htpc
ANSWERED Device Selection with Eddie
I'm wondering if there is a way to choose which device (from the configured devices in the client area) the Eddie client connects to/as? I couldn't find any settings in the preferences menu to make a choice and I'm a bit lost on how to make it connect as a specific device?
Thanks for your help!
@htpc
The list of available "devices" (client certificate/key pairs) should appear beside the login credentials, on the main window. If it doesn't, please try to uncheck "Remember me", log your AirVPN account out and log it in again (you will need to re-enter your account credentials).
Thanks for the advice 🙏 Now it works!!!
Topic can be closed
