Not connected, Your IP: 216.73.216.117
Staff
[COMPLETED] Hardware check on Phoenicis
Phoenicis has "badly" crashed three time in 7 days. The datacenter technicians will therefore perform a full hardware check in order to try to detect the problem. The hardware check will take at least 6 hours, and the downtime will be even longer if some parts will have to be replaced.
We will keep you informed.
The hardware check is over and no faults have been found in the hardware.
Therefore, the reasons of the crashes remain unfortunately unexplained at the moment. We have brought the server up again and we'll investigate the issue further.
Guest rbj
I didn't see anything about the Romanian server Phoenicis in the forums, so I'll ask. What happened to Phoenicis? Will it be returned/replaced/moved?
I woke up this morning, checked out what happened on Air overnight and no Phoenicis. What ever happened, I'm the Admins had very good reasons for taking this course of action. Just curious is all.
More Swedish servers?
Unfortunately Phoenicis crashed again and again. We are keeping the server unavailable to premium users while we investigate with the help of the datacenter technicians.
