Not connected, Your IP: 216.73.217.100
Droopy
Encrypted or not
80 1.343740000 192.---.-.- 70.--.---.--- UDP 94 Source port: 57296 Destination port: 56092
Above is from wireshark, there is alot like this without the https indicated, is that an issue, thanks for your help.
Are you running Wireshark on a separate machine? Sometimes, when you run WS on the same machine as the connection, WS gets the data after it is decrypted.
If you capture traffic on the tun/tap adapter you can see unencrypted packets. If you capture traffic on the physical interface you must see all encrypted packets to/from the Air server, except those to/from your internal network, otherwise there's something wrong: check your routing table after the VPN server push.
Thanks for the response, but how do you check your routing table after the VPN server push. And what am i looking for.
Cheers
