Not connected, Your IP: 216.73.216.169
koththegod
Cannot Connect using Tunnelblick (OS X)
I'm trying to connect to the VPN using Tunnelblick on OS X. I did everything properly, but when I attempt to connect, it says failed to authorize.
Can you please send us the Tunnelblick logs?
2012-10-30 19:17:07 [server] Peer Connection Initiated with 178.248.30.131:443
2012-10-30 19:17:08 MANAGEMENT: >STATE:1351639028,GET_CONFIG,,,
2012-10-30 19:17:09 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-30 19:17:09 AUTH: Received AUTH_FAILED control message
2012-10-30 19:17:09 SIGTERM received, sending exit notification to peer
2012-10-30 19:17:12 *Tunnelblick: Disconnecting; user cancelled authorization or there was an error obtaining authorization
I copied all files in the .zip that I generated to the correct folder (the connections show up), but I cannot connect to any (same error)
2012-10-30 19:17:27 *Tunnelblick: OS X 10.8.2; Tunnelblick 3.2.8 (build 2891.3099)
2012-10-30 19:17:32 *Tunnelblick: Attempting connection with AirVPN US Vega - UDP 443; Set nameserver = 1; monitoring connection
2012-10-30 19:17:32 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ US\ Vega\ -\ UDP\ 443.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw
2012-10-30 19:17:32 *Tunnelblick: Established communication with OpenVPN
2012-10-30 19:17:32 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2012-10-30 19:17:32 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2012-10-30 19:17:32 Need hold release from management interface, waiting...
2012-10-30 19:17:32 MANAGEMENT: Client connected from 127.0.0.1:1337
2012-10-30 19:17:32 MANAGEMENT: CMD 'pid'
2012-10-30 19:17:32 MANAGEMENT: CMD 'state on'
2012-10-30 19:17:32 MANAGEMENT: CMD 'state'
2012-10-30 19:17:32 MANAGEMENT: CMD 'hold release'
2012-10-30 19:17:32 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-10-30 19:17:32 WARNING: file 'user.key' is group or others accessible
2012-10-30 19:17:32 LZO compression initialized
2012-10-30 19:17:32 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-10-30 19:17:32 Socket Buffers: R=[196724->65536] S=[9216->65536]
2012-10-30 19:17:32 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-10-30 19:17:32 Local Options hash (VER=V4): '22188c5b'
2012-10-30 19:17:32 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-10-30 19:17:32 UDPv4 link local: [undef]
2012-10-30 19:17:32 UDPv4 link remote: <MYIP>:443
2012-10-30 19:17:32 MANAGEMENT: >STATE:1351639052,WAIT,,,
2012-10-30 19:17:32 MANAGEMENT: >STATE:1351639052,AUTH,,,
2012-10-30 19:17:32 TLS: Initial packet from <MYIP>:443, sid=58155b9c 865418d4
2012-10-30 19:17:32 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/colton/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/colton/Library/Application Support/Tunnelblick/Configurations/AirVPN US Vega - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Scolton-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN US Vega -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2012-10-30 19:17:33 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2012-10-30 19:17:33 VERIFY OK: nsCertType=SERVER
2012-10-30 19:17:33 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2012-10-30 19:17:35 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-30 19:17:35 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-30 19:17:35 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-30 19:17:35 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-30 19:17:35 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2012-10-30 19:17:35 [server] Peer Connection Initiated with <MYIP>
2012-10-30 19:17:36 MANAGEMENT: >STATE:1351639056,GET_CONFIG,,,
2012-10-30 19:17:37 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-30 19:17:38 AUTH: Received AUTH_FAILED control message
2012-10-30 19:17:38 SIGTERM received, sending exit notification to peer
2012-10-30 19:17:42 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-30 19:17:42 AUTH: Received AUTH_FAILED control message
2012-10-30 19:17:42 TCP/UDP: Closing socket
2012-10-30 19:17:42 SIGTERM[soft,auth-failure] received, process exiting
2012-10-30 19:17:42 MANAGEMENT: >STATE:1351639062,EXITING,auth-failure,,
2012-10-30 19:18:02 *Tunnelblick: Disconnecting; user cancelled authorization or there was an error obtaining authorization
2012-10-30 19:18:03 *Tunnelblick: Flushed the DNS cache
I upgraded but it gives me the same error. Also the website (airvpn.org) says that I'm signed in when I'm not.
Last attempted connection failed 43s ago.
Reason: Already logged on 'Herculis'.
