023.11.17 06:22:04 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e6::1)
. 2023.11.17 06:22:05 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:05 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:06 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:06 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:06 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:06 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:06 - Flushing DNS
! 2023.11.17 06:22:06 - Connected.
. 2023.11.17 06:22:06 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:22:21 - Above log line repeated 6 times more
! 2023.11.17 06:22:21 - Disconnecting
. 2023.11.17 06:22:21 - Sending soft termination signal
. 2023.11.17 06:22:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:22:26 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:22:26 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e6::/64)
. 2023.11.17 06:22:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:22:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e6::108d store=active
. 2023.11.17 06:22:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.230.143 store=active
. 2023.11.17 06:22:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:22:26 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:27 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:27 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:27 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:28 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:22:28 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:28 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:22:28 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:22:29 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:22:29 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:22:29 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:22:29 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:22:29 - Connection terminated.
. 2023.11.17 06:22:29 - Flushing DNS
! 2023.11.17 06:22:29 - Session terminated.
I 2023.11.17 06:23:36 - Session starting.
I 2023.11.17 06:23:38 - Checking authorization ...
. 2023.11.17 06:23:40 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:23:40 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:23:40 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:23:40 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:23:41 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:23:41 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:23:41 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:23:41 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:23:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:23:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:23:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:23:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:23:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:23:41 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:23:41 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:23:41 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:23:41 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=cba05ea8 7bb3b596
. 2023.11.17 06:23:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:23:41 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:23:41 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:23:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:23:41 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:23:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:23:41 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:23:41 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:23:42 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2023.11.17 06:23:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.230.1,dhcp-option DNS6 fde6:7a:7d20:12e6::1,tun-ipv6,route-gateway 10.22.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e6::108d/64 fde6:7a:7d20:12e6::1,ifconfig 10.22.230.143 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2023.11.17 06:23:42 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:23:42 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.230.1'
. 2023.11.17 06:23:42 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e6::1'
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:23:42 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:23:42 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:23:42 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:23:42 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:23:42 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:23:42 - OpenVPN > open_tun
. 2023.11.17 06:23:42 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:23:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.230.143 255.255.255.0
. 2023.11.17 06:23:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:23:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:23:42 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:23:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e6::108d/128 store=active
. 2023.11.17 06:23:42 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e6::/64 -> fde6:7a:7d20:12e6::108d metric 0) dev Eddie
. 2023.11.17 06:23:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:23:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:23:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:23:42 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:23:42 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:23:43 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:23:43 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:23:43 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:23:43 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.230.1)
. 2023.11.17 06:23:43 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e6::1)
. 2023.11.17 06:23:44 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:44 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:44 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:45 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:45 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:45 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:45 - Flushing DNS
! 2023.11.17 06:23:45 - Connected.
. 2023.11.17 06:23:45 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:23:53 - Above log line repeated 9 times more
! 2023.11.17 06:23:53 - Disconnecting
. 2023.11.17 06:23:53 - Sending soft termination signal
. 2023.11.17 06:23:56 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:23:58 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:23:58 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e6::/64)
. 2023.11.17 06:23:58 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:23:58 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e6::108d store=active
. 2023.11.17 06:23:58 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.230.143 store=active
. 2023.11.17 06:23:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:23:59 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:23:59 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:24:00 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:24:00 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:24:00 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:24:00 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:24:01 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:24:01 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:24:01 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:24:01 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:24:01 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:24:01 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:24:01 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:24:01 - Connection terminated.
. 2023.11.17 06:24:01 - Flushing DNS
! 2023.11.17 06:24:02 - Session terminated.
I 2023.11.17 06:25:20 - Session starting.
I 2023.11.17 06:25:22 - Checking authorization ...
. 2023.11.17 06:25:23 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:25:23 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:25:23 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:25:24 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:25:24 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:25:24 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:25:24 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:25:24 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:25:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:25:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:25:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:25:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:25:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:25:24 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:25:24 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:25:24 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:25:24 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=4864b23e 69259586
. 2023.11.17 06:25:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:25:24 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:25:24 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:25:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:25:24 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:25:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:25:24 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:25:24 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:25:25 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2023.11.17 06:25:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.230.1,dhcp-option DNS6 fde6:7a:7d20:12e6::1,tun-ipv6,route-gateway 10.22.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e6::108d/64 fde6:7a:7d20:12e6::1,ifconfig 10.22.230.143 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2023.11.17 06:25:25 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:25:25 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.230.1'
. 2023.11.17 06:25:25 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e6::1'
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:25:25 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:25:25 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:25:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:25:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:25:25 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:25:25 - OpenVPN > open_tun
. 2023.11.17 06:25:25 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:25:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.230.143 255.255.255.0
. 2023.11.17 06:25:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:25:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:25:25 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:25:25 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e6::108d/128 store=active
. 2023.11.17 06:25:25 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e6::/64 -> fde6:7a:7d20:12e6::108d metric 0) dev Eddie
. 2023.11.17 06:25:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:25:26 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:25:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:25:26 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:25:26 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:25:26 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:25:26 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:25:26 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:25:26 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.230.1)
. 2023.11.17 06:25:26 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e6::1)
. 2023.11.17 06:25:27 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:25:27 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:25:27 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:25:28 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:25:28 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:25:28 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:25:28 - Flushing DNS
! 2023.11.17 06:25:28 - Connected.
