hellohello1234 0 Posted ... Does the Eddie client have a setting for a kill switch? If not, is there a way to configure a 'kill switch' through windows settings? I'm not referring to torrent clients, all traffic. I'd rather not setup through the router if I can avoid it. Share this post Link to post
Staff 10459 Posted ... Hello! Traffic leaks prevention exists ever since Eddie Windows edition was created. The feature is "Network Lock". Click "Activate Network Lock" button from Eddie's main window before you start a connection. Network Lock will prevent any possible traffic leak outside the VPN tunnel. You may also configure Eddie to start with Network Lock enabled by checking "Activate Network Lock at startup" in "Preferences" > "Protocols" window. Kind regards Share this post Link to post
hellohello1234 0 Posted ... (edited) Thank you. I did notice I was able to access internet through the browser after disconnecting the VPN with network lock on. I will do some troubleshooting. Edit: Network lock now working great. I'll continue to fiddle with the firewall separately. Thanks again for the help. Edited ... by hellohello1234 Issue Resolved Share this post Link to post