I'm not connecting to any server right now. It connects for a second, then it disconnects me and gives me an error.
It finally connected, but no internet was available, it just said this:
2012-10-30 20:29:41 *Tunnelblick: After 30.0 seconds, gave up trying to fetch IP address information using the ipInfo host's name after connecting.
2012-10-30 20:29:41 write UDPv4: Network is unreachable (code=51)
2012-10-30 20:29:41 *Tunnelblick leasewatch: A system configuration change was ignored because it was not relevant
2012-10-30 20:29:42 write UDPv4: Network is unreachable (code=51)
2012-10-30 20:29:43 write UDPv4: Network is unreachable (code=51
2012-10-30 20:41:34 *Tunnelblick: OS X 10.8.2; Tunnelblick 3.3beta21a (build 3114.1)
2012-10-30 20:41:34 *Tunnelblick: Attempting connection with AirVPN CH Virginis - UDP 443; Set nameserver = 1; monitoring connection
2012-10-30 20:41:34 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ CH\ Virginis\ -\ UDP\ 443.ovpn 1337 1 0 0 0 49 -atADGNWradsgnw
2012-10-30 20:41:34 *Tunnelblick: openvpnstart message: Loading tun.kext
OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
/Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3-alpha1/openvpn
--cd
--daemon
--management
127.0.0.1
1337
--config
/Users/colton/Library/Application Support/Tunnelblick/Configurations/AirVPN CH Virginis - UDP 443.ovpn
--log
/Library/Application Support/Tunnelblick/Logs/-SUsers-Scolton-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN CH Virginis -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log
--management-hold
--script-security
2
--up
/Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw
--down
/Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atADGNWradsgnw
--up-restart
--route-pre-down
/Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -m -w -d -atADGNWradsgnw
2012-10-30 20:41:34 *Tunnelblick: Established communication with OpenVPN
2012-10-30 20:41:34 OpenVPN 2.3-alpha1 i386-apple-darwin10.8.0 [sSL (OpenSSL)] [LZO2] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110522-1 (2.2.0)] built on Sep 12 2012
2012-10-30 20:41:34 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2012-10-30 20:41:34 Need hold release from management interface, waiting...
2012-10-30 20:41:34 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2012-10-30 20:41:34 MANAGEMENT: CMD 'pid'
2012-10-30 20:41:34 MANAGEMENT: CMD 'state on'
2012-10-30 20:41:34 MANAGEMENT: CMD 'state'
2012-10-30 20:41:34 MANAGEMENT: CMD 'bytecount 1'
2012-10-30 20:41:34 MANAGEMENT: CMD 'hold release'
2012-10-30 20:41:34 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-10-30 20:41:34 WARNING: file 'user.key' is group or others accessible
2012-10-30 20:41:34 Socket Buffers: R=[196724->65536] S=[9216->65536]
2012-10-30 20:41:34 UDPv4 link local: [undef]
2012-10-30 20:41:34 UDPv4 link remote: [AF_INET]46.19.137.114:443
2012-10-30 20:41:34 MANAGEMENT: >STATE:1351644094,WAIT,,,
2012-10-30 20:41:34 MANAGEMENT: >STATE:1351644094,AUTH,,,
2012-10-30 20:41:34 TLS: Initial packet from [AF_INET]46.19.137.114:443, sid=28d4af64 7da52150
2012-10-30 20:41:34 *Tunnelblick: openvpnstart starting OpenVPN:
* /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3-alpha1/openvpn --cd /Users/colton/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/colton/Library/Application Support/Tunnelblick/Configurations/AirVPN CH Virginis - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Scolton-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN CH Virginis -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atADGNWradsgnw --up-restart --route-pre-down /Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -m -w -d -atADGNWradsgnw
2012-10-30 20:41:35 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2012-10-30 20:41:35 VERIFY OK: nsCertType=SERVER
2012-10-30 20:41:35 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
2012-10-30 20:41:38 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-30 20:41:38 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-30 20:41:38 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-30 20:41:38 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-30 20:41:38 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2012-10-30 20:41:38 [server] Peer Connection Initiated with [AF_INET]46.19.137.114:443
2012-10-30 20:41:39 MANAGEMENT: >STATE:1351644099,GET_CONFIG,,,
2012-10-30 20:41:40 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-30 20:41:41 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.0.10 10.4.0.9'
2012-10-30 20:41:41 OPTIONS IMPORT: timers and/or timeouts modified
2012-10-30 20:41:41 OPTIONS IMPORT: LZO parms modified
2012-10-30 20:41:41 OPTIONS IMPORT: --ifconfig/up options modified
2012-10-30 20:41:41 OPTIONS IMPORT: route options modified
2012-10-30 20:41:41 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2012-10-30 20:41:41 ROUTE_GATEWAY 199.195.254.111/255.0.0.0 IFACE=ppp0 HWADDR=00:00:00:00:00:00
2012-10-30 20:41:41 TUN/TAP device /dev/tun0 opened
