jrayers
More Comodo questions
Hi, I have been reading the extensive information on the forums about Comodo, VPN leaks, blocking traffic on VPN disconnect, etc., but still find myself quite confused about it all.
At some point I will post screenshots of my Comodo rules and whatnot, but before then the biggest thing that confuses me is how to answer all of the pop-up "firewall alerts" that come up asking me to allow or block this or that connection in or out of my PC from some executable. I have a feeling that my answers to a number of these questions have been wrong, and I am allowing things I shouldn't be, creating leaks and problems in the process.
Should I just ignore all of the pop-up alerts until I get all the rules set up as in this thread?
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=3405&Itemid=142
Thanks in advance
Don't worry, once you have set the Global Rules the only risk is an overblocking of an application by the Application Rules if wrongly set. When you answer to Comodo Firewall questions, Comodo will add Apllication Rules according to your answer ONLY if you tell it to remember it. Even so, you can safely delete the application rules (and if you wish re-define them) after you have set the Global Rules.
