Not connected, Your IP: 216.73.216.169
Hexx123
AirVPN on DD-WRT not connecting
Its been a few days emailling back and forth with customer support, however, an email a day has taken me nowhere in the last 4 days. Here is me hoping I can get some answers here in the forum. ive followed the guide from AirVPN to the dot to setting up AirVPN on DD-WRT, however, I've had no luck in connecting and my real IP is still exposed here are my DD-WRT logs on OpenVPN
Serverlog Clientlog 20121029 07:22:01 Current Parameter Settings:
20121029 07:22:01 config = '/tmp/openvpncl/openvpn.conf'
20121029 07:22:01 mode = 0
20121029 07:22:01 persist_config = DISABLED
20121029 07:22:01 persist_mode = 1
20121029 07:22:01 NOTE: --mute triggered...
20121029 07:22:01 206 variation(s) on previous 5 message(s) suppressed by --mute
20121029 07:22:01 I OpenVPN 2.2.1 mipsel-linux [sSL] [LZO2] [EPOLL] built on Jul 20 2012
20121029 07:22:01 MANAGEMENT: TCP Socket listening on 127.0.0.1:5001
20121029 07:22:01 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20121029 07:22:01 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20121029 07:22:01 I LZO compression initialized
20121029 07:22:01 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20121029 07:22:01 Socket Buffers: R=[109568->131072] S=[109568->131072]
20121029 07:22:01 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20121029 07:22:01 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20121029 07:22:01 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20121029 07:22:01 Local Options hash (VER=V4): '22188c5b'
20121029 07:22:01 Expected Remote Options hash (VER=V4): 'a8f55717'
20121029 07:22:01 I UDPv4 link local: [undef]
20121029 07:22:01 I UDPv4 link remote: 46.165.208.65:443
20121029 07:22:01 TLS: Initial packet from 46.165.208.65:443 sid=bdd4dd5c 7d495642
20121029 07:22:02 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121029 07:22:02 VERIFY OK: nsCertType=SERVER
20121029 07:22:02 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121029 07:22:46 MANAGEMENT: Client connected from 127.0.0.1:5001
20121029 07:22:46 D MANAGEMENT: CMD 'state'
20121029 07:22:46 MANAGEMENT: Client disconnected
20121029 07:22:47 MANAGEMENT: Client connected from 127.0.0.1:5001
20121029 07:22:47 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