. 2023.11.17 06:25:28 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:25:56 - Above log line repeated 13 times more
! 2023.11.17 06:25:56 - Disconnecting
. 2023.11.17 06:25:56 - Sending soft termination signal
. 2023.11.17 06:25:59 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:26:01 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:26:01 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e6::/64)
. 2023.11.17 06:26:01 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:26:01 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e6::108d store=active
. 2023.11.17 06:26:01 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.230.143 store=active
. 2023.11.17 06:26:01 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:26:01 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:02 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:02 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:03 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:03 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:26:03 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:04 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:04 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:26:04 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:26:04 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:26:04 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:26:04 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:26:04 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:26:04 - Connection terminated.
. 2023.11.17 06:26:04 - Flushing DNS
! 2023.11.17 06:26:05 - Session terminated.
I 2023.11.17 06:26:05 - Session starting.
I 2023.11.17 06:26:07 - Checking authorization ...
. 2023.11.17 06:26:09 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:26:09 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:26:09 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:26:10 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:26:10 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:26:10 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:26:10 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:26:10 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:26:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:26:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:26:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:26:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:26:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:26:10 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:26:10 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:26:10 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:26:10 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=4de424c3 dbb67ba4
. 2023.11.17 06:26:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:26:10 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:26:10 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:26:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:26:10 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:26:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:26:10 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:26:10 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:26:11 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2023.11.17 06:26:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.230.1,dhcp-option DNS6 fde6:7a:7d20:12e6::1,tun-ipv6,route-gateway 10.22.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e6::108d/64 fde6:7a:7d20:12e6::1,ifconfig 10.22.230.143 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2023.11.17 06:26:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:26:11 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.230.1'
. 2023.11.17 06:26:11 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e6::1'
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:26:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:26:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:26:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:26:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:26:11 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:26:11 - OpenVPN > open_tun
. 2023.11.17 06:26:11 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:26:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.230.143 255.255.255.0
. 2023.11.17 06:26:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:26:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:26:11 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:26:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e6::108d/128 store=active
. 2023.11.17 06:26:12 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e6::/64 -> fde6:7a:7d20:12e6::108d metric 0) dev Eddie
. 2023.11.17 06:26:12 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:26:12 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:26:12 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:26:12 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:26:12 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:26:12 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:26:12 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:26:12 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:26:12 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.230.1)
. 2023.11.17 06:26:12 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e6::1)
. 2023.11.17 06:26:13 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:13 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:14 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:14 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:14 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:14 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:26:14 - Flushing DNS
! 2023.11.17 06:26:15 - Connected.
. 2023.11.17 06:26:15 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:27:04 - Above log line repeated 34 times more
! 2023.11.17 06:27:04 - Disconnecting
. 2023.11.17 06:27:04 - Sending soft termination signal
. 2023.11.17 06:27:07 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:27:09 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:27:09 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e6::/64)
. 2023.11.17 06:27:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:27:09 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e6::108d store=active
. 2023.11.17 06:27:09 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.230.143 store=active
. 2023.11.17 06:27:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:27:09 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:10 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:10 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:11 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:11 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:27:11 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:12 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:12 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:27:12 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:27:12 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:27:12 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:27:12 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:27:12 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:27:12 - Connection terminated.
. 2023.11.17 06:27:12 - Flushing DNS
! 2023.11.17 06:27:13 - Session terminated.
I 2023.11.17 06:27:13 - Session starting.
I 2023.11.17 06:27:16 - Checking authorization ...
