CLT99
ANSWERED Wireguard, Failed to start: not running
I have some issues about connecting AirVPN. I changed my ethernet wall port to another wall port and it doesn't work.
I have no problem in the past, even if I changed back to the original wall port it doesn't work. Internet works fine without any problem.
I know it's my desktop problem since I have no problem to connect using my phone.
Tried both wireguard and openvpn, with various different ports. Under Settings > Networking, all are automatic.
Please help. The attached is the log file.
Eddie_20230727_180105.txt
Tried restarting my desktop, using experimental version, but still not working.
Hello, for wireguard, running it manually does not work, it says failed to setup adapter.
For openvpn manually connecting works.
Using eddie with openvpn protocol stuck at collect network information.
The attached file is the wireguard log.
Thank you.
wireguard-log-2023-07-27T211534.txt
Okay, the problem is solved.
After resetting my network and delete eddie profile, I am able to connect again using eddie.
