BatteriVoltas 0 Posted ... So I requested a port forward and was assigned a specific port number. I configured and confirmed that deluged is listening on the configured port. However, when I test it from airvpn.org, I get connection timed out. I also tried testing it from a couple general use websites, and both reported the port is closed. The docs seem to suggest not setting any port forwarding on my router, so there is none. What am I doing wrong? This seems so basic. Your help would be sincerely appreciated. Quote Share this post Link to post
Staff 10487 Posted ... @BatteriVoltas Hello! Please feel free to open a ticket to get thorough support. In the ticket please state whether you get error 110 or 111 when you test from AirVPN web site port tester. As a preliminary check, please make sure that Deluge settings related to UPnP and NAT-PMP are all disabled and that no firewall (running in the same machine where Deluge runs too) interferes with packets to and from Deluge. A quick reference guide to check other settings:https://airvpn.org/faq/p2p/ Kind regards Quote Share this post Link to post
ChehTan 1 Posted ... Hello there, Was is your configuration? Are you running on Windows or Linux? Are you using a Docker stack? Quote Share this post Link to post
