worric
[SOLVED] Port Forwarding not working on Cygni
Hiya
Just wanted to report that port forwarding doesn't seem to work on the newly added Cygni server in Sweden.
Switching to Leporis, the server I have used for quite some time reliably, remedied the problem immediately.
Hiya
Thank you for the information. We confirm we have still some issues with port forwarding on Cygni. We're working on it in order to detect the problem.
The problem has been fixed, we apologize for the inconvenience. Please try again port forwarding on Cygni at your convenience.
Works now, thanks
Also, thanks for the great response time and fixing problems the same day they're reported.
I'm very satisfied with the quality and service of AirVPN and I will definitely consider a sub for a year