. 2023.11.17 06:27:18 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:27:18 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:27:18 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:27:18 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:27:19 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:27:19 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:27:19 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:27:19 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:27:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:27:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:27:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:27:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:27:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:27:19 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:27:19 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:27:19 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:27:19 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=ad130709 c4637ec7
. 2023.11.17 06:27:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:27:19 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:27:19 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:27:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:27:19 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:27:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:27:19 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:27:19 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:27:20 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2023.11.17 06:27:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.230.1,dhcp-option DNS6 fde6:7a:7d20:12e6::1,tun-ipv6,route-gateway 10.22.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e6::108d/64 fde6:7a:7d20:12e6::1,ifconfig 10.22.230.143 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2023.11.17 06:27:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:27:20 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.230.1'
. 2023.11.17 06:27:20 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e6::1'
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:27:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:27:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:27:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:27:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:27:20 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:27:20 - OpenVPN > open_tun
. 2023.11.17 06:27:20 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:27:20 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.230.143 255.255.255.0
. 2023.11.17 06:27:20 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:27:20 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:27:20 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:27:20 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e6::108d/128 store=active
. 2023.11.17 06:27:20 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e6::/64 -> fde6:7a:7d20:12e6::108d metric 0) dev Eddie
. 2023.11.17 06:27:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:27:20 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:27:20 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:27:20 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:27:20 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:27:20 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:27:20 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:27:21 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:27:21 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.230.1)
. 2023.11.17 06:27:21 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e6::1)
. 2023.11.17 06:27:21 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:22 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:22 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:22 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:22 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:23 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:23 - Flushing DNS
! 2023.11.17 06:27:23 - Connected.
. 2023.11.17 06:27:23 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:27:49 - Above log line repeated 18 times more
! 2023.11.17 06:27:49 - Disconnecting
. 2023.11.17 06:27:49 - Sending soft termination signal
. 2023.11.17 06:27:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:27:54 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:27:54 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e6::/64)
. 2023.11.17 06:27:54 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e6::/64 42 fe80::8 store=active
. 2023.11.17 06:27:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e6::108d store=active
. 2023.11.17 06:27:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.230.143 store=active
. 2023.11.17 06:27:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:27:56 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:56 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:56 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:57 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:57 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:27:57 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:58 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:27:58 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:27:58 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:27:58 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:27:58 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:27:58 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:27:58 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:27:58 - Connection terminated.
. 2023.11.17 06:27:58 - Flushing DNS
! 2023.11.17 06:27:59 - Session terminated.
I 2023.11.17 06:30:05 - Session starting.
I 2023.11.17 06:30:07 - Checking authorization ...
. 2023.11.17 06:30:08 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:30:08 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:30:08 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2023.11.17 06:30:08 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:30:09 - Routes, add 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:30:09 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:30:09 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:30:09 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:30:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:30:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:30:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:30:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:30:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2023.11.17 06:30:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:30:09 - OpenVPN > Attempting to establish TCP connection with [AF_INET]64.42.179.61:443 [nonblock]
. 2023.11.17 06:30:09 - OpenVPN > TCP connection established with [AF_INET]64.42.179.61:443
. 2023.11.17 06:30:09 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2023.11.17 06:30:09 - OpenVPN > TCP_CLIENT link remote: [AF_INET]64.42.179.61:443
. 2023.11.17 06:30:09 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=707659d0 94ca8b93
. 2023.11.17 06:30:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:30:09 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:30:09 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:30:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:30:09 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:30:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2023.11.17 06:30:09 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:30:09 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2023.11.17 06:30:10 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2023.11.17 06:30:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.231.1,dhcp-option DNS6 fde6:7a:7d20:12e7::1,tun-ipv6,route-gateway 10.22.231.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e7::102e/64 fde6:7a:7d20:12e7::1,ifconfig 10.22.231.48 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2023.11.17 06:30:10 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:30:10 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.22.231.1'
. 2023.11.17 06:30:10 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:12e7::1'
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2023.11.17 06:30:10 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:30:10 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:30:10 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:30:10 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:30:10 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:30:10 - OpenVPN > open_tun
. 2023.11.17 06:30:10 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:30:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.22.231.48 255.255.255.0
. 2023.11.17 06:30:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:30:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:30:10 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:30:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:12e7::102e/128 store=active
. 2023.11.17 06:30:10 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e7::/64 -> fde6:7a:7d20:12e7::102e metric 0) dev Eddie
. 2023.11.17 06:30:10 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e7::/64 42 fe80::8 store=active
. 2023.11.17 06:30:10 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:30:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:30:10 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:30:10 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:30:11 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:30:11 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:30:11 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:30:11 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.22.231.1)
. 2023.11.17 06:30:11 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:12e7::1)
. 2023.11.17 06:30:12 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:12 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:12 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:13 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:13 - Routes, add 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:13 - Routes, add 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:13 - Flushing DNS
! 2023.11.17 06:30:13 - Connected.
! 2023.11.17 06:30:23 - Disconnecting
. 2023.11.17 06:30:23 - Sending soft termination signal
. 2023.11.17 06:30:26 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:30:26 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e7::/64)
. 2023.11.17 06:30:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e7::/64 42 fe80::8 store=active
. 2023.11.17 06:30:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:12e7::102e store=active
. 2023.11.17 06:30:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.22.231.48 store=active
. 2023.11.17 06:30:26 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2023.11.17 06:30:26 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:26 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:27 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:27 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:27 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:30:28 - Routes, delete 64.42.179.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:28 - Routes, delete 2605:9f80:6000:80:fc8c:43ee:267e:97ab/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:30:28 - Routes, delete 64.42.179.61/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:30:28 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:30:28 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:30:28 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:30:28 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:30:28 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:30:28 - Connection terminated.
. 2023.11.17 06:30:28 - Flushing DNS
! 2023.11.17 06:30:29 - Session terminated.
I 2023.11.17 06:30:53 - Session starting.
I 2023.11.17 06:30:55 - Checking authorization ...
. 2023.11.17 06:30:57 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:30:57 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:30:57 - Connecting to Ross (Canada, Montreal)
. 2023.11.17 06:30:57 - Routes, add 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:30:58 - Routes, add 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:30:58 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:30:58 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:30:58 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:30:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:30:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:30:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:30:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:30:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]139.28.218.237:443
. 2023.11.17 06:30:58 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:30:58 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:30:58 - OpenVPN > UDP link remote: [AF_INET]139.28.218.237:443
. 2023.11.17 06:30:58 - OpenVPN > TLS: Initial packet from [AF_INET]139.28.218.237:443, sid=77199f20 e43975c0
. 2023.11.17 06:30:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:30:58 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:30:58 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:30:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:30:58 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:30:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ross, emailAddress=info@airvpn.org
. 2023.11.17 06:30:58 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:30:58 - OpenVPN > [Ross] Peer Connection Initiated with [AF_INET]139.28.218.237:443
. 2023.11.17 06:30:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.35.38.1,dhcp-option DNS6 fde6:7a:7d20:1f26::1,tun-ipv6,route-gateway 10.35.38.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1f26::108d/64 fde6:7a:7d20:1f26::1,ifconfig 10.35.38.143 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2023.11.17 06:30:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:30:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.35.38.1'
. 2023.11.17 06:30:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1f26::1'
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:30:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:30:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:30:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:30:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:30:58 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:30:58 - OpenVPN > open_tun
. 2023.11.17 06:30:58 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:30:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.35.38.143 255.255.255.0
. 2023.11.17 06:30:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:30:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:30:59 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:30:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:1f26::108d/128 store=active
. 2023.11.17 06:30:59 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1f26::/64 -> fde6:7a:7d20:1f26::108d metric 0) dev Eddie
. 2023.11.17 06:30:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1f26::/64 42 fe80::8 store=active
. 2023.11.17 06:30:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:30:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:30:59 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:30:59 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:30:59 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:30:59 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:30:59 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:31:00 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.35.38.1)
. 2023.11.17 06:31:00 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1f26::1)
. 2023.11.17 06:31:00 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:01 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:01 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:01 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:01 - Routes, add 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:02 - Routes, add 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:02 - Flushing DNS
I 2023.11.17 06:31:02 - Checking route IPv4
. 2023.11.17 06:31:24 - OpenVPN > write UDP: Unknown error (code=10065)
. 2023.11.17 06:31:24 - Above log line repeated 5 times more
! 2023.11.17 06:31:24 - Disconnecting
. 2023.11.17 06:31:24 - Sending soft termination signal
. 2023.11.17 06:31:27 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.11.17 06:31:29 - OpenVPN > Closing TUN/TAP interface
. 2023.11.17 06:31:29 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1f26::/64)
. 2023.11.17 06:31:29 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1f26::/64 42 fe80::8 store=active
. 2023.11.17 06:31:29 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 42 fde6:7a:7d20:1f26::108d store=active
. 2023.11.17 06:31:29 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv4 delete address 42 10.35.38.143 store=active
. 2023.11.17 06:31:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.11.17 06:31:30 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:30 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:30 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:31 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:31 - Routes, delete 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:31:31 - Routes, delete 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:31 - Routes, delete 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:31:31 - Routes, delete 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", not exists.
. 2023.11.17 06:31:32 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:31:32 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.11.17 06:31:32 - DNS leak protection with packet filtering disabled.
. 2023.11.17 06:31:32 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.11.17 06:31:32 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.11.17 06:31:32 - Connection terminated.
