Hi
i dont have a problem when connecting via ipv4 protocol. but i cant connect via ipv6
i tried on multiple computers and multiple routers on different networks, problem presisted throughout last 3 years
Log:
I 2023.01.06 13:38:04 - Session starting.
I 2023.01.06 13:38:04 - Checking authorization ...
. 2023.01.06 13:38:05 - Using WinTun network interface "OpenVPN Wintun (Wintun Userspace Tunnel)"
! 2023.01.06 13:38:05 - Connecting to Caph (Netherlands, Alblasserdam)
. 2023.01.06 13:38:05 - Routes, add 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)".
. 2023.01.06 13:38:05 - Routes, add 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)", already exists.
. 2023.01.06 13:38:05 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.01.06 13:38:05 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.01.06 13:38:05 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.01.06 13:38:05 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.01.06 13:38:05 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.01.06 13:38:05 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.01.06 13:38:05 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.01.06 13:38:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET6]2a00:1678:2470:18:5ac5:3314:8260:3523:443
. 2023.01.06 13:38:05 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.01.06 13:38:05 - OpenVPN > UDPv6 link local: (not bound)
. 2023.01.06 13:38:05 - OpenVPN > UDPv6 link remote: [AF_INET6]2a00:1678:2470:18:5ac5:3314:8260:3523:443
. 2023.01.06 13:38:37 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2023.01.06 13:38:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.01.06 13:38:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2023.01.06 13:38:42 - Disconnecting
. 2023.01.06 13:38:42 - Routes, delete 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)".
. 2023.01.06 13:38:42 - Routes, delete 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)", not exists.
. 2023.01.06 13:38:42 - Connection terminated.
I 2023.01.06 13:38:45 - Checking authorization ...
. 2023.01.06 13:38:45 - Using WinTun network interface "OpenVPN Wintun (Wintun Userspace Tunnel)"
! 2023.01.06 13:38:45 - Connecting to Caph (Netherlands, Alblasserdam)
. 2023.01.06 13:38:46 - Routes, add 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)".
. 2023.01.06 13:38:46 - Routes, add 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)", already exists.
. 2023.01.06 13:38:46 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.01.06 13:38:46 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.01.06 13:38:46 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.01.06 13:38:46 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.01.06 13:38:46 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.01.06 13:38:46 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.01.06 13:38:46 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.01.06 13:38:46 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET6]2a00:1678:2470:18:5ac5:3314:8260:3523:443
. 2023.01.06 13:38:46 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.01.06 13:38:46 - OpenVPN > UDPv6 link local: (not bound)
. 2023.01.06 13:38:46 - OpenVPN > UDPv6 link remote: [AF_INET6]2a00:1678:2470:18:5ac5:3314:8260:3523:443
! 2023.01.06 13:38:57 - Disconnecting
. 2023.01.06 13:38:57 - Sending soft termination signal
. 2023.01.06 13:39:00 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.01.06 13:39:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.01.06 13:39:03 - Routes, delete 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)".
. 2023.01.06 13:39:03 - Routes, delete 2a00:1678:2470:18:5ac5:3314:8260:3523/128 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)", not exists.
. 2023.01.06 13:39:03 - Connection terminated.
I 2023.01.06 13:39:03 - Cancel requested.
! 2023.01.06 13:39:03 - Session terminated.
I 2023.01.06 13:39:05 - Session starting.
I 2023.01.06 13:39:05 - Checking authorization ...
. 2023.01.06 13:39:06 - Using WinTun network interface "OpenVPN Wintun (Wintun Userspace Tunnel)"
! 2023.01.06 13:39:06 - Connecting to Caph (Netherlands, Alblasserdam)
. 2023.01.06 13:39:06 - Routes, add 213.152.162.172/32 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)".
. 2023.01.06 13:39:06 - Routes, add 213.152.162.172/32 for interface "Ethernet (Intel(R) Ethernet Connection (7) I219-V)", already exists.
