Stalinium 57 Posted ... 09:13:36 UTC [Info] Trying connection to AirVPN server Kajam in Alblasserdam, Netherlands - WireGuard, Protocol UDP, Port 1637 09:13:36 UTC [Info] Using user key 'MyDefault' 09:13:36 UTC [Info] Local networks are exempted from the VPN 09:13:36 UTC [Info] Network is connected to WIFI 09:13:36 UTC [Debug] VPNService.networkStatusChanged() action: 'SYSTEM_RESUME' 09:13:37 UTC [Info] WireGuardTunnel: successfully created a new WireGuard client 09:13:37 UTC [Info] Setting MTU to 1320 09:13:37 UTC [Error] WireGuardTunnel: Cannot resolve [2a00 09:13:37 UTC [Info] Starting VPN thread 09:13:37 UTC [Info] Adding server IPv4 address internal_ip4/32 09:13:37 UTC [Info] Adding server IPv6 address internal_ip6/128 09:13:37 UTC [Error] WireGuardTunnel: Cannot resolve [2a00 Yes it literally says this in the log. If needed I will send the full log to the AirVPN team. Does anybody else have the same issue? This is how to test: Open Eddie Switch to the tab "AirVPN Server" Tap the Settings Icon VPN Type: Wireguard IP Version: IPv6 Try to connect to a server. It will either show an error (and this in log) or crash. It works fine with OpenVPN Android 11 Eddie 3.0 VC30 Maybe this? https://gitlab.com/AirVPN/EddieAndroid/-/blob/ef70deabb46206e5b1edf178b36655ae0d4a103e/app/src/main/java/org/airvpn/eddie/WireGuardTunnel.java#L805 Share this post Link to post
Staff 10510 Posted ... Hello! Confirmed, unfortunately. We're investigating and a fix will be implemented in the next release. Thank you very much for the report. Kind regards 1 Stalinium reacted to this Share this post Link to post