I 2023.11.17 06:31:32 - Cancel requested.
! 2023.11.17 06:31:32 - Session terminated.
I 2023.11.17 06:32:08 - Session starting.
I 2023.11.17 06:32:10 - Checking authorization ...
. 2023.11.17 06:32:12 - Added new network interface "Eddie", Wintun version 0.12
. 2023.11.17 06:32:12 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.11.17 06:32:12 - Connecting to Ross (Canada, Montreal)
. 2023.11.17 06:32:12 - Routes, add 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)".
. 2023.11.17 06:32:12 - Routes, add 139.28.218.237/32 for interface "Ethernet (Intel(R) Ethernet Connection (13) I219-LM)", already exists.
. 2023.11.17 06:32:12 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.11.17 06:32:12 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.11.17 06:32:12 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.11.17 06:32:12 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:32:12 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:32:12 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.11.17 06:32:12 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.11.17 06:32:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]139.28.218.237:443
. 2023.11.17 06:32:12 - OpenVPN > Socket Buffers: R=[65536->262144] S=[64512->262144]
. 2023.11.17 06:32:12 - OpenVPN > UDP link local: (not bound)
. 2023.11.17 06:32:12 - OpenVPN > UDP link remote: [AF_INET]139.28.218.237:443
. 2023.11.17 06:32:13 - OpenVPN > TLS: Initial packet from [AF_INET]139.28.218.237:443, sid=6ce0bfa2 d229cd2e
. 2023.11.17 06:32:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.11.17 06:32:13 - OpenVPN > VERIFY KU OK
. 2023.11.17 06:32:13 - OpenVPN > Validating certificate extended key usage
. 2023.11.17 06:32:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.11.17 06:32:13 - OpenVPN > VERIFY EKU OK
. 2023.11.17 06:32:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ross, emailAddress=info@airvpn.org
. 2023.11.17 06:32:13 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.11.17 06:32:13 - OpenVPN > [Ross] Peer Connection Initiated with [AF_INET]139.28.218.237:443
. 2023.11.17 06:32:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.35.38.1,dhcp-option DNS6 fde6:7a:7d20:1f26::1,tun-ipv6,route-gateway 10.35.38.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1f26::108d/64 fde6:7a:7d20:1f26::1,ifconfig 10.35.38.143 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2023.11.17 06:32:13 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.11.17 06:32:13 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.35.38.1'
. 2023.11.17 06:32:13 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1f26::1'
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.11.17 06:32:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.11.17 06:32:13 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.11.17 06:32:13 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:32:13 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.11.17 06:32:13 - OpenVPN > interactive service msg_channel=0
. 2023.11.17 06:32:13 - OpenVPN > open_tun
. 2023.11.17 06:32:13 - OpenVPN > wintun device [Eddie] opened
. 2023.11.17 06:32:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip set address 42 static 10.35.38.143 255.255.255.0
. 2023.11.17 06:32:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete dns 42 all
. 2023.11.17 06:32:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ip delete wins 42 all
. 2023.11.17 06:32:14 - OpenVPN > IPv4 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:32:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 42 fde6:7a:7d20:1f26::108d/128 store=active
. 2023.11.17 06:32:14 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1f26::/64 -> fde6:7a:7d20:1f26::108d metric 0) dev Eddie
. 2023.11.17 06:32:14 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1f26::/64 42 fe80::8 store=active
. 2023.11.17 06:32:14 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2023.11.17 06:32:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 42 all
. 2023.11.17 06:32:14 - OpenVPN > IPv6 MTU set to 1500 on interface 42 using SetIpInterfaceEntry()
. 2023.11.17 06:32:14 - OpenVPN > Initialization Sequence Completed
. 2023.11.17 06:32:14 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.11.17 06:32:14 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.11.17 06:32:14 - DNS leak protection with packet filtering enabled.
. 2023.11.17 06:32:15 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.35.38.1)
. 2023.11.17 06:32:15 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1f26::1)
. 2023.11.17 06:32:15 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:32:16 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:32:16 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:32:16 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:32:16 - Routes, add 139.28.218.235/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:32:17 - Routes, add 2a0d:5600:9:3f:3a9b:a7b9:b7c1:498/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.11.17 06:32:17 - Flushing DNS
! 2023.11.17 06:32:17 - Connected.
. 2023.11.17 06:32:17 - OpenVPN > write UDP: Unknown error (code=10065)
Edited ... by OpenSourcerer
Apply LOG format to logs
Reboot your computer, launch Eddie and try a connection. Then provide a system report:.
