jockworld 0 Posted ... To start with a thanks for the excellent Comodo articles which I followed to the letter and have a fully working connection with all the rules on Windows 8. However, the speed results are 1-2mb whereas without AirVPN I can obtain 20mb plus (my cable speed being a theoretical 50mb). My connections are UDP port 443 using the UK servers. Is there anything I should do to increase speed or is this normal for an AirVPN connection? (I mostly use it with Utorrent). Quote Share this post Link to post
Staff 10721 Posted ... To start with a thanks for the excellent Comodo articles which I followed to the letter and have a fully working connection with all the rules on Windows 8. However, the speed results are 1-2mb whereas without AirVPN I can obtain 20mb plus (my cable speed being a theoretical 50mb). My connections are UDP port 443 using the UK servers. Is there anything I should do to increase speed or is this normal for an AirVPN connection? (I mostly use it with Utorrent).Hello!Can you please try connections to different servers and especially different ports and protocols? Just in case your ISP caps bandwidth on some or all UDP ports.Kind regards Quote Share this post Link to post
