Droopy 2 Posted ... Hi, this morning I woke up to see that air was running and according to the icon in the task bar , go to peer block and my IP is there for everyone to see, do an IP check it is ok, i think the leak was Utorrent logs are below, sorry I changed server and cant remember what server i was on. 5/11/2012 - 8:57 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 5/11/2012 - 9:57 PM TLS: tls_process: killed expiring key 5/11/2012 - 9:57 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 5/11/2012 - 9:57 PM VERIFY OK: nsCertType=SERVER 5/11/2012 - 9:57 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 5/11/2012 - 9:57 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/11/2012 - 9:57 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/11/2012 - 9:57 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/11/2012 - 9:57 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/11/2012 - 9:57 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 5/11/2012 - 10:57 PM TLS: tls_process: killed expiring key 5/11/2012 - 10:57 PM TLS: soft reset sec=0 bytes=103959294/0 pkts=199972/0 5/11/2012 - 10:57 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 5/11/2012 - 10:57 PM VERIFY OK: nsCertType=SERVER 5/11/2012 - 10:57 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 5/11/2012 - 10:58 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/11/2012 - 10:58 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/11/2012 - 10:58 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/11/2012 - 10:58 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/11/2012 - 10:58 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 5/11/2012 - 11:57 PM TLS: tls_process: killed expiring key 5/11/2012 - 11:58 PM TLS: soft reset sec=0 bytes=86720025/0 pkts=165426/0 5/11/2012 - 11:58 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 5/11/2012 - 11:58 PM VERIFY OK: nsCertType=SERVER 5/11/2012 - 11:58 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 5/11/2012 - 11:58 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/11/2012 - 11:58 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/11/2012 - 11:58 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 5/11/2012 - 11:58 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 5/11/2012 - 11:58 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 12:58 AM TLS: tls_process: killed expiring key 6/11/2012 - 12:58 AM TLS: soft reset sec=0 bytes=3899091/0 pkts=13103/0 6/11/2012 - 12:58 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 12:58 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 12:58 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 12:58 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 12:58 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 12:58 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 12:58 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 12:58 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 1:58 AM TLS: tls_process: killed expiring key 6/11/2012 - 1:58 AM TLS: soft reset sec=0 bytes=229419/0 pkts=1670/0 6/11/2012 - 1:58 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 1:58 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 1:58 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 1:58 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 1:58 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 1:58 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 1:58 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 1:58 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 2:58 AM TLS: tls_process: killed expiring key 6/11/2012 - 2:58 AM TLS: soft reset sec=0 bytes=129075/0 pkts=1180/0 6/11/2012 - 2:58 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 2:58 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 2:58 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 2:58 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 2:58 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 2:58 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 2:58 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 2:58 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 3:58 AM TLS: tls_process: killed expiring key 6/11/2012 - 3:58 AM TLS: soft reset sec=0 bytes=145512/0 pkts=1285/0 6/11/2012 - 3:58 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 3:58 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 3:58 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 3:58 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 3:58 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 3:58 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 3:58 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 3:58 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 4:58 AM TLS: tls_process: killed expiring key 6/11/2012 - 4:58 AM TLS: soft reset sec=0 bytes=132143/0 pkts=1215/0 6/11/2012 - 4:58 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 4:58 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 4:58 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 4:59 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 4:59 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 4:59 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 4:59 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 4:59 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 5:58 AM TLS: tls_process: killed expiring key 6/11/2012 - 5:59 AM TLS: soft reset sec=0 bytes=144571/0 pkts=1346/0 6/11/2012 - 5:59 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 5:59 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 5:59 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 5:59 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 5:59 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 5:59 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 5:59 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 5:59 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 6:59 AM TLS: tls_process: killed expiring key 6/11/2012 - 6:59 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 6:59 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 6:59 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 6:59 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 6:59 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 6:59 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 6:59 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 6:59 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 7:59 AM TLS: tls_process: killed expiring key 6/11/2012 - 7:59 AM TLS: soft reset sec=0 bytes=144955/0 pkts=1354/0 6/11/2012 - 7:59 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 7:59 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 7:59 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 7:59 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 7:59 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 7:59 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 7:59 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 7:59 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 8:59 AM TLS: tls_process: killed expiring key 6/11/2012 - 8:59 AM TLS: soft reset sec=0 bytes=134339/0 pkts=1232/0 6/11/2012 - 8:59 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 8:59 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 8:59 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 8:59 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 8:59 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 8:59 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 8:59 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 8:59 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 9:47 AM Disconnecting... 