2012-10-30 20:41:41 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
2012-10-30 20:41:41 MANAGEMENT: >STATE:1351644101,ASSIGN_IP,,10.4.0.10,
2012-10-30 20:41:41 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2012-10-30 20:41:41 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2012-10-30 20:41:41 /sbin/ifconfig tun0 10.4.0.10 10.4.0.9 mtu 1500 netmask 255.255.255.255 up
2012-10-30 20:41:41 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw tun0 1500 1558 10.4.0.10 10.4.0.9 init
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and SMB server(s) [ ] and using default domain name [ openvpn ]
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 8.8.8.8 8.8.4.4 } }
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 8.8.8.8 8.8.4.4 } }
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = No such key
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.4.0.1; DYN_DNS_SD =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = 8.8.8.8 8.8.4.4; MAN_DNS_SD =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 8.8.8.8 8.8.4.4; CUR_DNS_SD =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses '10.4.0.1' ignored because ServerAddresses was set manually
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 8.8.8.8 8.8.4.4; FIN_DNS_SD = openvpn
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.8 or higher, so will modify DNS settings using Setup: in addition to State:
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS =
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = #
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes:
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 8.8.8.8 8.8.4.4
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: ServerAddresses 8.8.8.8 8.8.4.4
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: SearchDomains openvpn
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: DomainName openvpn
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses
2012-10-30 20:41:43 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes:
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 8.8.8.8 8.8.4.4 } }
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = No such key
2012-10-30 20:41:44 *Tunnelblick: Flushed the DNS cache
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 8.8.8.8 8.8.4.4 } }
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 8.8.8.8 8.8.4.4 } }
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = No such key
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes:
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 8.8.8.8 8.8.4.4 } }
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { TunnelblickNoSuchKey : true }
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use
2012-10-30 20:41:44 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with leasewatch
2012-10-30 20:41:44 /sbin/route add -net 46.19.137.114 199.195.254.111 255.255.255.255
add net 46.19.137.114: gateway 199.195.254.111
2012-10-30 20:41:44 /sbin/route add -net 0.0.0.0 10.4.0.9 128.0.0.0
add net 0.0.0.0: gateway 10.4.0.9
2012-10-30 20:41:44 /sbin/route add -net 128.0.0.0 10.4.0.9 128.0.0.0
add net 128.0.0.0: gateway 10.4.0.9
2012-10-30 20:41:44 MANAGEMENT: >STATE:1351644104,ADD_ROUTES,,,
2012-10-30 20:41:44 /sbin/route add -net 10.4.0.1 10.4.0.9 255.255.255.255
add net 10.4.0.1: gateway 10.4.0.9
2012-10-30 20:41:44 Initialization Sequence Completed
2012-10-30 20:41:44 MANAGEMENT: >STATE:1351644104,CONNECTED,SUCCESS,10.4.0.10,46.19.137.114
2012-10-30 20:41:44 write UDPv4: Network is unreachable (code=51)
2012-10-30 20:41:45 write UDPv4: Network is unreachable (code=51)
2012-10-30 20:41:46 write UDPv4: Network is unreachable (code=51)
2012-10-30 20:41:47 write UDPv4: Network is unreachable (code=51)
I have mac 10.6.6
The only option for port forwarding is TCP.
My client is utorrent. I've followed the guide over and over. reinstalled tunnel over blick over and over. It still says UDP.
Help, please.
****LOG***
2012-10-30 17:58:05 *Tunnelblick: OS X 10.6.6; Tunnelblick 3.2.8 (build 2891.3099)
2012-10-30 17:58:05 *Tunnelblick: Attempting connection with AirVPN US Arietis - UDP 443; Set nameserver = 1; monitoring connection
2012-10-30 17:58:05 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ US\ Arietis\ -\ UDP\ 443.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw
2012-10-30 17:58:05 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/Bkamer/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/Bkamer/Library/Application Support/Tunnelblick/Configurations/AirVPN US Arietis - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SBkamer-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN US Arietis -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2012-10-30 17:58:06 *Tunnelblick: Established communication with OpenVPN
2012-10-30 17:58:06 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2012-10-30 17:58:06 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2012-10-30 17:58:06 Need hold release from management interface, waiting...
