the current state is the following:
https://airvpn.org/forums/topic/56119-new-10-gbits-server-available-bg/?do=findComment&comment=220907
After the message by Antonio Quartulli (lead DCO developer) we re-started from scratch and the stability problems are resolved. However DCO is still immature for production. Remember that:
ovpn-dco is currently under heavy development, therefore neither its userspace API
nor the code itself is considered stable and may change radically over time.
So you might need to re-build everything multiple times: it's not the way to go in production, of course.
Without DCO, on your client side, you can not see any difference in performance and stability between OpenVPN 2.5.x and 2.6.x.
So, the only thing we could do would be upgrading to OpenVPN 2.6 without DCO. However, we would prefer to migrate to OpenVPN 2.6.x with DCO support, instead of 1) upgrading to 2.6.3, and 2) later on re-upgrading the whole infrastructure again with DCO. We'll keep you informed, but don't expect too much, nothing will change on your side in terms of stability and throughput.
As much as I am reading... yeah I am much more eager to try Airvpns go live
I am not a Mullvad subscriber but am reading lots of headaches currently
