Today my AirVPN just stopped working. For some reason, the connection process stops at "Checking route IPv4" and it takes forever
Here's the log
I 2023.09.05 16:56:56 - Session starting.
I 2023.09.05 16:56:56 - Checking authorization ...
. 2023.09.05 16:56:57 - Added new network interface "Eddie", Wintun version 0.12
. 2023.09.05 16:56:57 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.09.05 16:56:57 - Connecting to Talitha (Netherlands, Alblasserdam)
. 2023.09.05 16:56:57 - Routes, add 213.152.161.140/32 for interface "Ethernet (Realtek PCIe GBE Family Controller)".
. 2023.09.05 16:56:57 - Routes, add 213.152.161.140/32 for interface "Ethernet (Realtek PCIe GBE Family Controller)", already exists.
. 2023.09.05 16:56:57 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.09.05 16:56:57 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.09.05 16:56:57 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.09.05 16:56:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.09.05 16:56:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.09.05 16:56:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.09.05 16:56:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.09.05 16:56:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.140:443
. 2023.09.05 16:56:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.09.05 16:56:57 - OpenVPN > UDP link local: (not bound)
. 2023.09.05 16:56:57 - OpenVPN > UDP link remote: [AF_INET]213.152.161.140:443
. 2023.09.05 16:56:57 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.140:443, sid=fbc08c94 fb5570a0
. 2023.09.05 16:56:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.09.05 16:56:57 - OpenVPN > VERIFY KU OK
. 2023.09.05 16:56:57 - OpenVPN > Validating certificate extended key usage
. 2023.09.05 16:56:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.09.05 16:56:57 - OpenVPN > VERIFY EKU OK
. 2023.09.05 16:56:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Talitha, emailAddress=info@airvpn.org
. 2023.09.05 16:56:57 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.09.05 16:56:57 - OpenVPN > [Talitha] Peer Connection Initiated with [AF_INET]213.152.161.140:443
. 2023.09.05 16:56:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.18.1,dhcp-option DNS6 fde6:7a:7d20:1b12::1,tun-ipv6,route-gateway 10.31.18.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1b12::1061/64 fde6:7a:7d20:1b12::1,ifconfig 10.31.18.99 255.255.255.0,peer-id 6,cipher AES-256-GCM'
. 2023.09.05 16:56:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.09.05 16:56:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.31.18.1'
. 2023.09.05 16:56:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1b12::1'
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.09.05 16:56:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.09.05 16:56:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.09.05 16:56:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.09.05 16:56:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.09.05 16:56:58 - OpenVPN > interactive service msg_channel=0
. 2023.09.05 16:56:58 - OpenVPN > open_tun
. 2023.09.05 16:56:58 - OpenVPN > wintun device [Eddie] opened
. 2023.09.05 16:56:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 28 static 10.31.18.99 255.255.255.0
. 2023.09.05 16:56:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 28 all
. 2023.09.05 16:56:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 28 all
. 2023.09.05 16:56:58 - OpenVPN > IPv4 MTU set to 1500 on interface 28 using SetIpInterfaceEntry()
. 2023.09.05 16:56:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 28 fde6:7a:7d20:1b12::1061/128 store=active
. 2023.09.05 16:56:58 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1b12::/64 -> fde6:7a:7d20:1b12::1061 metric 0) dev Eddie
. 2023.09.05 16:56:58 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1b12::/64 28 fe80::8 store=active
. 2023.09.05 16:56:58 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2023.09.05 16:56:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 28 all
. 2023.09.05 16:56:58 - OpenVPN > IPv6 MTU set to 1500 on interface 28 using SetIpInterfaceEntry()
. 2023.09.05 16:56:58 - OpenVPN > Initialization Sequence Completed
. 2023.09.05 16:56:58 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2023.09.05 16:56:58 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2023.09.05 16:56:58 - DNS leak protection with packet filtering enabled.
. 2023.09.05 16:56:58 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.31.18.1)
. 2023.09.05 16:56:58 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1b12::1)
. 2023.09.05 16:56:58 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.31.18.1)
. 2023.09.05 16:56:59 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:1b12::1)
. 2023.09.05 16:56:59 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.31.18.1)
. 2023.09.05 16:56:59 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1b12::1)
. 2023.09.05 16:56:59 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:56:59 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:56:59 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:56:59 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:56:59 - Routes, add 213.152.161.138/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:56:59 - Routes, add 2a00:1678:2470:6:6f0d:8828:9fc4:bbdd/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:56:59 - Flushing DNS
I 2023.09.05 16:56:59 - Checking route IPv4
. 2023.09.05 16:57:26 - Checking route (4° try)
. 2023.09.05 16:57:52 - Checking route (5° try)
E 2023.09.05 16:58:13 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
! 2023.09.05 16:58:13 - Disconnecting
. 2023.09.05 16:58:13 - Sending soft termination signal
. 2023.09.05 16:58:16 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.09.05 16:58:17 - OpenVPN > Closing TUN/TAP interface
. 2023.09.05 16:58:17 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1b12::/64)
. 2023.09.05 16:58:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1b12::/64 28 fe80::8 store=active
. 2023.09.05 16:58:17 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 28 fde6:7a:7d20:1b12::1061 store=active
. 2023.09.05 16:58:17 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 28 10.31.18.99 store=active
. 2023.09.05 16:58:17 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.09.05 16:58:17 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:58:17 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:58:17 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:58:17 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:58:18 - Routes, delete 213.152.161.140/32 for interface "Ethernet (Realtek PCIe GBE Family Controller)".
. 2023.09.05 16:58:18 - Routes, delete 213.152.161.138/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:58:18 - Routes, delete 2a00:1678:2470:6:6f0d:8828:9fc4:bbdd/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2023.09.05 16:58:18 - Routes, delete 213.152.161.140/32 for interface "Ethernet (Realtek PCIe GBE Family Controller)", not exists.
. 2023.09.05 16:58:18 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.09.05 16:58:18 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2023.09.05 16:58:18 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2023.09.05 16:58:18 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2023.09.05 16:58:18 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2023.09.05 16:58:18 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2023.09.05 16:58:18 - DNS leak protection with packet filtering disabled.
. 2023.09.05 16:58:18 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2023.09.05 16:58:18 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2023.09.05 16:58:18 - Connection terminated.
I 2023.09.05 16:58:19 - Cancel requested.
! 2023.09.05 16:58:19 - Session terminated.
. 2023.09.05 17:09:35 - Collect information about AirVPN completed
Please send the system report as required by the support team. Please see here to do so: https://airvpn.org/forums/topic/50663-youve-been-asked-for-a-support-filesystem-report-–-heres-what-to-do/
Also, please test a connection with OpenVPN, in TCP and UDP, port 443 and port 53 (all the 4 combinations), to entry-IP address THREE and report whether the problem persists or not. You can change connection mode in Eddie's "Preferences" > "Protocols" window (uncheck "Automatic" to pick a specific connection mode).
I had the same problem today. I unchecked check airvpn dns and ensure dns lock in preferences/dns. And enabled automatic server selection when connecting. It worked.
I have the same issue. In last several days I began to experience this weird issues: when I try to connect to a server and the connection process stops on "Checking DNS" or "Checking route IPv4". I need to try various servers in order to randomly find the one which connects successfully. Same issue on Android, but on Android it does establish the connection, but traffic is not working, internet in fact does not working. Trying various servers, before randomly one of them start to work.
It seems, that the issue can be fixed by changing OpenVPN port from UDP 443 to 53, both on PC and Android.
