Sanguisugent
ANSWERED After Airvpn changed a device, it was unable to connect normally.
What is the reason?
I 2022.09.10 16:15:50 - Session starting.
I 2022.09.10 16:15:50 - Checking authorization ...
. 2022.09.10 16:15:52 - Using WinTun network interface "VPN - VPN Client (VPN Client Adapter - VPN)"
! 2022.09.10 16:15:52 - Connecting to Achernar (Switzerland, Zurich)
. 2022.09.10 16:15:52 - Routes, skipped for 185.156.175.173 : IPv4 Net gateway not available.
. 2022.09.10 16:15:52 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2022.09.10 16:15:52 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.09.10 16:15:52 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2022.09.10 16:15:52 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.09.10 16:15:52 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.09.10 16:15:52 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.09.10 16:15:52 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.09.10 16:15:52 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.168.10.3:8118
. 2022.09.10 16:15:52 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.09.10 16:15:52 - OpenVPN > Attempting to establish TCP connection with [AF_INET]192.168.10.3:8118 [nonblock]
. 2022.09.10 16:15:52 - OpenVPN > TCP connection established with [AF_INET]192.168.10.3:8118
. 2022.09.10 16:15:52 - OpenVPN > Send to HTTP proxy: 'CONNECT 185.156.175.173:443 HTTP/1.0'
. 2022.09.10 16:15:52 - OpenVPN > Send to HTTP proxy: 'Host: 185.156.175.173'
. 2022.09.10 16:15:52 - OpenVPN > HTTP proxy returned: 'HTTP/1.1 200 Connection established'
. 2022.09.10 16:15:55 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2022.09.10 16:15:55 - OpenVPN > TCP_CLIENT link remote: [AF_INET]192.168.10.3:8118
. 2022.09.10 16:15:55 - OpenVPN > TLS: Initial packet from [AF_INET]192.168.10.3:8118, sid=539f9022 85344d16
. 2022.09.10 16:15:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.09.10 16:15:55 - OpenVPN > VERIFY KU OK
. 2022.09.10 16:15:55 - OpenVPN > Validating certificate extended key usage
. 2022.09.10 16:15:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.09.10 16:15:55 - OpenVPN > VERIFY EKU OK
. 2022.09.10 16:15:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org
. 2022.09.10 16:15:57 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2022.09.10 16:15:57 - OpenVPN > [Achernar] Peer Connection Initiated with [AF_INET]192.168.10.3:8118
. 2022.09.10 16:15:58 - OpenVPN > SENT CONTROL [Achernar]: 'PUSH_REQUEST' (status=1)
. 2022.09.10 16:15:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.115.1,dhcp-option DNS6 fde6:7a:7d20:73::1,tun-ipv6,route-gateway 10.4.115.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:73::1063/64 fde6:7a:7d20:73::1,ifconfig 10.4.115.101 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2022.09.10 16:15:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.09.10 16:15:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.4.115.1'
. 2022.09.10 16:15:58 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:73::1'
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2022.09.10 16:15:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.09.10 16:15:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.09.10 16:15:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.09.10 16:15:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.09.10 16:15:58 - OpenVPN > interactive service msg_channel=0
. 2022.09.10 16:15:58 - OpenVPN > open_tun
. 2022.09.10 16:15:58 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system.  You should be able to create an adapter by using tapctl.exe utility.
. 2022.09.10 16:15:58 - OpenVPN > Exiting due to fatal error
! 2022.09.10 16:15:58 - Disconnecting
. 2022.09.10 16:15:58 - Routes, skipped for 185.156.175.173 : IPv4 Net gateway not available.
. 2022.09.10 16:15:58 - Connection terminated.
I 2022.09.10 16:16:00 - Cancel requested.
! 2022.09.10 16:16:00 - Session terminated.
The following network interface:
is causing a critical error to OpenVPN:
You should be able to resolve the problem in the following way:
Alternatively, you can remove that problematic network interface. As a further option, you can connect with WireGuard. To do so, please select Settings > Protocols and pick WireGuard. (WireGuard will not use the interface detected by Eddie for OpenVPN).
