lucdtn
TCP: connect to 127.0.0.1:9050 failed
How can I solve it?
I use ubuntu, I can't change OS for the moment.
Fri Nov 2 20:55:05 2012 OpenVPN 2.2.1 i686-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Mar 30 2012
Fri Nov 2 20:55:05 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Nov 2 20:55:05 2012 LZO compression initialized
Fri Nov 2 20:55:05 2012 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Fri Nov 2 20:55:05 2012 Socket Buffers: R=[87380->131072] S=[16384->131072]
Fri Nov 2 20:55:05 2012 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Nov 2 20:55:05 2012 Local Options hash (VER=V4): '958c5492'
Fri Nov 2 20:55:05 2012 Expected Remote Options hash (VER=V4): '79ef4284'
Fri Nov 2 20:55:05 2012 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Fri Nov 2 20:55:05 2012 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused
Fri Nov 2 20:55:10 2012 TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused
