woffmark
Connect remotely to RDP
Hi. I have RDP running locally on port 3389. I've enabled port forwarding on airvpn web page, and there is information about my port 3389 and port 32604. I was trying to connect to my RDP via port 3389 or 32604 but no success. Which port I should use in local service, and wich port I should use remotely?
Assuming that your RDP server is running behind an Air server, you can reach it from the Internet at :
The listening port needs to be remotely forwarded. Please note:
- the entry-IP and exit-IP of our servers are different
- the forwarded port may be different form the RDP server listening port, as long as you remap it to the correct local port
For example:
- your RDP server runs in a machine where an OpenVPN client is connected to an Air server
- the RDP server listens to port 3389
- the remotely forwarded port is 32604 remapped to local port 3389,
Then you can reach the RDP at:
:32604
Alternatively, you can change (if possible) the RDP server listening port to 32604 and NOT remap 32604 to any local port.