6/11/2012 - 9:47 AM SIGTERM received, sending exit notification to peer 6/11/2012 - 9:47 AM TCP/UDP: Closing socket 6/11/2012 - 9:47 AM Disconnected. 6/11/2012 - 9:47 AM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.6.157 6/11/2012 - 9:47 AM Warning: route gateway is not reachable on any active network adapters: 10.4.6.157 6/11/2012 - 9:47 AM Route deletion via IPAPI failed [adaptive] 6/11/2012 - 9:47 AM Route deletion fallback to route.exe 6/11/2012 - 9:47 AM OK! 6/11/2012 - 9:47 AM C:\WINDOWS\system32\route.exe DELETE 95.211.169.3 MASK 255.255.255.255 192.168.0.1 6/11/2012 - 9:47 AM Route deletion via IPAPI succeeded [adaptive] 6/11/2012 - 9:47 AM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.6.157 6/11/2012 - 9:47 AM Warning: route gateway is not reachable on any active network adapters: 10.4.6.157 6/11/2012 - 9:47 AM Route deletion via IPAPI failed [adaptive] 6/11/2012 - 9:47 AM Route deletion fallback to route.exe 6/11/2012 - 9:47 AM OK! 6/11/2012 - 9:47 AM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.6.157 6/11/2012 - 9:47 AM Warning: route gateway is not reachable on any active network adapters: 10.4.6.157 6/11/2012 - 9:47 AM Route deletion via IPAPI failed [adaptive] 6/11/2012 - 9:47 AM Route deletion fallback to route.exe 6/11/2012 - 9:47 AM OK! 6/11/2012 - 9:47 AM Closing TUN/TAP interface 6/11/2012 - 9:47 AM SIGTERM[hard,] received, process exiting 6/11/2012 - 9:48 AM Login... 6/11/2012 - 9:48 AM Login success. 6/11/2012 - 9:48 AM Contacting service... 6/11/2012 - 9:48 AM Connecting... 6/11/2012 - 9:48 AM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 6/11/2012 - 9:48 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 6/11/2012 - 9:48 AM LZO compression initialized 6/11/2012 - 9:48 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 6/11/2012 - 9:48 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 6/11/2012 - 9:48 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 6/11/2012 - 9:48 AM Local Options hash (VER=V4): '22188c5b' 6/11/2012 - 9:48 AM Expected Remote Options hash (VER=V4): 'a8f55717' 6/11/2012 - 9:48 AM UDPv4 link local: [undef] 6/11/2012 - 9:48 AM UDPv4 link remote: 95.211.191.33:443 6/11/2012 - 9:48 AM TLS: Initial packet from 95.211.191.33:443, sid=b19f7e78 d90fb28f 6/11/2012 - 9:48 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 6/11/2012 - 9:48 AM VERIFY OK: nsCertType=SERVER 6/11/2012 - 9:48 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 6/11/2012 - 9:48 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 9:48 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 9:48 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 6/11/2012 - 9:48 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 6/11/2012 - 9:48 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 6/11/2012 - 9:48 AM [server] Peer Connection Initiated with 95.211.191.33:443 6/11/2012 - 9:48 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 6/11/2012 - 9:48 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.0.234 10.4.0.233' 6/11/2012 - 9:48 AM OPTIONS IMPORT: timers and/or timeouts modified 6/11/2012 - 9:48 AM OPTIONS IMPORT: LZO parms modified 6/11/2012 - 9:48 AM OPTIONS IMPORT: --ifconfig/up options modified 6/11/2012 - 9:48 AM OPTIONS IMPORT: route options modified 6/11/2012 - 9:48 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 6/11/2012 - 9:48 AM ROUTE default_gateway=192.168.0.1 6/11/2012 - 9:48 AM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{C645D3F7-2AC7-4262-8878-3DBC27719666}.tap 6/11/2012 - 9:48 AM TAP-Win32 Driver Version 9.9 6/11/2012 - 9:48 AM TAP-Win32 MTU=1500 6/11/2012 - 9:48 AM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.0.234/255.255.255.252 on interface {C645D3F7-2AC7-4262-8878-3DBC27719666} [DHCP-serv: 10.4.0.233, lease-time: 31536000] 6/11/2012 - 9:48 AM Successful ARP Flush on interface [18] {C645D3F7-2AC7-4262-8878-3DBC27719666} 6/11/2012 - 9:48 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 6/11/2012 - 9:48 AM C:\WINDOWS\system32\route.exe ADD 95.211.191.33 MASK 255.255.255.255 192.168.0.1 6/11/2012 - 9:48 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 6/11/2012 - 9:48 AM Route addition via IPAPI succeeded [adaptive] 6/11/2012 - 9:48 AM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.233 6/11/2012 - 9:48 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 6/11/2012 - 9:48 AM Route addition via IPAPI succeeded [adaptive] 6/11/2012 - 9:48 AM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.233 6/11/2012 - 9:48 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 6/11/2012 - 9:48 AM Route addition via IPAPI succeeded [adaptive] 6/11/2012 - 9:48 AM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.0.233 6/11/2012 - 9:48 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 6/11/2012 - 9:48 AM Route addition via IPAPI succeeded [adaptive] 6/11/2012 - 9:48 AM Initialization Sequence Completed 6/11/2012 - 9:48 AM Starting Management Interface... 6/11/2012 - 9:48 AM Checking... 6/11/2012 - 9:48 AM Retrieve statistics... 6/11/2012 - 9:48 AM Connected. 6/11/2012 - 9:49 AM Replay-window backtrack occurred [1] 6/11/2012 - 9:52 AM Replay-window backtrack occurred [2] Quote Share this post Link to post
Staff 10659 Posted ... Hi, this morning I woke up to see that air was running and according to the icon in the task bar , go to peer block and my IP is there for everyone to see, do an IP check it is ok, i think the leak was Utorrent logs are below, sorry I changed server and cant remember what server i was on.Hello!The problem was here:6/11/2012 - 9:47 AM Warning: route gateway is not reachable on any active network adapters: 10.4.6.157 but immediately after, when restarted, OpenVPN could handle correctly the TUN/TAP interface:6/11/2012 - 9:48 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4It's difficult to say for sure, but maybe the TUN adapter driver had crashed. If the problem persists, we would suggest that you uninstall completely and re-install OpenVPN, making sure to authorize the installer to install all the drivers.In our package for Windows OpenVPN 2.2.2 is included, while if you need different versions please see here:http://openvpn.net/index.php/open-source/downloads.htmlAlso, we strongly recommend that you secure your connection against leaks in case of unexpected disconnections. You can find the guides to do that (according to your system) in the forum announcement section link.https://airvpn.org/forumsPlease feel free to keep us updated.Kind regards Quote Share this post Link to post