2012-10-30 17:58:06 MANAGEMENT: Client connected from 127.0.0.1:1337
2012-10-30 17:58:06 MANAGEMENT: CMD 'pid'
2012-10-30 17:58:06 MANAGEMENT: CMD 'state on'
2012-10-30 17:58:06 MANAGEMENT: CMD 'state'
2012-10-30 17:58:06 MANAGEMENT: CMD 'hold release'
2012-10-30 17:58:06 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-10-30 17:58:06 WARNING: file 'user.key' is group or others accessible
2012-10-30 17:58:06 LZO compression initialized
2012-10-30 17:58:06 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-10-30 17:58:06 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-10-30 17:58:06 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-10-30 17:58:06 Local Options hash (VER=V4): '22188c5b'
2012-10-30 17:58:06 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-10-30 17:58:06 UDPv4 link local: [undef]
2012-10-30 17:58:06 UDPv4 link remote: 198.15.111.162:443
2012-10-30 17:58:06 MANAGEMENT: >STATE:1351645086,WAIT,,,
2012-10-30 17:58:06 MANAGEMENT: >STATE:1351645086,AUTH,,,
2012-10-30 17:58:06 TLS: Initial packet from 198.15.111.162:443, sid=f3f017da a852422e
2012-10-30 17:58:06 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2012-10-30 17:58:06 VERIFY OK: nsCertType=SERVER
2012-10-30 17:58:06 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2012-10-30 17:58:07 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-30 17:58:07 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-30 17:58:07 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-30 17:58:07 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-30 17:58:07 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2012-10-30 17:58:07 [server] Peer Connection Initiated with 198.15.111.162:443
2012-10-30 17:58:08 MANAGEMENT: >STATE:1351645088,GET_CONFIG,,,
2012-10-30 17:58:09 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-30 17:58:09 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.11.222 10.4.11.221'
2012-10-30 17:58:09 OPTIONS IMPORT: timers and/or timeouts modified
2012-10-30 17:58:09 OPTIONS IMPORT: LZO parms modified
2012-10-30 17:58:09 OPTIONS IMPORT: --ifconfig/up options modified
2012-10-30 17:58:09 OPTIONS IMPORT: route options modified
2012-10-30 17:58:09 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2012-10-30 17:58:09 ROUTE default_gateway=192.168.1.1
2012-10-30 17:58:09 TUN/TAP device /dev/tun0 opened
2012-10-30 17:58:09 MANAGEMENT: >STATE:1351645089,ASSIGN_IP,,10.4.11.222,
2012-10-30 17:58:09 /sbin/ifconfig tun0 delete
2012-10-30 17:58:09 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2012-10-30 17:58:09 /sbin/ifconfig tun0 10.4.11.222 10.4.11.221 mtu 1500 netmask 255.255.255.255 up
2012-10-30 17:58:09 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.11.222 10.4.11.221 init
No such key
2012-10-30 17:58:11 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2012-10-30 17:58:11 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2012-10-30 17:58:11 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2012-10-30 17:58:12 *Tunnelblick: Flushed the DNS cache
2012-10-30 17:58:12 /sbin/route add -net 198.15.111.162 192.168.1.1 255.255.255.255
add net 198.15.111.162: gateway 192.168.1.1
2012-10-30 17:58:12 /sbin/route add -net 0.0.0.0 10.4.11.221 128.0.0.0
add net 0.0.0.0: gateway 10.4.11.221
2012-10-30 17:58:12 /sbin/route add -net 128.0.0.0 10.4.11.221 128.0.0.0
add net 128.0.0.0: gateway 10.4.11.221
2012-10-30 17:58:12 MANAGEMENT: >STATE:1351645092,ADD_ROUTES,,,
2012-10-30 17:58:12 /sbin/route add -net 10.4.0.1 10.4.11.221 255.255.255.255
add net 10.4.0.1: gateway 10.4.11.221
2012-10-30 17:58:12 Initialization Sequence Completed
2012-10-30 17:58:12 MANAGEMENT: >STATE:1351645092,CONNECTED,SUCCESS,10.4.11.222,198.15.111.162
2012-10-30 17:58:12 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2012-10-30 17:58:17 *Tunnelblick process-network-changes: A system configuration change was ignored because it was not relevant
@koththegod
Can you please make sure that no program is blocking Tunnelblick/OpenVPN? Check for firewalls and Little Snitch-like programs.