. 2023.01.06 13:39:06 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.01.06 13:39:06 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.01.06 13:39:06 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.01.06 13:39:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.01.06 13:39:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.01.06 13:39:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.01.06 13:39:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.01.06 13:39:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.172:443
. 2023.01.06 13:39:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.01.06 13:39:06 - OpenVPN > UDP link local: (not bound)
. 2023.01.06 13:39:06 - OpenVPN > UDP link remote: [AF_INET]213.152.162.172:443
. 2023.01.06 13:39:06 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.172:443, sid=372ea917 90a0d157
. 2023.01.06 13:39:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.01.06 13:39:06 - OpenVPN > VERIFY KU OK
. 2023.01.06 13:39:06 - OpenVPN > Validating certificate extended key usage
. 2023.01.06 13:39:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.01.06 13:39:06 - OpenVPN > VERIFY EKU OK
. 2023.01.06 13:39:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caph, emailAddress=info@airvpn.org
. 2023.01.06 13:39:06 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.01.06 13:39:06 - OpenVPN > [Caph] Peer Connection Initiated with [AF_INET]213.152.162.172:443
. 2023.01.06 13:39:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.12.138.1,dhcp-option DNS6 fde6:7a:7d20:88a::1,tun-ipv6,route-gateway 10.12.138.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:88a::10df/64 fde6:7a:7d20:88a::1,ifconfig 10.12.138.225 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2023.01.06 13:39:06 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.01.06 13:39:06 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.12.138.1'
. 2023.01.06 13:39:06 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:88a::1'
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.01.06 13:39:06 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.01.06 13:39:06 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.01.06 13:39:06 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.01.06 13:39:06 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.01.06 13:39:06 - OpenVPN > interactive service msg_channel=0
. 2023.01.06 13:39:06 - OpenVPN > open_tun
. 2023.01.06 13:39:06 - OpenVPN > wintun device [OpenVPN Wintun] opened
. 2023.01.06 13:39:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 9 static 10.12.138.225 255.255.255.0
. 2023.01.06 13:39:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 9 all
. 2023.01.06 13:39:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 9 all
. 2023.01.06 13:39:07 - OpenVPN > IPv4 MTU set to 1500 on interface 9 using SetIpInterfaceEntry()
. 2023.01.06 13:39:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 9 fde6:7a:7d20:88a::10df/128 store=active
. 2023.01.06 13:39:07 - OpenVPN > add_route_ipv6(fde6:7a:7d20:88a::/64 -> fde6:7a:7d20:88a::10df metric 0) dev OpenVPN Wintun
. 2023.01.06 13:39:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:88a::/64 9 fe80::8 store=active
. 2023.01.06 13:39:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2023.01.06 13:39:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 9 all
. 2023.01.06 13:39:07 - OpenVPN > IPv6 MTU set to 1500 on interface 9 using SetIpInterfaceEntry()
. 2023.01.06 13:39:07 - OpenVPN > Initialization Sequence Completed
. 2023.01.06 13:39:07 - Interface OpenVPN Wintun metric changed from Automatic to 3, layer IPv4
. 2023.01.06 13:39:07 - Interface OpenVPN Wintun metric changed from Automatic to 3, layer IPv6
. 2023.01.06 13:39:07 - DNS leak protection with packet filtering enabled.
. 2023.01.06 13:39:07 - DNS IPv4 of a network adapter forced (OpenVPN Wintun, from automatic to 10.12.138.1)
. 2023.01.06 13:39:07 - DNS IPv6 of a network adapter forced (OpenVPN Wintun, from automatic to fde6:7a:7d20:88a::1)
. 2023.01.06 13:39:07 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.12.138.1)
. 2023.01.06 13:39:07 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:88a::1)
. 2023.01.06 13:39:07 - DNS IPv4 of a network adapter forced (VirtualBox Host-Only Network, from automatic to 10.12.138.1)
. 2023.01.06 13:39:07 - DNS IPv6 of a network adapter forced (VirtualBox Host-Only Network, from automatic to fde6:7a:7d20:88a::1)
. 2023.01.06 13:39:07 - Routes, add 0.0.0.0/1 for interface "OpenVPN Wintun (Wintun Userspace Tunnel)".
. 2023.01.06 13:39:07 - Routes, add 128.0.0.0/1 for interface "OpenVPN Wintun (Wintun Userspace Tunnel)".
. 2023.01.06 13:39:07 - Routes, add ::/1 for interface "OpenVPN Wintun (Wintun Userspace Tunnel)".
. 2023.01.06 13:39:07 - Routes, add 8000::/1 for interface "OpenVPN Wintun (Wintun Userspace Tunnel)".
. 2023.01.06 13:39:08 - Routes, add 213.152.162.170/32 for interface "OpenVPN Wintun (Wintun Userspace Tunnel)".
. 2023.01.06 13:39:08 - Routes, add 2a00:1678:2470:18:c954:55da:f018:70ff/128 for interface "OpenVPN Wintun (Wintun Userspace Tunnel)".
. 2023.01.06 13:39:08 - Flushing DNS
I 2023.01.06 13:39:08 - Checking route IPv4
I 2023.01.06 13:39:11 - Checking route IPv6
I 2023.01.06 13:39:11 - Checking DNS
! 2023.01.06 13:39:12 - Connected.
Hi. When I see ping timeout, I wonder whether you have a firewall configuration not allowing ping with IPv6?
In the recent issues I have faced, I learned I had to adjust firewall rules for both IPv4 and IPv6.
However, I don't know how Windows firewall works.
I am unfortunately having the exact same problem as OP. No issues up until a few days ago, but now I time out every single time I try to connect!
Can you give us a list of VPN servers which you experience this IPv6 problem on?
i also timeout on every server when i choose ipv6 , if i choose to use ipv4 it still goes through tho
