quintonjones
NOOB help with initial setup
I am trying to get this thing setup and running so I can use a bittorrent client to download stuff anonymously. Problem is that something is wrong. Tunnelblick keeps trying to connect but getting refused.
I paid for and received the files from AirVPN for my OpenVPN connections. I followed the steps for Tunnelblick setup and have 3 different US servers that looked fast with limited traffic. I have tried all 3 with the same results. Repetitive attempts to connect with the connection getting refused every time. Over and over.
What am I doing wrong? Honestly I am a total noob to all of this. While I understand the premise of the Tunnel I was really hoping this would work right out the gate easier.
A few details:
Macbook Pro OSX 10.8 (If this is a problem I have a tower on Snow leopard I can use instead)
Tunnelblick 3.3beta21a (build 3114.1) - OpenVPN 2.3-alpha1
No ports being forwarded as I don't even understand how to use them
I followed the recomendation to use the Tunnelblick VPN configuration because I do want this to be an automatic thing
"Note: Tunnelblick VPN Configurations are preferred, because they may be shared, may be started when the computer starts, and are secured automatically."
HELP!!
The support team replied to your mail where you attached the Tunnelblick logs. The solution to your problem is straightforward, please check your inbox. :)
