farquaad
ANSWERED Failover / Load balanced OVPN setup
Hi all,
I would like to enable a failover configuration with OpenVPN but I am not sure if this can be done.
This article describes how to do it.
Because I want to use AirDNS, I am forced to use IPs so I can't just set the "remote" to "europe3.vpn.airdns.org" as it won't resolve and I'll be stuck in a catch 22.
Would what is described in the document work or are the certificates different on each server making it impossible to do so?
Thanks for your help!
Thank you both for your advice. I gave it a go and it works great.
Edited ... by farquaad
tested the change and it works.
